Question about Nvidia GeForce 6600 Graphic Card
Do this graphic card require supplementary power???
Do this graphic card require supplementary power from the power supply????
  • BIOS21 Jun 15, 2008
    Thanks a lot! It works!!
  • 70 Answers
No need, unless the FAN requires an external power source, but you can use your powersupply to supply it.
Posted on Jun 11, 2008
Is not Reading My Geforce GTX 260 Card
What do you mean connect wire to graphics card?
A) Computer is to be OFF when connecting a monitor cable.
B) Computer is to be OFF, and unplugged from power; when plugging the power cable from Power Supply, into it.
You are also supposed to be Following Anti-Static Precautions.
What Power Supply are you using?
Manufacturer name, and model number. Post back in a Comment.
Motherboard requires about 150 Watts by itself.
That isn't including what the Processor (CPU) needs, Ram Memory needs, optical drive/s need, computer case fans need; AND what the Nvidia GeForce GTX 260 graphics card needs.
It needs 225 Watts by itself.
(Manufacturers usually state around 500 Watts MINIMUM.
This is in reality based on a COMPLETE computer system, and NOT just the graphics card itself)
What do I base that the GTX 260 needs 225 Watts?
(I see that as the -> Maximum, though )
A PCI Express x16 expansion slot on a motherboard, is only capable of 75 Watts of power.
That is why the additional power cables were brought out.
The 6-pin PCI Express power cable that plugs into the GTX 260, is capable of an additional 75 Watts of power.
The Nvidia GeForce GTX 260 requires using TWO 6-pin PCI Express power cables
That means 150 Watts of additional power.
75 Watts + 150 Watts = 225 Watts
http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-260/specifications
"Supplementary Power Connectors -> 6-pin x2"
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress
If you are using just one 6-pin PCI Express power cable, '
this = NO.
NOT enough power for the graphics card.
What will happen?
A) The PCI Express x16 slot connector oins, will burn
B) The gold plated contact pins on the bottom of the graphics card, will burn.
C) The connector on the graphics card, that the 6-pin PCI Express power cable plugs into, will burn.
D) The connector on the 6-pin PCI Express power cable will burn.
The graphics card will burn up.
Too little power.
IF, your Power Supply has enough power, and IF there are two 4-pin Peripheral power cables that aren't being used; you can use a 6-pin PCI Express power adapter cable.
Example of 4-pin Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Example of 6-pin PCI Express power adapter cable, was shown in the Playtool link,
http://www.directron.com/pci03.html
(Connectors are white, and hard to see against white backdrop. You can enlarge all 3 views)
For additional questions please post in a Comment
Regards,
joecoolvette
Feb 23, 2013 | Gigabyte GA-M61PME-S2 Motherboard, AM2,...
Hi! I am using nvidia Ge force 6600 256mb AGP graphic card of m/s pny verto which has an additional supplementary power terminal. My mainboard is Intel D865GLC Board. every time when i start my computer i...
Hi Yasir,
As you can see from the image above the molex power from the PSU is connected to the card for additional power. from your post "Where as the power cable is duly connected" like the image?. If you connected the supplementary power, you have to consider the peripherals connected to your desktop and the brand of your power supply.
The link would help you if your power supply wattage is sufficient. Link
If you are using generic power supply, for example a 500 watt power supply the real wattage can be 300-400 watts only.
Using a tru rated supply might fix the problem. try to test a different power supply for your system or try to turn off or remove additional devices that consumes power that might help.
Hopefully this information helped.
Thank you for using FixYa.
Sep 10, 2011 | PNY Verto GeForce 6600, (128 MB) AGP...
What is the minimum power supply required for this card?
  • Hello limkweenan, the "Minimum Power Suppy" requirements for the [XFX - 7 Series] is 350 Watts, the 'Minimum Power Supply" requirements for the "Newer" [XFX - AGP Series] is 1000 Watts. "I hope this information is helpful? Thanks for using FixYa, paul7of9"
Feb 04, 2011 | Pine Technology XFX GeForce 7600GT, (256...
Problemas con el video
I also need Your OS.
Before
making yourself nuts, test the monitor on another PC or laptop. If you use a laptop to test the monitor and it doesn't automatically detect an external monitor when booting, use the "F" function keys along the top of the keyboard to tell the laptop to shift to the external display. Remember that we are testing just to see if the monitor is live, it doesn't matter if the screen settings are wrong and the display looks funny. If it doesn't work on a known good computer, the problem is with the monitor, not your PC. If a faint image is detectable on an LCD screen, the problem is with the backlight or the inverter that powers the backlight. A loud buzz coming from an LCD monitor is most likely the inverter circuit failing, though it can go on getting louder for years before it pops.
Assuming the system power comes up, does the monitor power come on? Monitors have a status LED on the front bezel that should show green, orange, or blinking if the monitor is powered on. You can also hear older monitors power on with a gentle sound, though I can't describe it beyond saying it's the sound of a CRT tube warming up. Make sure the monitor is plugged into a good outlet by testing the outlet with a lamp or any other device that will prove beyond a doubt that the outlet is good. Make sure that the power cord is either permanently attached at the monitor end or that it is seated fully in the socket, since partial cord insertion is the most common failure for monitors with detachable cords.
