From google maps help which you access by clicking the menu in the top left and then help, then type your question.
see link also:
Add or edit business information on Maps
You could follow the instructions here :
Add or Edit Business Information on Google Maps to add your location using Google Maps :
- Open Google Maps and make sure you're signed in.
- Zoom in to the map where you want to add your business.
- In the bottom right, click Report a problem.
- Click Add a missing place.
- Drag the marker where you business is, and add any relevant information.
- Click Submit.
Alternatively, I recommend that you
add the place on
Google Map Maker as it is better at parsing addresses, especially in India, if you are trying to add your location here :
Add a place
Before you add a place, check if it exists on the map. If not, follow the steps below:
- Open Map Maker.
- In the top left, click Add New.
- Select Add a Place.
- Select the Satellite view and zoom in to the appropriate location.
- Drop the marker on top of the building where your place exists.
- From the drop-down menu, select a category. You can also search for a category.
- Enter the name of the place. To add multiple names, click Add more names. To add more details, click Continue. To discard your edit, click Cancel.
- Click Save.
Note: Check if the name you choose follows the
guidelines.
Map Maker might provide a list of possible duplicates. If the place you want to add is already in this list, select the duplicate item and click
Continue. A P.O. box number is not a physical address.
Thanks.
