Question about Canon ZR100 Mini DV Digital Camcorder
Canon ZR200 keeps reading "card error"
How do I fix this. my camera keeps reading "card error" and I keep getting a no battery message.
Format the card with the camera. If that doesn't work, format the card as FAT (not FAT32) file system with your PC.
Posted on Jul 11, 2009
Card error as I put it inside canon camera sandisk sdhc with adapter
The ZR200 works with SD cards, not with SDHC cards. While the SDHC card fits, it is electronically incompatible.
Sep 20, 2011 | Canon ZR200 Mini DV Digital Camcorder
I keep getting an error card message with my new 8 gb sdhc car I bought
The ZR 200 uses standard sd cards. It will not work with an SDHC card.
Nov 09, 2010 | Canon ZR200 Mini DV Digital Camcorder
It says card error
There can be few issues related to the card error message in the DV.
First of all take the card out and check it on the PC card reader. If there is any possibility of virus then scan to detect , quarantine or delete.
If the card is fine copy off all the files to a folder and format.
now put the formatted card to the DV.
If the errror comes up there can be fewother issue.
1. The fault of non contact of the card slot.
2. The possibility of the interface failure to the mP.
3. the possible soldering joints of the slot contacts.
If you are able to open with good experience of handling micro mechanisms, then open this section to check for some dirt or dry solderings.
Otherwise take help or just keep the DV working as it is except for the still images.
Sep 02, 2010 | Canon ZR200 Mini DV Digital Camcorder
Trying to format cards, but it says "cannot format, replace card"
in Canon Cameras, there's one thing you should keep in consideration:
if you take the photos off the card (or even edited them on the card), the camera won't accept to read them anymore.
you need to format the card on your PC (using the canon software) and then reformat it on the camera.
Aug 21, 2009 | Canon EOS 40D Digital Camera
Lens error restart camera
This is a common problem with with cameras with retractable zoom lens .
Heres a few thing you should try :
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. If you get another type of error message this may mean you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
TO AVOID THIS PROBLEM AGAIN : Keep away from dust, dirt, grit, sand and any camera bag that has loose fibres (clean it before use).
If this helps you, please vote...thankyou and good luck!
Jul 28, 2009 | Canon PowerShot SD1100 IS Digital Camera
Canon zr200 wont format new 4gb sandisk card...why?
The ZR200 is able to read a card of maximum of 2 Gbytes !!!
The 4 GB SD card it is a so called SDHC = Secure Digital High Capacity ! Every SD card with more than 2 G Bytes it is a High Capacity and the old hardware will not be able to use these SDHC.
Jan 11, 2009 | Canon ZR200 Mini DV Digital Camcorder
Viewing pics downloaded onto the mem card?
yeeep .. the ZR200 (and not only - in fact all the Canon cameras/camcorders) it is expecting to see/read a jpeg file according with Canon Standard Name within that folder IMG_dddd.jpg
Jan 01, 2009 | Canon ZR200 Mini DV Digital Camcorder
Canon S400 problem
The little internal button battery that keeps track of time is going dead. Canon will fix this for free on your model camera regardless of warranty status. Here's the link to the info:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8777&keycode=2112&id=27465
Mar 14, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Canon ds6041
The error 02 can come up when there is CF card problem : card not seated properly , card takes too long to come on line from the cameras point of view or if one of the the pins inside CF card chamber is faulty.
Sep 12, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon ZR100 Mini DV Digital Camcorder Logo
795 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
