Question about Dryers
Pilot Light Where would my pilot light be located? I can send pics if needed. Thanks.
  • 3 Answers
Usually behind a removable panel on the bottom front of the dryer, the panel may have a few screws but most just "snap" on and off. You should see a gas valve with a red knob that has the "off", "pilot" and "on positions.
Posted on Jun 11, 2008
What do I need to do to lite my heater after a summer rest?
How to Light a Furnace Pilot Light Here, we'll explain the basic steps for re-lighting the pilot light of a gas furnace.
#1: Locate the Instructions Label on Your Furnace
Every furnace should have a label on it that tells you how to light a furnace. Sometimes, however, the printing may be small or the furnace area may be dark. In these cases, the label may be difficult to read. Keeping the following instructions near your furnace or in another safe spot where they can be located easily will make the task much easier.
#2: Find Pilot Light and Components
Near the bottom of your furnace is a switch that normally says "Pilot," "On" and "Off." Find this switch and turn it to the "Off" position. Wait at least five minutes. This is important because it gives the gas time to dissipate, which is necessary to avoid possibly starting a fire. While you are waiting, take note of the location of the reset button, which should be near the dial you just turned to "Off."
#3: Re-Light the Pilot Light
Once the gas has had time to dissipate, turn the knob to "Pilot." Then, hold down the "Reset" button and bring the flame of a long lighter close to the pilot light opening. This should light the furnace pilot light. Once you are sure the pilot light is on, release your pressure on the reset button.
Sometimes, seeing a job bein
Oct 28, 2017 | Heating & Cooling
How to light the pilot. The pilot went off when I shut the power off during the Irene storm. I cannot locate where to open so I can light the pilot. I have a GE Profile Gas Dryer, Mod.PDSR 610GG8WT
unless this is a very very old dryer,, it will have a glow plug element in it and should light without the need to light a pilot, just try starting it and see if it lights, But it would have to be ages old to need a pilot lit, I'll try and locate that model, But lemme know if it fires up will ya
Sep 11, 2011 | Dryers
How do you light the pilot light on the stove? Model 3627391592
A pilot light will be found on natural gas stoves, fireplaces, clothes dryers, water heaters and furnaces. When the gas is turned off, the pilot light will go out on all of these appliances. After the gas is turned back on, you must relight the pilot light before you can use the appliance. Pilot lights are similar so if you can relight the pilot light for a gas heater you can relight the pilot light for a gas stove or any other gas appliance.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Instructions Things You'll Need:
  • matches OR flashlight
  1. Locate the gas valve by following the gas line in the appliance. The gas valve will have a large red button or knob and will be easy to see and will be well marked.
  2. Check for a gas leak by smelling the area close to the gas valve. Listen carefully for escaping gas and do not attempt to light a pilot light if there is a gas leak.
  3. Hold down or press the red button or knob on the gas valve while holding a lit match in front of the opening in the gas pilot line. Continue to hold down or press the red button or knob for several seconds after the gas ignites to allow the thermocouple (the sensor for the appliance's thermostat) to heat up.
  4. Repeat step 3 if the pilot light goes out after you release the button or knob. In most cases, the pilot light goes out because the thermocouple did not have enough time to heat up, so give it a few more seconds.
  5. Make final adjustment of the gas flow to the pilot light by turning the red knob. In some cases, no adjustment other than "on" or "off" will be needed.
  6. Turn on our appliance to make sure the pilot light ignites the main gas flow. Replace any covers or close any access doors to the gas valve.
Hope this help?
Thanks for using fixya.
Nov 23, 2010 | Kenmore Kitchen Ranges
How do i light pilot light?
Remove front cover,or just lower section if you can. they usually just need to be lifted up about an inch or so and pulled out. However some have covers that snap in place. After you remove cover locate gas valve. It should have a control knob on top with markings for on, off, and pilot. Set control to pilot. Follow lines from gas valve to burner compartment, one goes to main burner one ,small copper colored line is the thermocouple, other line is the pilot. Turn thermostat down as far as it will go. Make sure gas supply valve in line to heater is on and then depress pilot control , when you have pilot control depressed have a match or other small flame source close to pilot assembly. If it lights then hold down on pilot control for a couple of mins. Slowly release pilot control and if it stays lit turn gas control to on. Turn thermostat up to call for heat and burner should light. If pilot doesn't stay lit when you release pilot control then try again holding pilot down longer. If it still won't stay lit then thermocouple will need replace. Good luck. Thanks
Nov 22, 2010 | Williams 6508732 Gas Heater
How do i relight my standing wall heater light, where is it?
There should be a removable panel on the bottom front. Remove this panel and you should see gas valve with two lines going into combustion chamber. The larger of the two will be for burner and the smaller to the pilot light. There may be lighting instructions on the inside of panel,or on front of burner compartment. If not look at gas valve and see if you can see where it is marked off pilot and on. Turn thermostat to lowest setting and gas valve to pilot ,locate pilot light and hold match to it while you depress pilot button . Pilot should light. If it does hold button depressed for 1 to 2 mins. Release pilot button and if pilot stays lit turn valve to on. Turn thermostat up to desired setting and see if burner comes on. If it does you should be done. Put cover back on. If pilot light does not stay lit or burner won't light I Would recommend you call a service tech as there are several things that could be wrong. Hope this helps you.Thanks
Nov 12, 2010 | Montgomery Ward (223600UP) Heater
PILOT LIGHT KEEPS GOING OUT.
If the pilot flame is weak, when the main burner is ignited, there can be enough 'whoosh' of air and gas to blow out the pilot. There may be a little of grit in the pilot valve jet hole restricting the flow, hence the weak flame. Try using a piece of fine wire to clear the obstruction. If that does not help the pilot jet will have to be unscrewed and cleaned with compressed air. Ensure the gas is turned off before attempting any maintenance.
Sep 13, 2010 | Reliance Water Heater #6-40-GBRS 40GAL...
I have a Frigidaire gas range, model #FGF316BSA. When I attempt to operate the oven it won't light. The glow bar comes on but nothing happens after that.
Hi
Thanks for using FixYa. From what you have described it seems that possible oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Kitchen Ranges
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
Hi
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.
The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.
If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.
The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Ovens
My 1.5 yr old gas water heater has a pilot light problem
YOUR WATER HEATER HAS WHAT IS CALLED A STANDING PILOT-STAYS LIT ALWAYS WHEN THE PILOT GOES OUT YOU LOOSE EVERYTHING. YOU HAVE TO REPLACE THE THERMOCOUPLE WHICH KEEP THE PILOT LIT. ONCE THE PILOT IS LIT THE THERMOCOUPLE SENDS IN MILLIVOLTS TO THE BURNER TO SAY ITS READY FOR BURNING
IF YOU ARE NOT FAMILURE WITH THIS REPLACEMENT PLEASE FIND SOME ONE WHO CAN. IT IS NOT HARD TO DO ASK A NABOR OR FRIENDS SOME HAS TO KNOW HOW. SERVICE COMPANYS ARE OUT FOR THE MONEY FOR A 10 MINUTE JOB
Aug 10, 2009 | Water Heaters
Where is the pilot light located
your unit dioes not have a pillot that would need need relighting, it instead uses a glow bar ignitor. auto pilot.
Dec 15, 2008 | Frigidaire FGB24L2A Gas Single Oven
Dryers Logo
70 people viewed this question
Top Dryers Experts
