Question about Canon EOS 400D / Rebel XTi Digital Camera
Just a weird noise
My camera sounds like something is loose inside of it...that's it...not much of a problem otherwise. I was just wondering why it sounds like that.
  • jenihen Jun 11, 2008
    Thanks for replying so quickly! I just bought it in March of this year...so it shouldn't be making noises...I know!
I've had this problem as well, but unfortunately, it seems that I discovered it when the camera simply would not take the picture!  So I can't help but think that whatever's come loose inside is a bit more serious.  I would have to point to the ground, then lift it up slowly, THEN it would take the photo.  So for me, I'm thinking it's more than the flash or whatnot previously mentioned.  Very frustrating as I just got this camera four months ago, and treat it like a baby!
Posted on Sep 22, 2008
  • 3 Answers
I think Fiddy01 is on the right track with the noise being the two flash guides. I have an XTi and that rattle is common. to check if it is the flash guides and not something else, first remove your lens so you can isolate the sound to the camera body. Next gently shake the camera to hear the sound. Then pop up the flash, and locate the guides (they are black and glossy, and are attached to the camera with matching Phillips screws). Once you you find them, use your thumb an pointer finger to pinch or hold the guides securly in place. while doing that hold the camera with your other hand and gently shake, DO NOT DROP IT! the sound should be gone. If so than no worries. Just a note there is also a failt sound you may hear while doing this, it is caused by the tilt senor, it will make its sound while doing the above steps, but insead of shaking the camera you slowly tilt/rotate it like going from landscape to portraite and back. This is not a strong sound you may need to bring it close to your ear to hrear it. If you try this and still hear a dominate noise you should have it looked at.
Posted on Sep 11, 2008
I had a 3ood, there was a noise similar to what you describe, when you pop the flash up there are two guides, they rattle a little.
If this is the case don't worry about it, my camera was used daily and only failed when I dropped it in water.
Posted on Jun 14, 2008
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey jenihen,
Cameras are definitely not supposed to have loose parts inside them. If the camera is working properly you could ignore the sound and wait until what is loose ends up causing a problem, or you could have it looked at by an authorized service technician and they should be able to tell you what is loose and what it would cost to get it repaired. This is a very nice camera and if it was mine I would worry that whatever is loose could cause more damage to the camera by ignoring the problem. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jun 11, 2008
MTX 12'' sub noise
Sounds like your sub is overextending itself, and possibly losing contact at the voice coil. Overextending will make a weird rattling sound, losing contact at the voice coil will make a popping sound.
Jan 12, 2010 | Car Audio & Video
Stupid lense error
It sounds like there is mechanical binding inside the lens assembly.
If you are good at working on small mechanics such as like inside a watch, and you have the tools to work on the camera, you could take it apart to see if you can easily fix it.
Most likely you may not be able to buy internal parts for the lens if it needs parts. The lens is normally changed as a complete unit during service.
Jerry G.
Aug 06, 2009 | Nikon COOLPIX S710 Digital Camera
There is a noise inside the camera. Kind of like the sound when you focus, but continuous whether or not you are focusing. Just started this morning. Camera has not been dropped or anywhere weird. It's...
G7 and G9 have a common problem: loose screws short the circuit boards. So if it’s possible, return it. But if you really like to keep it, open the camera and make sure the screws are secured. See here for more details:
Canon G7 won’t power on
Who killed my G9?
Jul 05, 2009 | Canon PowerShot G7 Digital Camera
Weird noise from Acura MDX
Could be a lot of different things... Transmission mount broke, exhaust rubbing against something...ect. Have a mechanic check it out.
Jun 09, 2009 | 2004 Acura MDX
Camera shuts off
I have the same problem.. the camera worked this morning, and now it doesn't. Weird. HELP!
Feb 03, 2008 | Pentax Optio MX Digital Camera
Camera making strange noise
Sounds like the focus mechanism, your camera will be a very light sound while focusing. this is totally normal and nothing is wrong with your camera the sound is a good thing it makes sure your photos are in focus :)
Sep 15, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
76 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
