Question about George Foreman GR10AWHT Indoor Grill
Hot plug Each time I unplug the grill (one of the older small ones, no on/off switch) I notice that the plug is quite hot. Is this to be expected, or is it a safety concern. All my kitchen sockets are I guess what one would call ungrounded, not 3-pronged or appearing to have replaced (at least the covers) in a long time. I keep forgetting to feel the cord to see if it heats up as well. The longest time I've ever grilled anything is 5 minutes, usually 4 (then there's the original pre-heat time as well). Thanks for your help. I hope it's ok...i'd starve without my little grill.
  • Anonymous Jun 30, 2008
    My grill's plug gets hot too and I'm wondering the same thing. I haven't used my grill because the hot plug is making me nervous.
  • Anonymous Jan 11, 2009
    I have the exact same problem.  I actually burned my finger unplugging the device.
  • 368 Answers
Hello xavatea,
If it's too hot to handle comfortably, I'd contact the manufacturer, especially if it's still under warranty.
I've seen other complaints, including one where the plastic on the plug was actually melting, but have not been able to find any safety recalls, although evidently the manufacturer, Salton, Inc. is having a bad year financially - - you might want to get ahold of them sooner than later.
Go to
http://prc.prodregister.com/prodprotect/applica/
And click on "George Foreman" (lower-right portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/gf.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Dec 30, 2008
My george foreman grill will not power on
Check for power at the outlet where you plugged it in. Plug in a small lamp, if it doesn't light could be tripped breaker or blown fuse. I am assuming there is no switch for the outlet. With the lamp still plugged in and on plug in the grill and try to turn on. If the lamp goes off or dims noticeably, you have an electrical problem, contact your electrician. If the light does not dim and it does not get hot take to repair shop.
Oct 27, 2015 | George Foreman GR10AWHT Indoor Grill
Traeger trip gfi
Could be the hot rod igniter has accumulated too much moisture.
From Traeger:
Why won't my Grill Ignite?
  1. If your grill is plugged into an electrical outlet with a GFI (ground fault interrupter) plug, chances are the hot rod has absorbed or been exposed to too much moisture and is leaking to ground causing the plug to trip.
  2. Open your cooking chamber lid, remove cooking grill, angled drip pan and U-shaped firepot cover. Is there ash build up in the firepot and/or around the firepot? If so, this needs to be cleaned out. The ash is choking out the fire.
  3. Check the fuse on the back of the control board. To do this, first UNPLUG the grill from the electrical outlet. Then, unscrew the control board and look at the fuse-is it blown or not?
  4. If the fuse is good, check for power by switching the colored plugs first. Unplug the purple plug and the orange plug. Plug the purple plug into the orange plug. Now plug the power cord back into the electrical outlet and turn the grill on. Does the induction fan operate? If so, you will need a new hot rod and fuse. If not, you will need a new control board. Unplug the purple from the orange and reconnect the plugs together to their correct color plug.
  5. Always start your grill on the SMOKE setting.
Feb 03, 2013 | Traeger Industries BBQ075 All-in-One Grill...
Traeger tripping gfi
Check this out: may be your hot rod has absorbed too much moisture
From Traeger:
Grill wont fire up
From Traeger:
Jun 13, 2011 | Traeger Industries BBQ100 All-in-One Grill...
Traeger 075 tripping GFI continually
May be too much moisture on the hot rod.
From Traeger:
Jun 19, 2010 | Traeger Industries BBQ075 All-in-One Grill...
Cooking Time fr Chicken breast
a lot depends on the thiknesss of the breast. But if the grill is hot say 200C an average time is about 3 minutes per side. To test do a small cut obliquely to ensure it is white all the way through.
Thanks for using FIXYA
Apr 13, 2010 | George Foreman GR10AWHT Indoor Grill
Grill problems
I would advise not to use the grill or the plug it plugs into before determining what the problem is. It could be the grill cord, or the wall plug.
If you have been in the habit of pulling the cord plug out of the wall by tugging on the cord, then chances are the problem is broken conductors inside of the wire insulation. One way to test this is to attempt plugging the unit into a totally different wall outlet. If the cord and outlet heat up again, chances are the cord needs to be replaced (if possible). If the both do not heat up, then the outlet wiring connections inside of the wall need to be checked.
Bad wiring connections either in the wall, or in the cord, will generate heat, when will then conduct to the other connector. So it is difficult to use heat as the indicator of which connector is bad.
Dec 10, 2009 | George Foreman GR36P
My son purchased a GR10WSP1 house grill. He told
ibelivw that there is no on of switch, plugging it in cuts it on
Aug 14, 2009 | George Foreman GR30 Indoor Grill
Not getting hot
possible blocked jet or control unit
check for gas level and regulator operation using other burners
Nov 22, 2017 | Weber Genesis Silver C Grill
George Foreman G5 Grill
With the unit unplugged, check the elements to see if one has become unseated. A gentle push should seat them. Some elements are plug in & can come unseated.
Jan 21, 2007 | George Foreman G5 Indoor Grill
George Foreman GR10AWHT Indoor Grill Logo
99 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
