Question about HP LaserJet 4100n Printer
HP Laserjet 4100N saying toner is low when it isn't
HP 4100N displays "Toner Low" for over 6 months before it runs out. Is there a sensor in the printer or in the toner cartridge that tells the printer when the toner is low?
  • Anonymous Dec 29, 2008
    Is there a way to disable this message?
  • 638 Answers
Yes Is there a sensor in the printer and in the toner cartridge that tells the printer when the toner is low. if u r using new cartridge it indicates perfectly.if u r using refilled cartridge the indication is not always u do one thing use your cartridge till u think the printout is perfect do not worry about this messages this is common in many printers.if this solution helps u pls rate it as "fixya" thank u for using fixya.good luck.
Posted on Jun 11, 2008
Hp laserjet p3015 not printing
The printer will have a message in the screen saying roughly how many pages are left in the toner cartridge if the toner is running low. Try printing a "configuration page" by pressing "ok", arrow down to "information", arrow down to " print configuration page", then press "ok". If this page prints you still have toner left.
Dec 12, 2012 | HP Laserjet P3015X Printer
I have recently replaced my black toner in my HP Laserjet CM1015 MFP and now I cant get anything to print? other toner colours are low but haven't given me a low warning so a bit puzzled why I can
Check and make sure the toner is in correctly. Also go to your start menu if you are running windows and look for your print settings print a test page if this isn't working then please message back.
Sep 25, 2012 | HP LaserJet CM1015 All-In-One Printer
Why does my printer say low toner and have garbled print when i downloaded drivers and changed toner?
In the configuration menu you should have an option to select when changing the toner to say "New Toner" yes or no.
Jun 14, 2010 | HP LaserJet 4100dtn Printer
HP Laserjet P1006 prints with blank white stripe down left side
Clean the Corona Wire carefully to remove any residue. As the charge on the wire is effectivley masked it cannot deposit any toner to the page and will result in a consistent white vertical stripe.
Aug 29, 2009 | HP LaserJet 1022 Printer
Display says toner out even with new cart. Setting new cart message in resets menu to yes does not work, selection reverts back to no. Customer is using reman carts.
A number of companies use a fuse that blows when the cartridge is low. If the fuse is not replaced, it will still say "toner out". The reman should have replaced it.
Jul 27, 2009 | HP LaserJet 4100 Printer
I am trying to reinstall the black ink cartridge to a hp2605dn and it keeps saying the error 10.1000
I found this info on the web for you, guessing you are using a recycled or generic cartridge:
The HP LaserJet 2300 toner cartridge has a smart chip on the top left side. This chip tells the printer when the toner is low.
Recycled toners do not or can not reset the chip, therefore when you use a recycled toner you may get toner low messages although the toner is good.
Also, you may get the 10.10.00 error. There is a work around to fool the printer into not displaying the message.
Place a strip of opaque tape or paper on the chip. When the printer detects a non-standard cartridge press the green (go) button. It will then reset the LCD to Ready.
No guarantees but it seems plausible.
Jun 19, 2009 | HP Color LaserJet 2600n Printer
Hp laser 4500 says toner is low or out even after new cartridge
There is a toner sensor in this printer that shoots a beam of light through the toner cartridge. As long as the toner is full and blocks the light, it sees it as being full. If it were the sensor, it would tell you this for all the toners, though. The printer also calculates how much toner may have been used and gives warnings based on that. It could be that this isn't getting reset after you change toner. You can reset the toner gage by going into the reset menu and selecting "New xxxx cartridge" and changing it to YES.
Mar 17, 2009 | HP Color LaserJet 4550n Printer
HP 2550L says toner is low when it isn't
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | HP LaserJet 2550L Printer
Hp color laserjet 2820. Low on something. Icon next to toner colo
If you are talking about the icons under the little display first four are the toners the one on the far right is the drum unit it has a small solid circle with a large bar going through it rounded at the bottom & has like a fish tail on the top goes top left to bottom right.
Dec 31, 2008 | HP LaserJet 2820 Printer
Laser Printer Cleaning
Does the dirty background get lighter as you print additional pages? Have you tried a new cartridge yet? Unless your toner cartridge is leaking toner (you?ll see toner on the inside of the printer or leaking out if you remove the cartridge and shake) a simple cleaning is probably not the answer. Let me know and we'll pick up later.
Feb 28, 2007 | HP LaserJet 4100n Printer
HP LaserJet 4100n Printer Logo
392 people viewed this question
Ben Johnson
