Question about Philips Magnavox 9P6034C 60" Rear Projection Television
FPA lock on a magnavox
We accidently set the FPA lock on and turned off the TV. We don't have a Remote or a user's manual because our tv was a display model.
The Chasis number is M123SP. manufactured by RCA. If you need any other information to help us please contact us at redravengod@yahoo.com
Thank you.
  • 137 Answers
The only way to fix it is wit remote , get your self a universal remote and do manual search until set switched on , then go to menu and turn lock off before it happened again.
Posted on Jun 29, 2008
RCA Truflat TV 27F522T is completely locked both manually and remote do not work. Was working manually but after checking menu for block accidently FPA locked not can't turn on tv at all.
You must have its remote control to unlock this TV. Try to make your remote control get repaired, and check these.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jun 28, 2012 | Televison & Video
Turn off fpa lock without remote
Install an IR Remote App in android phone. The app link below worked for me to remove the fpa lock on. Configure the App for your RCA TV. Set TV as Device type, RCA as the brand. and choose the model (e.g., TV 20 F420T) also, select the Alternate IR Driver.
All the options of the command may appear in a list form. Close that and an actual remote with buttons should appear.
Then Power your tv will turn ON. Press the Menu. Pressing the Channel Down/Up Button to navigate to Preferences. Press OK button on the screen.. Then Navigate to FPA Lock. Press OK again. THis will turn the FPA Lock to Off.
Then you could use your on-TV buttons ZappIR Universal IR Remote Android Apps on Google Play
Nov 23, 2011 | RCA TruFlat 27F520T 27" TV
How do i unlock my acer laptop? i have forgotan my password
Start the laptop and press F8 to go into safemode. Once boots up, go to control panel and click on user account. There will be option to remove password or reset password.
Thanks
Nov 04, 2010 | Computers & Internet
I hit the FPA and now i am screwed how do i fix this it I cant get into my tv
Child Lock allows you to lock the buttons on the front of the TV.
Press MENU to see the main menu.
Press CH+ or CH- to highlight
Preferences.
Press OK to enter the Preferences
submenu.
Press CH+ or CH- to highlight FPA
(Front Panel) Lock.
Press VOL+ or VOL- to turn on or off
FPA Lock. Choose On to disable all the
buttons on the front of the TV. FPA Lock
On will appear on the TV screen each
time you press buttons on the front of
the TV. You can still operate the TV with
the remote control. You can still use the
POWER button on the front of the TV, but
only to turn off the TV (not on). Set FPA
Lock to Off to cancel this feature so you
can use the buttons on the front of the TV
again.
Press MENU repeatedly to exit the
menu or the menu will automatically
disappear within a few seconds if no
buttons are pressed on the remote
control.
I hope this helps and good luck!
Nov 15, 2009 | RCA TruFlat 27F520T 27" TV
FPA lock on; have no remote control
FPA Lock On and have no remote for the TV on a RCA TV
May 20, 2009 | RCA 24V511T 24" TV
Fpa lock
i need some help people......i need to know how to take off the Lock
Jan 20, 2008 | RCA 27F530T 27" TV
FPA Lock can't turn Tv on
I posted the above - I went to WalMart, bought an $8 remote and a .98 pack of AA batteries. It turned the TV on immediately. Problem solved for less than $10.
Sep 16, 2007 | RCA 14F512T 14" TV
FPA lock settings, No remote, can not power on TV
If you forget your password you can reset it. Make sure the TV is off. Simultaneously press and hold VOL< on the TV?s front panel and CLEAR on the remote for approximately 5 seconds. Enter a new password next time you access the PARENTAL CONTROL menu. Front Panel Lock 1. From the PARENTAL CONTROL menu, press the up or down arrow to highlight Lock Fr. Panel. 2. Press the right or left arrow to turn on (box has check mark) or off (box doesn?t have check mark) front panel lock. Of course if you don't have a remote that can bring up the menu I don't know how this can be done.
Sep 12, 2007 | RCA 27F650T 27" TV
RCA FPA LOCK
Take the remote and turn the set on. With FPA (Front Panel Access, or Child Lock) on, the set will only turn on with the remote. Enter the menu, navigate to the page with FPA and set it to OFF.
Sep 02, 2007 | RCA 20F511T TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
126 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
