Dell d610 start only a few second then its going off
Cannot boot/start. start just a few minutes only
  • 871 Answers
Hey azmi
try to go to the bios and check if HD0 is your primary boot.
try also to go to safemode by pressing f8.
Posted on Jun 11, 2008
    Genius:
  • 2,785 Answers
Try to boot in safemode, if you cant then you have to reload or repair your operating system
Dell latitude D610. Bios Revision AO6 Anyone Help?
try to remove bios battery on the inside and short the pins with something iron like a screwdriver for a few seconds, remove the battery pack too when doing this, you should be fine after that,
ps. you might need to set some bios parameters when starting up again
Nov 03, 2016 | Dell Computers & Internet
My parents Dell Latitude D610 is returning the Internal HDD Hard Error. When I press F2 for the setup utility as it suggests, there is no option to enter safe mode. What should I do?
DELL Laptops usually have a bulit in self test.
You can enter it either by pressing F10 key at boot time and then go down to "Boot to utility partition" or "Hardware test".
If there is no such menu, you can still find your "Drivers and Utilites" disc. Put it in your optical drive and boot from it. You will be asked for starting tests by pressin Keys "1" or "2" or so. Once you booted into the main menu choose "Test System" and finally "Run tests". Optionally, you could specify the hardware part that you want to diag, but harddrives take most of the time, all other components are tested within a few seconds. Thus you can take the full diag as well.
Jan 13, 2011 | Dell Latitude D610 Laptop Computer -...
How can i recovered bios password of dell d610
Take out battery don´t work on Dell Laptops.
I got my Dell Bios & HDD Master Pasword within a few minutes from http://www.bios-password.kickme.to/
Jul 30, 2010 | Dell Latitude D600 Notebook
Dell Latitude D610. It is coming up with the Erro Mentioned in t
Have you tried System Restore? If not familiar... Start Button ---> Help ---> System Restore ---> "Restore my computer to an earlier date" --> choose an appropriate date, maybe a few days earlier than the problem.
Re-boot and see if works! If you are ceratin that the problem arose simply from hibernating, then restoring should do the trick!
Hope this helps!
May 17, 2010 | Dell Latitude D610 Notebook
My loptop D610 turn on ,caps lock blinks and ater 3 to4 secons it
I would try clearing the cmos battery. It's located under a small door under the laptop battery. Unhook the wire (laptop unplugged) and let it sit for 20 minutes. Hook it back up and try to power up. If that doesn't work www.pcrepairhelp.net has techs that work on laptops.
May 04, 2010 | Dell Latitude D600 Notebook
Dell latidude d610 wont start properly
Can you select "safe mode" from the boot menu? As much as I hate to recommend it, I think you should wipe the hard drive and reinstall Windows (I hope you backed up everything of value on your computer). If you can't successfully reinstall the operating system, then I'd say, in all likelihood, you have a defective hard drive which would need to be replaced.
Feb 11, 2010 | Dell Latitude D610 Notebook
Hello, I have the Dell Latitude D610. All of my apps; you name it are gone. When turning on the PC it takes a lil longer to load into WINDOWSXP. All I have on my desktop is the recycle Bin :(....I've tried...
It sounds like the computer is booting into the administrator account, which also maybe safe mode.. When the computer boots up and is stable (give it a few minutes) go online and go to the following site and downoad the shown program. It is called Malwarebytes Anti-Malware tool. Download, run and update this tool. Perform a quick scan and when the scan finishes, click on the "show results" button, then delete every infection it finds. When it is done, reboot the system.
Dec 06, 2009 | Dell Latitude D610 Notebook
Dell D610 will not boot to hard disc
in os installed not corrected driver (s).
1. when goin bott press F8 and select "Dont reboot when error..."
windows go in blue screen, and write to screen what still by error (file name)
2. Try boot in safe mode. Find and delete this file.
3. Boot in normal mode.
If dont work. Boot with help WinPE bootdisk and scan your system by Viruses and Malware
Nov 07, 2009 | Dell Latitude D610 Notebook
D610 boot failure
Remove all drives, Memory and wireless cards, see if the indication changes. If no change, replace the motherboard. If they change, add memory back one module at a time, see if the system will post. If one does, then the other is bad.
Apr 03, 2009 | Dell Latitude D610 Notebook
Dell d610 goes off
remove the cd if it is in your drive and remove battery also and see.
Mar 25, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
