Dvd disc will not play or copy w/ WMP
Error Message (when copying to desktop): Data Error (cyclic redundancey check)
Error Message (when playing WMP): Error (WMP cannot skip to the requested location on the Dvd)
  • 24 Answers
Or you might try re-installing a DVD decorder. That sounds more likely then a dirty disk.
PEACE
Posted on Jun 12, 2008
  • 265 Answers
I would try first washing the DVD. Use dishwashing liquid and hot water, with only your hands, and use side-to-side motions to move the soap around the underside of the disc, never 'with' the grain of the data grooves. When finished, rinse the disc thoroughly, and pat it dry with a clean paper towel or other lint-free cloth. When dry, try it again.
Hope this will FixYa!!!
A number of qued files are stopping windows midia player from playing dvd,s
Some DVD copies use different compression codes.
check files by loading on a computer (do not auto play)
view folder on DVD then view file detail see if compatible file types with your system...
Dec 06, 2013 | Computers & Internet
My DVD-HR753 will not read discs. A message comes up saying 'this disc cannot be played or recorded'
Original dvd disc,not copy or not another countries datas disc?Same country as the DVD player was bought and formatted Disc?Most likely the disc u trying to play it is in a difference formatted of recording or finalizing data codes inbeted by some patent coded program.Tries play many more other DVD discs,should work find,than the original disc,u trying to play have protected datas or difference format and not same as of ur DVD player main programming firmware.
May 27, 2011 | Samsung DVD-HR735 DVD Recorder/HDD...
When I want to copy a CD must I only record on a CD blank disc; i.e. not a DVD
It depends upon what type of data you want to copy onto a CD or DVD.
If you want to copy and play music in a CD player then it needs to be on a CD disc.
If you want to copy and play movie DVDs in a DVD player then it needs to be on a DVD disc.
If you want to backup data files then it can be on either CD or DVD discs (depending upon the amount of data to be stored on the disc - CD holds 700 Mb, single layer DVD holds 4.7 Gb, and dual layer DVD holds 8.5 Gb of data).
A DVD player can read both CDs and DVDs, but a CD player cannot read DVD discs.
Dec 30, 2009 | Dell Insprion 4F778 (4F779) DVD Drive
When I try to copy Outlook data from the DVD to HDD it is getting an error '' cannot copy Outlook: data error (cyclic redundancy check) kindly do the needful to resolve the issue. Thanks & Regards...
CRC error indicates bad sectors, try one thing:
open the data file from outlook and from there create a new pst on the destination and copy the mails, you may loose some mails but the rest of the data will be safe
Jul 23, 2009 | Computers & Internet
Cyclic redundancy error
In simple terms, a CRC is bit of mathematics used to ensure that your data is OK when being transfered. It's a checking procedure that quickly identifies when data has been damaged. If you get this message, it means that the file being read by your PC or software is corrupted. However, it does not mean all the data is lost forever. When data is transfered, it is usually in small blocks and each block is given a CRC value. If something goes wrong with the data between the time it leaves the source and arrives at its destination, the CRC sent at the source will no longer match the one that is calculated when the data arrives - this is when the cyclic redundancy check error will appear,
All of the above is true, didnt write it myself copied it from a good friends post. It is probably the data itself that is corrupted. Doesnt mean the data is gone. Try running a disk defrag, if that doesnt work try copying it to a cd/dvd and see if you get the same error. If you dont, flash your bios. This should explain your problem, if it doesnt follow up with me, email address is kustom42 at gmail.com.
Jul 14, 2009 | E-Machines eMachines Desktop PC
Cannot upload or play dvd with error report
Reinstall your windows player then you need to install the codecs to be able to read other formats here's one of the most complete packs of codecs. if you have doubts try this, install VLC player if the movies work on that player then your problem with the WMP will be the codecs. Make sure you install the full version.
http://www.free-codecs.com/download/K_lite_codec_pack.htm
May 20, 2009 | Computers & Internet
Wmp and dvd
try going to microsofts site and installing the dvd softwae for wmp
Dec 12, 2008 | Computers & Internet
Moving files from Windows xp
The file on the hard drive is corrupt, run scandisk and fix the file error, but the video is likely a loss
Jul 06, 2008 | Dell Dimension 8100 PC Desktop
Samsung DVD VR355 DVD format problems
I have just copied a video to a dvd on my samsung dvd-vr355 and finialised the disc with a title now it will not play any disc,even if it is. shop bought, just says loading then the dvd opens to reject the disc. please help
Mar 07, 2008 | Televison & Video
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
