Question about HP Pavilion dv1000 Notebook
No power - no boot
I actually got it to power up and it worked for over an hour. Then it suddenly shut down, and have had no luck re-booting. When you say the powersupply, do you mean the power adapter? Or do you think this sounds more like motherboard?
Thanks so much for you help!!
  • wwjdjata Jun 14, 2008
    There are no signs of power what-so-ever. I have re-seated the ram as instructed by the HP troubleshooting website, after doing so is when I got the computer to boot up. It worked for an hour or so and then shut off, I have not been able to get it up and running again. Is it possible just changing the memory card will work? Or am I doomed to purchase a new laptop? Thanks for your help!
  • francisco de mesa
    francisco de mesa May 11, 2010
    are there any signs that your notebook has power? is the power led turned on? are there any lock keys that are on and how does it behave? does the ac adapter have a solid green light? try also removing all external device attached to your computer like printer, docking station, usb flash drive and others.
    try using also an external monitor.
    when you turn on the computer do you get to see anything on the screen like a logo or watever?
  • 611 Answers
For this two resasons is there one is your power and other one is your ram in your note book can do change the both the thing for testing purpose . or check it the power adapter to other note book. after that you get it.
Posted on Jun 13, 2008
  • kalpesh jain
    kalpesh jain Jun 14, 2008
    just changing your the memory card but i think that you re-installed your o/s and give there repair if your main file is goes deleted by mistake then you recover the files that's why you do re-installed the o/s and give repair it.
Why will my Asus transformer tf101 not boot up can it be fixed ?
Three possible solutions, from mild to drastic--hope one of them can help.
1) In my experience, the battery can drop below a threshold voltage quite suddenly and cause the boot-up to freeze, or not start at all. Before you do anything else, be sure it's *fully* charged by leaving the tablet switched off and plugged into the charger for at least 12 hours. Then try starting it normally. If it still doesn't start up,
2) Try holding the power button down for a long press, at least 10-15 seconds. Sometimes this is enough to kick it into action. If not, you could try the nuclear option--
3) --a hard reset, which could be achieved by pressing a straightened paper clip into a small hole (*not* the headphone socket), or by holding down the power button and pressing the volume-up or volume-down button and then following on-screen instructions (check your manual). Note that this will erase all your user data and you should back up everything first, but if you can't boot I don't see how you could accomplish this.
Aug 11, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
My D620 starts to boot up then shuts down suddenly
could it be that your battery is no longer holding a charge?
try powering it up with the power pack attached (and ensure the light on the power pack is indeed lit) - it also could be that the laptop is not being charged by the power pack.
Jul 14, 2010 | Dell Latitude D620 Notebook
My laptop turned off but it has 35% remaining battery
Laptop turns off suddenly? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage.
If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed.
Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
May 29, 2010 | Computers & Internet
Turns off suddenly
Mar 27, 2010 | Toshiba Satellite M55-S331 Notebook
My computers seem to have become somehow linked by the KVM switch
The GCS632U is just one KVM switch. But if you're going to check it out, it has actually two separate connections.
It will just switch once you toggle from one computer to another.
Try to power cycle the KVM switch.
1. Shut off both computers.
2. Disconnect the KVM switch from the computers. (make sure that not even a single cable is connected to the computer, even the audio).
3. Leave it disconnected for 10 minutes.
4. Reconnect the KVM and boot up the XP first.
5. Boot up the Vista, try to toggle from one computer to another.
6. LASTLY, shut off the Vista and see if same problem will occur.
If you get the same problem, then you need to contact IOGEAR and have them RMA the device. Because this is the first time that I heard of this problem.
Thank you and good luck!
Jan 25, 2010 | IOGear GCS632U 2-port KVM Switch
THE LAPTOP JUST SHUTS IT SELF DOWN
Check if the cooling fan is actually turning on or if the exaust is cloged with any derbis. If so, you should try cleaning them and later observe if it works. However, if the cooling fan fails to run you should replace it.
Mar 22, 2009 | Toshiba Satellite A205-S5809 Notebook
No power - no boot
You need to State some of your Symptoms... Like what you are seeing when attempting to boot.... is the screen just black?? do you see the BIOS POST... does it go to loading windows... do you see any lights turn on after hitting the power on button.?.. do any fans spin?? More Info.....
You might want to check the Heatsing Fins and the fan(s) they're probably clogged and your laptop is getting overheated and causing it to shut down... Unless it doesnt power on at all.. no lights no nothing... then it's most likely your motherboard..
Jul 07, 2008 | HP Pavilion dv6000z Notebook
No power - no boot
Could be the power adapter. Sometimes they start to overheat and shutdown.
Could be other things, but the AC adapter is the least expensive to fix
Jun 16, 2008 | HP Pavilion dv1000 Notebook
No power - no boot
no power no boot can be indicative of a motherboard failure or could also be the memory. try removing all the memories, hard drive, the optical drives and all external devices connected to your computer. if you get to hear a beeping sound .. your in luck your motherboard is alive and just need to isolate which among the remaining pieces is causing the no power.
Jun 14, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
50 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
