Question about NEC Electra Elite 32D-1 Corded Phone
Can I forward an incoming call to an outside line?
We often get calls that need to be sent to an employee's cell phone, but we can't always give out that number.. is there a way to forward an incoming call to an outside line?
Thanks in advance!
External transfer to Mobile 1. Transfer 2. press 1 and external # 3. Wait for ringing 4. press feature then transfer 5. hang up
Posted on Oct 06, 2008
Trying to call an employees extention and it goes straight to intercom and he cant recieve any incoming calls on a dterm 80 phone
Not too clear on what's happening. Maybe the phone is set to call forward all. Usually CFA code is 41 plus ext. If the user happened to dial 41......, but forgot to dial 9 first for an outside line the phone could be forwarded to the twilight zone. In this case, dial 42 to cancel CFA, problem solved. If do not disturb in on, code 40 is the cancel code. This depends on your codes being at default, if your office codes were changed, say to make room for 400 series extensions, then who knows what will set and cancel CFA or DND. If you want the phone to ring instead of voice announce on internal calls, I'll have look for that later. I know it can be done in programming, but there's probably a code so you can do it yourself.
Apr 14, 2014 | NEC Dterm DTP 16D-1 Corded Phone
Hi I have been tasked with simple programming task on a panasonic kx-td816 ISDN phone system. Well I thought it would be simple!!. We are small company and when we are out of the office I want to set up...
Don't they have Panasonic Engineers where you are? We don't have ISDN here, but we do have things like software revisions, CF off premise, and flags in 990 and 991 that have to be turned on to forward a call to outside numbers. In our features guide, 4.3.13 Call Forwarding -- To Outside Line, there's a Conditions and Programming Guide References that tell us that you need Class of Service changes and Outside-to-Outside Line Call duration time (206 default 10 minutes) 504 CF to outside line and 601 Class of Service programs to change.
Your Mileage(Kilometers) May Vary.
Carl
Jun 25, 2011 | Panasonic KX-T7436 Phone (KXT7436000000)
How does one forward incomming calls on a uniden 2.4ghz cordless phone?
Cordless phones can not 'forward' a call to an outside line.
Forwarding must be controlled by the ATT, Verizon, or landline provider.
Please contact your provider to determine if you have call forwarding feature built into your service package.
Then, follow the instructions of your landline phone provider.
Here is the instructions for Verizon:
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
  1. Lift your telephone's receiver and listen for a dial tone.
  2. Press star.gif7.gif2.gif.
    Dial 1172 on rotary or pulse-dialing phones.
  3. When you hear the tone, set or change the Call Forwarding number by dialing the telephone number where you want your calls transferred.
    You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
  4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
    You will hear two short tones telling you that Call Forwarding is activated.
  5. Hang up the receiver.
Feb 16, 2011 | Cell Phones
Forwarding Calls to Outside # for Nortel T7316
You can set divert for the calls to another number. Do check for the call settings and activate the divert based on situation like.. When busy. Not reachable.
Aug 19, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Forward calls to an outside party
try this press SP phone - 7106-9+tel no. which you wanted to forward the call.this is a call forwarding to outside CO line
Mar 03, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T633?
If it were my choice, I'd set up an ICD number and forward that to an outside number. Something like pick 400 or 600 plus your extension like 605 (they tend to be defined by default), and go into the group fwd command to dial your cell numbers.
Any call placed from anywhere, either VM, internal, or transfer will go out on another line and dial your cell...assuming you put the fwd number in both places.
Carl
Aug 20, 2008 | Panasonic KX-T7633 Corded Phone
Forwarding to cell phones or outside lines
Hi Lauri, the calls can be FORWARDED to a cell phone or the call can be CONFERENCED with a cell phone but can only be TRANSFERED to a phone/voicemail in your office. The information for external fordwarding and conferencing is in the iDCS user guide. Let me know if I can help .....Mike
Aug 06, 2008 | Samsung DCS 12 Corded Phone
Forwarding to an outside line..?
Call forward off net needs to be allowed in Class of Service. If it is not than it must be programmed in. If it is than use your forward all code enter 9 and the full phone number.
Jun 13, 2008 | NEC Electra Elite 32D-1 Corded Phone
Need help forwarding phones
The programming on the Samsung should be set so that your highest line number is selected when you call out, this leaves your first line available for incoming calls. If you want to access line 701 from any phone you should be able to just dial 701 instead of dialing " 9 ". Let me know how is goes. ...Mike
May 27, 2008 | Samsung DCS 12 Corded Phone
NEC Electra Elite 32D-1 Corded Phone Logo
1,039 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
