Question about E-Machines eMachines Desktop PC
System issues My black emachines page used to flash on the creeen for 10 seconds on starting. Now it remains for 60-90 seconds. I just installed a new printer. Could this be the issue?
  • 871 Answers
That may be the issue. have you tried going to msconfig to stop the printer from autostarting while rebooting? this usually helps boot your computer faster. you may as well disable other apps there in the startup folder so that your computer will boot faster.
Posted on Jun 11, 2008
    Genius:
  • 2,785 Answers
You can uninstall the printer and check for the problem
Reset security system
To review - the factory VATS security system will not let the engine crank or start if the wrong key is used or there is a problem with the system.
So if the engine was cranking the security system was not at fault.
You may have to get a used shop manual to get the testing procedures for a no start-stall problem.
Feb 25, 2013 | 1999 Chevrolet Cavalier
Resetting 1999 cavalier security system
If it's a factory alarm then you need to get it disabled by the dealer. if it's an installed alarm you need to unplug the brain/ module and your car should run
Feb 25, 2013 | 2001 Chevrolet Cavalier
My power save came on, which turned my laoptop screen off, i moved the mouse, the system started up again but the screen remains black/very dark . the only way i can see my computer screen is if i connect...
It sounds like a driver recovery issue, you may have to do a hard reboot. Hold the power button in for atleast 10 seconds or until your laptop shuts down completely, wait 30 seconds then turn it back on. If this fixes the problem you need to upgrade your video driver and/or your Operating System.
Mar 24, 2010 | Computers & Internet
When I turn on my machine, I get 3 beeps and my monitor tell me no signal, the model is a T5026 emachine, please email me any suggestions
First use the following steps:
Turn off the system and disconnect power cables
Press and hold the power button for 10-15 seconds.
Reconnect power cables and try to turn it on.
If it remains same, the next step will be to:
Open the case and re-seat memory modules
If you have more than one modules installed, try to test the system with a single module at a time.
Mar 12, 2010 | E-Machines Emachine T5026 power supply **...
My honda cbr 600rr 2005 will not start the hiss system is flashing when key is in ignition ,and when you turn the engine over it just will not fire up help
1. Obtain a new transponder key.
2. Grind the key in accordance with the shape of the original key.
3. Apply 12V battery voltage to the ignition pulse generator lines of the engine control module (ECM).
4. Turn the ignition switch ON with the original key. The immobilizer indicator comes on and it remains on.
*The code of the original key is recognized by the ECM.
*If there is any problem in the immobilizer system, the system will enter the diagnostic mode and the indicator will remain on for approx. ten seconds, then it will indicate the diagnostic code (page 20-5).
5. Disconnect the red clip of the inspection adepter from the battery positive (+) terminal for two seconds or more, then connect it again. The indicator remains on for approx. two seconds, then it blinks four times repeatedly.
*The immobilizer system (HISS) enters the registration mode. Registrations of all key except the original key inserted in the ignition switch are canceled. (Registration of the lost key or spare key is canceled.)
NOTE:
The spare key must be registered again.
6. Turn the ignition switch OFF and remove the key.
7. Turn the ignition switch ON with a new key or the spare key. (Never use the key registered in previous step.) The indicator comes on for two seconds, then it blinks four times repeatedly.
*The new key or spare key is registered in the ECM.
*If there is any problem in the registration, the system will enter the diagnostic mode and the indicator will remain on for approx. ten seconds, then it will indicate the diagnostic code (page 20-6).
CAUTION:
Keep the other transponder key away from the immobilizer receiver more than 50mm (2.0 in).
8. Repeat the steps 6 and 7 when you continuously register the other new key.
NOTE:
The ECM can store up to four key codes. (The four keys can be registered.)
9. Turn the ignition switch OFF, remove the inspection adapter and connect the ignition pulse generator connector.
10. Turn the ignition ON with the registered key.
*The immobilizer system (HISS) returns to the normal mode.
11. Check that the engine can be started using all registered key.
If that doesn't work,You will need to go to a dealer and have the keys reprogrammed.
Jun 04, 2009 | 2005 Honda CBR 600 RR
Tried to do a restore with restore disc that came with the comput
There seems to be a problem with the operating system that is being installed. This often happens if you use the restore disks that came from another computer.
Are you sure that you used the disks that came with that exact computer? Does it flash a blue screen right before restarting the cycle?
Try the restore over again and if the problem persists, you may have to either order new restore disks for your computer or buy a fresh copy of Windows XP.
Apr 11, 2009 | eMachines T3604 PC Desktop
Emachine xp 2000
An overheated video card will do this when it is under high load, among other problems, like artifacts, lines, delayed and choppy video, etc. Cool your system somehow. Put a small fan by your PC.
Aug 10, 2008 | E-Machines eMachines Desktop PC
EMachine laptop/windows xp problem
ur window had been crashed pls install new window
Jun 15, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Emachines desktop
Could be a sign of hard drive trouble or may need to reload the Operating System. Back up your data and do a system recovery with the cds the machine came with. That will erase hard drive and reload Windows. If still takes a long time to load chances are it is a hard drive starting to fail.
Hope this helps!
Jun 11, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