LCD displays don't make any sound when you turn them on, but they don't always have a simple power cord, either. Some LCD monitors are powered by an external transformer, which in turn is powered from a regular AC outlet. If the LCD display doesn't show any signs of life, make sure that the cords into and out of the transformer are fully seated. Some transformers are equipped with a status LED to show when they are operating, though you can also check for live output with a DC voltmeter. The power connection to the LCD display is often awkward to inspect, recessed into the back of the display. The important thing is to make sure it is started correctly, then seat it all the way.
If you see a message on the screen that includes "power" in it, like: "attach graphics card power", "no power to video adapter", etc, it means that you have a PCI Express or older AGP video card that requires more power than the motherboard can supply through the bus. This means you need to run a power cable directly from the power supply to the video adapter, inside the PC. If it's a new build, you may have forgotten or not seated the connector firmly. If it was a working PC, either the power supply lead has failed, the power supply itself has problems, the cable worked loose, or some hardware on the video card has failed.
Earlier video cards that required additional power from the power supply usually took a Molex connector, the same 4 pin connector used to power non-SATA drives. Newer power supplies include one or two six pin PCI Express supplementary connectors designed for power hungry graphics cards. Some PCI Express cards, in the absence of a six pin supplementary lead, will accept two 4 pin Molex leads.
Dec 23, 2010 | ASUS P5RD1-VM Motherboard
How to check if my power supply is already not ''at the limit''?
1 or 2 extra hdds and ram does not require much extra power and your coolmaster should do the job. But if you intend to use a newer graphic card you should check the requirenments for wattage at your new card manufacturer product specification webpage. I am pretty sure that almost all newer graphic cards require at least 500 watt to run without problem. My advise is to buy at least a 550 watt psu although i don't know what is your hardware. Try to post your hardware specs and calculate for each component (cpu wattage+graphics wattage +etc) your power supply need to be over 50 wattage. Hope that helped!
Mar 22, 2010 | Cooler Master (RS-430-PMSR/P) (RS430PMSRP)...
Crashes pc, video and audio go out of sync and frames roll when scene changes
This sounds like your power supply is not powerful enough to provide all of the power required for the boards you have added. If the system crashes when you launch a graphics intensive program, your power supply does not have enough reserve capacity. The Pinnacle Graphics cards require additional video cards. Depending on the card used, it can draw as much as 120 watts when first accessed and more than 50 watts when running. You should check the specifications on your power supply. It probably needs replacing if you are going to continue to use the Pinnacle Graphics Card.
Nov 25, 2009 | Pinnacle Computers & Internet
Graphics card help
> nvidia 9600gt oc graphics card requirements : found at http://www.bfgtech.com/bfgr96512gtoce.aspx
Microsoft Windows Vista -or- Windows XP
> CD or DVD-ROM drive > 100MB of available hard disk drive space for basic driver installation > 425W PCI Express-compliant system power supply with a combined 12V current rating of 28A or more (Minimum system power requirement based on a standard PC configured with an Intel® Core™2 Extreme X6800 processor) > PCI Express-compliant motherboard with one vacant PCI Express x16 slot. > One 6-pin PCI Express supplementary power connector -or- Two 4-pin Molex supplementary power connectors
> 512 MB of system memory
http://www.directron.com/slireadymb.html heres a list of SLI ready motherboards. dont gotta use this site to buy it just giving you and idea of whats out there for you.
Seems from what i gathered that as long as its an SLI ready motherboard with a open 16x PCI-E compliant slot and of course its gotta fit your tower. Find out the form factor of the tower then also make sure that it fits the correct type of ram that you have and prosesser. Then u should be good to go!
May 13, 2008 | Graphics BV200 BizView 128MB (128 MB) PCI...
Supply voltage issue...
the x1650 card requires extra amperage, not extra voltage. It runs on the same 12 volts as the rest of the computer. The issue is that if you have an underpowered power supply, of if you have a lot of other devices hooked up, you may need a better power supply to provide enough wattage to the card. As long as you have at least a 400w power supply, I would expect you to be alright.
Feb 13, 2008 | ATI RADEON X1650 Graphic Card
6 pin power supply
Some cards do not come with the connector... You can stil use it...
Jan 12, 2008 | ECS RS400-A (V1.0) Motherboard
X1650 xt agp installation problem
check and see if your pc has the recommended power requirements, a lot of the generic power supply's can't support anywhere near the posted wattage. A good power supply is very heavy with big heat sinks. Also check and make sure that the graphics card does not require any extra power connectors. A lot of the newer card require you to either plug in a pci-e power connector, molex plug, or floppy drive power cable.
Oct 02, 2007 | ATI RADEON X1650 Xt, (256 MB) Graphic...
Nvidia GeForce 6600 Graphic Card Logo
109 people viewed this question
Top Nvidia Computers & Internet Experts
David
David
Alun Cox
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
