Question about Jack Lalanne Power Juicer 250 Watts
Darn thing STILL won't turn on
I have the Jack Lalanne power juicer express, my mom gave it to me. She only used it once, and I was with her. Now I have it and it won't turn on. The manual says there is a micro safety switch (which, by the way, I still cannot find) that is supposed to keep it from running if the parts are not all assembled correctly. Is there a trick to this? I have taken it apart and put it back together 5 times and it still won't work. I know the outlet is fine as I tested other appliances on it. HELP!
  • 2 more comments
  • cohem Jun 13, 2008
    machine won't start at all!
  • breejoy Sep 23, 2008
    Thanks for your help, I finally got it working though. I called customer service and what I found out is that the little peg that holds in the safety switch was actually broken off. It's a plastic part that juts out of the base of the pulp cup and into the switch, it looks like a tiny peg. They said it is very common for people to break it off, especially when they don't know it's there, when they pull the pulp cup up instead of straight back. I was able to order a new pulp cup (it also came with a new pusher) for only $12, and the guy was so friendly. Hope this helps other people.
  • nicoleb2
    nicoleb2 Sep 07, 2012
    Thank you! I was able to makeshift a peg and super glue it to the pulp cup.
  • nicoleb2
    New Friend:
There is a little knob on pulp collector that pushes in a switch, probably to assure the unit is assembled before operation. Mine broke off. I opened bottom of unit and used electrical tape to permanently engage the switch. The Juicer now works. I consider it poor construction that such an important part of the operation of the unit is able to break off and poor customer relations that there is no help for this on their web site. I have used it only a handful of times and the unit has mostly been in storage and has not been abused.
Posted on Mar 09, 2013
I recently took my juicer to a friend's house to use over the weekend.  When I plugged it in, nothing.  Tried it again at home, nothing.  Finally after reading some of the stuff here, I opened up the bottom part with a phillips screwdriver.  It's remarkably simple inside and yes, the handle triggers an on/off switch.  I checked all the connections (they all had plugs kind of like a phone or computer) and then reassembled.  The reassembly was a bit tricky because I had to put some little springs back in and make sure the handle was positioned properly.
Once it was all tightened up it worked again.  I'm glad because I was thinking I needed a new juicer and really mine isn't that old...
Posted on Sep 20, 2008
  • 3 Answers
I came to this site with the same problem. I brought out the manual and tried the troubleshoot steps. Sure enough the metal handle was not properly up, hence the machine would not turn on. I adjusted the handle properly and the machine started up. Try it with everything in its place. See if it works.
Posted on Jun 25, 2008
    New Friend:
Investigating some of the other post I did some troubleshooting . I noticed on the basket that catches the Pulp it was A piece of plastic that was broke ( on the bottom middle Compartment that faces the unit. I looked That area of the unit and noticed it was a small hole; so I figured the plastic piece broke off that Released a safety off that allows the unit to turn on. I cut Off the top head of a Q-tip, Stuck it into the hole reassemble the unit and My unit worked. Hope this helped.
Posted on Oct 24, 2014
Where is the safety Switch in the Jack Lalanne juicer express?
The safety switch is on the bottom base where the pulp collection bin goes. If you look on the pulp collection bin there is a small tab that when assembled right deactivates the safety switch. The main arm that holds the top container where you put the produce in is also a safety mechanism that when not in place the machine will not turn on.
Sep 08, 2013 | Jack Lalanne Power Juicer 250 Watts
Mom lost directions. how do you take apart to clean?
You can find a manual for your Jack LaLanne product online here:
http://www.powerjuicer.com/power-juicer-manuals.php
In additon to the instruction on assembly / disassembly in the manual recommend you view the How To Videos available on the site:
http://www.powerjuicer.com/power-juicer-how-to-videos.php
Thank you for using FixYa!
Sep 15, 2011 | Jack Lalanne Power Juicer 250 Watts
Need the operating manual for jack lalanne power juicer express
Manuals for the Jack LaLanne Power Juicers can be found here:
You might take time to browse the site, you will find How To videos, Tips and recipes.
Oct 24, 2010 | Kitchen and Much More Power Juicer
Need an instruction manual for Jack Lalanne Power Juicer?
This picture looks like the Jack LaLanne's Power Juicer "Express." You can google search "owner's manual" for it and download it.
Good luck.
Oct 30, 2009 | Jack Lalanne Power Juicer 250 Watts
Jack lalanne power juicer
I seem to be able to put the crescent too in but the blade just spins and doesn't seem to be connecting to anything to pull it out. Talk about frustration!!!!!!!!!!!!!!!!!!!!!!!
Jul 21, 2008 | Jack Lalanne Power Juicer 250 Watts
Need Power Juicer manual
Found online. They don't make finding the manual easy. Try this http://www.powerjuicer.com/pdf/classic.pdf
Nov 04, 2007 | Jack Lalanne Power Juicer 250 Watts
Jack Lalanne Power Juicer 250 Watts Logo
5,947 people viewed this question
Top Jack Lalanne Juicers Experts
Greg Cann
Greg Cann
Starnley Johnwells
Starnley Johnwells
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
