Question about Apple iMac G4 Desktop
Power button not responding
After moving cpu from floor to desktop (unplugged all cords prior to move) the mac does not power on. Absolutely no response, as if it is dead.
    Genius:
  • 1,673 Answers
Carefully check all the wires to be properly seated in to their respective connectors. Make sure you did not cross any connections by accident.
If the above fails and the warranty is finished on the computer, you can take the chance to open it yourself and see if there are any connectors that become loose.
If all the above fails, you will have to bring the computer to the MAC dealer for service.
Jerry G.
Posted on Jul 08, 2008
MAC G3 QUICKSILVER WON'T START UP AT ALL, WHAT CAN I DO TO TRY AND FIX IT?
Disconnect all the device.
remove the ram
remove the battery
keep it aside for an hour
then put them back , don't connect the power cable , press and hold the power button for 20 seconds then connect power cord.
good luck
Jun 10, 2014 | Apple Power Mac G4 Dual Mac Desktop
MacBook Pro is slow when disconnected with electric charging.
First step would be to Reset Your Mac's SMC
The method for resetting your Mac's SMC depends on the type of Mac you have. All SMC reset instructions require shutting down your Mac first. If your Mac fails to shut down, try pressing and holding the power button until the Mac shuts down, which usually takes 10 seconds or so.
Mac portables with user-removable batteries (MacBook and most MacBook Pros):
1.Shut down your Mac.
2.Disconnect your Mac portable from its MagSafe connector.
3.Remove the battery.
4.Press and hold the power button for at least 5 seconds.
5.Release the power button.
6.Re-install the battery.
7.Reconnect the MagSafe connector.
8.Turn your Mac on.
Mac portables with non-user-removable batteries (MacBook Air and some late 2009 MacBook Pro models):
2.Connect the MagSafe power adapter to your Mac and to a power outlet.
3.On the built-in keyboard (this will not work from an external keyboard), simultaneously press and hold the left shift, control, and option keys while you press the power button. Release all keys at the same time.
4.Press the power button to start your Mac.
Mac desktops (Mac Pro, iMac, Mac mini):
2.Unplug your Mac's power cord.
3.Press and hold the Mac's power button for 15 seconds.
4.Release the power button.
5.Reconnect your Mac's power cord.
6.Wait five seconds.
7.Start your Mac by pressing the power button.
Alternative SMC reset for Mac Pro:
If you have a Mac Pro that isn't responding to the normal SMC reset as described above, you can force a manual SMC reset by using the SMC reset button located on the Mac Pro's motherboard.
2.Unplug the Mac's power cord.
3.Open the Mac Pro's side access panel.
4.Just below the Drive 4 sled and adjacent to the top PCI-e slot is a small button labeled SMC. Press and hold this button for 10 seconds.
5.Close the Mac Pro's side door.
6.Reconnect your Mac's power cord.
7.Wait five seconds.
8.Start your Mac by pressing the power button.
Now that you have reset the SMC on your Mac, it should be back to operating as you expect. If the SMC reset didn't fix your problems, you can try combining it with a PRAM reset. Although the PRAM works differently than the SMC, it can, depending on your Mac model, store a few bits of information that the SMC uses.
Jan 23, 2013 | Computers & Internet
Bretford iPad Cart Static Electricity problem
This was straight from a Bretford tech:
There are no capacitors or anything that can hold a charge on the cart itself. The only thing that we've been able to come up with thus far is that dry air in the schools may help generating static electricity. Common precautions would be 1. make sure the ground plug is still on the cord. (This can get broken off if the cart is moved with the cord still plugged into the wall.) Plugging the ground cord in won't help however if the person has to grab the door handle to open the door to get to the wall outlet. 2. If the air is dry (ie: people get shocks even without the cart or the problem goes away in the spring when the humidity goes up), gently push the metal of the cart handle against the door frame prior to reaching for the door handle. This will discharge any static electricity that was built up as the person walked with the cart safely to the door jamb prior to the person reaching for the door handle.
Nov 20, 2012 | Apple Computer Apple Bretford PowerSync...
When i moved my pc the monitor,mouse,keyboard quit.when push button on monitor it displays power saver on & goes off/it also beeps 4-6 times when turned on.
When you moved your pc you probably knocked the graphics card loose. You can open it up and try re-seating it. Make sure you unplug the pc first and then press the on button for 10 seconds to clear out all the power from the power supply before opening the computer up.
Also, If you are using a KVM... Unplug the KVM's power cord for 30 seconds and plug it back in. That will reset it.
May 14, 2012 | Dell Dimension 4700 PC Desktop
Want power up
Any lights at all? try swapping a printer power cord or another power cable on it. Does the fan on power supply move? CPU fan moving?
Need more info.
Jul 08, 2009 | Dell Dimension E510 PC Desktop
Cannot turn printer on
might as well do a reset:
for partial reset:
1.unplug the power cord wthout turning the printer off
2.while the cord is unplugges, press # and number 3 simultaneously
3.hold the 2 button for 10 seconds while inserting the plug back
4.release the 2 buttons when the printer reinitialized.
for semi-full reset:
follow same steps but press # and number 6
semi full means the printer is set back to factory settings or default settings.
Mar 04, 2009 | HP Photosmart C6180 All-In-One InkJet...
Moving within page with columns
What program are you using? The answer may be different if you are using a Microsoft product, vs an Apple product, on your Mac.
Have you tried shutting down and restarting your Mac?
Jan 31, 2008 | Apple Power Mac G5 Desktop
Apple iMac G4 Desktop Logo
55 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
