Video problems I just purchased this motherboard and everything is hooked up right and I am not getting any video and the keyboard and mouse is not working at all.
I just purchased VIA KM266 motherboard and everything is hooked up right and I am not getting any video driver for Windows Vista so it not working at all.
Posted on Jun 11, 2008
I have a zx4351, touch sreen wireless gateway desk top computer , i had cable co. today to hook it and now my screen does not turn on and has no power going to it what is it?
Your desktop tower/cpu tower has to be turned on to give those hardware power. If you can't turn on your computer then that means you have an internal problem with your motherboard etc. If everything else powers up except for the screen/monitor your video is dead. Find someone you know that has an extra monitor and hook it up to your tower, if it works then it's not your video but the monitor instead.
Dec 01, 2012 | Gateway Computers & Internet
I have an old Compaq Presario 6420nx (6000) This happened after updating to a XFX 256 graphics AGP card, I installed all drivers and updated bios. After rebooting , no video,mouse or keyboard working. I...
If your computer works fine with an onboard video, it is possible that your motherboard is not getting much power. The agp video card gets power from the motherboard. I suggest using a different power supply.
Jun 01, 2011 | Computers & Internet
Emachine w3609 will not turn on green light is on the motherboard nothing works i did the power drain and still does not work could the ps be bad or the motherboard or both
Yes to both of your questions.
When nothing works, I first unhook everything from the motherboard except for the CPU, video, and memory. Then turn it on. If you get the fan starting up and video, then hook up the hard drive and keyboard and mouse to see if it works. Lastly, hook up the CD--this is the part that fails most often.
Mar 17, 2011 | Computers & Internet
To give background I have DG45ID mother board, and a ATI 5570 video card. My computer works with no problems until it goes to sleep for more than I few minutes. When I try to wake it up after it has...
Try updating all the drivers. Mainly the chipset and the video card drivers. If you have a wireless card, update it too.
Also make sure that the onboard video card is disabled in the setup-
Nov 09, 2010 | Intel DG45ID Motherboard
Monitor on power save mode and using wireless keyboard and mouse
This sounds like the monitor is not reading a signal from the computer. I had the same problem when I installed a DIV cable from my old VGA cable. The video card was still sending the signal via VGA port instead of the DVI port of my video card. You should cheack the cable to you're computer and what port is being used. If everything is hooked up correctly then there might be a problem with the cable. Other then that it could be you're video card. If the hard drive is running and everything is running fine then what I said should be whats wrong. If nothing works go back to the shope and tell them the new problem you have.
Sep 10, 2009 | Dell Wireless Keyboard Optical Mouse w0147
How to disable the onboard graphic card when nothing comes up
Its not a problem with integrated graphic or PCI card. Sometimes if the keyboard or mouse fails, the display won't come on. Check by using a working keyboard & mouse(also check for any nent pins in the Ps2 jack)..........sodeep
May 11, 2009 | Asrock K7S41 Motherboard
Complience of motherboard and video card on new PC
remove the GFX and try onboard or try chainging ram slots...
Mar 14, 2009 | Evga e-GeForce 9800 GX2 DDR3 PCI-Express...
Computer Does not Boot correctly, Monitor is Black.
Very interesting...Might try the following...
- Video. Yes, almost garuntee that it is either the video card/onboard or the cable. Look at the cable and cable connectors and see if one of the pins has been shoved in. This is common. Often, one will replace the cable and still have the problem because a pin has been shoved in on the mother board.
- Power. Remove everything from your computer except the keyboard and the monitor (yes, even the mouse) to eliminate any power drain issues. If you can, remove the DVD drive (unplug power and data bus cable).
- BIOS. One beep is good. You should be able to get into the BIOS setup no mater what other problems you are having. The BIOS uses a generic text, video and keyboard driver. If you aren't able to see ANYTHING after the beep then it is definately the route from the motherboard through the video card or onboard video, through the cable to the screen. You seem to be going through the right steps to debug but just haven't found it yet because it is something that you have dismissed as working...like the pins on the video connector. Go through your path again, this time look at anything that you have assumed that was working and suspect it as the issue.
Jan 08, 2009 | Computers & Internet
Computers & Internet Logo
363 people viewed this question
David Payne
David Payne
