Question about Philips 170C4FS 17" LCD Monitor
170c lcd screen saying no video input
My screen keeps sayin no video input and i ahve checked all the wires and everything is fine but the problem persists can u help
Hey i relise you had this problem a while back but i am having the same problem, may i ask how you resolved this problem?
regards
adam
Posted on May 21, 2009
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
Direct tv plugged into av. tv on av. still says no
Hello. Use the remote control and push the input button on your tv, making sure that everything is on. Go through the input menu until you get your pix back. Regards, Joe
Jan 13, 2010 | Vizio L32 32 in. LCD HDTV
My Philips 170C monitor does not work when I turn on. It only says "attention signal off".
it thinks this is no input signal. make sure your computer is on and the cables are secure, switch your screen with a known good one from a freind. this will rule out your computer. if the pc is fgood maybe go into the bad monitor menu settings and make sure the input mode is correct. if this is not the cause you may need to have it repair, your monitor video or display board maybe bad.
Dec 26, 2009 | Philips 170C4FS 17" LCD Monitor
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Dec 12, 2009 | Element Electronics FLX3220F 32 in. LCD TV
"Input not supported" roaming on my screen
It means that the resolution of the windows is set too high for your monitor. You will have to find some better monitor to connect it to it, and then to lower the resolution, after that, it should be working just fine
Nov 15, 2009 | Acer P191WBD LCD Monitor
No picture when on for approx 15 minutes
It sounds like you are saying the "video looks scrambled but the audio keeps playing OK"
Normally this is a Video Processor Problem that requires a Board to be replaced.
When the problem happens, can you see the TV menu or the TV's On Screen Display clearly.
I suggest checking to see if the problem happens with the video inputs like, Composite(yellow/red/black), component(RGB/yellow and black), HDMI and S-video. If it happens to all inputs then you need to replace a board.
May 21, 2009 | Vizio VW37L 37 in. LCD HDTV
LCD screen continues rolling
There is connecting ribbon wire between LCD board and main camera board, this ribbon wire is cracked and needs to be replaced.
Dec 10, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
White Screen on Dynex LCD
Please stop buying these cheap things.....your out of luck. Parts are not available for these cheap chinnese sets....Thank Bill Clinton. Anyway, sound like the tuner going out. But....you can't get a tuner...Sorry. Just try using a vcr or cable box on video input and change channels that way.
Jul 28, 2008 | Dynex DX-LCD37 TV
Monitor keeps saying self test everything working check plugs
The self test thinks nothing is connected to it
it might be the cable or the input circuit.
not an easy issue to verify if you only have one input.
most often its is the internal board with a failed input circuit.
you can only open the unit and test the vga cable continuity.
as most have a 1 year warranty you might want to check on yours.
Nov 13, 2007 | Acer AL1912 19" LCD Monitor
Zire 71 collected moisture
The digitizer function reads from the input of the LCD touch screen, so I would say LCD.
Dec 22, 2006 | Palm Zire 71 Handheld
Philips 170C4FS 17" LCD Monitor Logo
331 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
