Question about Whirlpool LEB6200 Electric Dryer
Help Last week I turned on my dryer before going to work. When I returned home it was still running and wasnt hot at all. This has been the case since that time. why is this?
  • Anonymous Jun 21, 2008
    I replaced the heating element it heated up for a few minutes and now there is no heat.
    Problem Solver:
  • 9 Answers
You should NEVER NEVER turn your dryer on and go to bed or go out.
Check your fuses or breakers in your house panel and if there fuses change them. Also try it on adifferent cycle maybe you have a bad timer
Posted on Jun 24, 2008
    Genius:
  • 1,073 Answers
Check the heating element it is bad
Posted on Jun 11, 2008
Gas dryer won't light
Check the gas valve with a meter for coil resistance and voltage, there is a delay from when the ignitor comes on and the gas valve opens.
Apr 14, 2017 | GE Dryers
Maytag dryer sounds like it is going to start but wont start
could be that the belt is cut off , of the the puleys are jam .. does it make a big noise ( squeeky noise
May 12, 2017 | Maytag PYE2300AY Electric Dryer
Our kenmore dryer is 6 years old , model# 110.63102101 at first the drum wouldn't turn,and we would get it to turn by using our hand , last week it smelled liked it was burning, so let it rest and then it...
In your case the motor probably has gone bad....you are looking at a 200-400.00 repair, so go from there...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 04, 2010 | Kenmore 62602 Electric Dryer
Ive been putting the cheapest gas for six years and last week i put the 92 gas and last nite i was at a light and it died on me it turns but wont start
it wasnt the gas. they were made to run on the regular. thats not to say there wasnt any water in the gas though
Mar 26, 2010 | Kia Rio Cars & Trucks
Our dryer stopped working last week. We were drying a load and when we returned the dryer was very hot on the outside (more than normal) and the button to turn it on no longer worked. There is power to...
There is a in line thermal fuse that is in the machine near the heating element that has probably burned out from overheating replace the thermal fuse and check your vent pipe for clogs and or kinks that cause the machine to overheat.
Mar 08, 2010 | Whirlpool WED5500S Electric Dryer
Heating works but drum doesnt turn.
Try turning drum, or remove top from dryer to confirm if belt has gone. When turning drum there should be some resistance as the belt fits around the drum
Feb 18, 2010 | Whirlpool LER4634J Electric Dryer
Dryer runs hot and a little louder
sounds like the thermostat needs to be replaced
Jun 15, 2009 | Amana ALE643RB Electric Dryer
1996 Cavalier--PLEASE HELP
Maybe try to replace the map sensor and the oxygen sensors
Jul 26, 2008 | 1996 Chevrolet Cavalier
2 dryers that run but have no heat
It sounds like the gas supply is not giving you any gas, as both have the exact same symptoms. You can see the glow coil getting red hot, then the safety shuts off after a it gets no gas. If you feel confident, shut off the valve in back coming from the wall, unscrew the line where it connects to the dryer. Turn the valve back on slowly, there should be gas pressure blow out of the line.
Dec 19, 2007 | Dryers
Kelvinator ED 56 Dryer
reach inside and see if the drum turns real easy. It should turn real easy even wth wet clothes in it. if it hard to turn then the motor aint gonna get going gonna run hot and quit.
Jun 27, 2017 | Dryers
Whirlpool LEB6200 Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
