Control circuit board for carrier a/c unit xcb 183e
This an in the wall unit, 18,000btu's
  • camjoe Sep 22, 2008
    the blower fan will not turn off. No cool air flowing or heat.
  • 1,420 Answers
You are missing some numbers. It is probably a KCB_ _ _ _ _ _ .
Get back to us with all the numbers and letters of the unit and we can get you a part number for the circuit board if that is what you are looking for.
Posted on Jun 12, 2008
We have a Carrier A/C, Model# 2397E15183 (INSIDE) about 12 hours ago (I believe it is a fan) started making a kind of grinding noise when it starts up and when it cycles off, this is located at the bottom portion of the unit. It is cooling well and the outside unit works fine.
Help!
Posted on Jul 15, 2008
FAN NOT BLOWING ON INSIDE UNIT, CARRIER FX4CN042T00AAAA LAST TIME IT WAS SOMETHING ON A CONTROL BOAQRD THAT HAD A RED LIGHT ON IT, QUESTION WHERE IS THAT LOCATED?
If your outdoor unit has a control board/circuit board, it will located at the outdoor units electrical panel where the line voltage electrical whip goes into the unit. Should be 2 screws that hold the panel/cover on. Turn off power, remove panel, and board should be visible.
Mar 30, 2017 | Carrier Heating & Cooling
I need to find a control circuit board for this Carrier aircon. Any ideas?
You need the model number and serial number of your unit.Then call or go to your local Carrier dealer or the local appliance parts house.
They should be able to help you.
Nov 09, 2015 | Carrier Heating & Cooling
Infinity system. Why is the wall thermostat display blank?
Either an open control fuse at the circuit board, a fault at the circuit board, wiring to the tstat or fault at tstat.
Jul 09, 2015 | Carrier Heating & Cooling
After a thunder storm my roof mounted Carrier cooling/heating unit stopped working and now does nothing. Changed the time delay fuses and checked the circuit breakers and they seem fine. Is there a reset...
You may have a circuit board problem. Make sure you have power to the unit first. If you can, get on the roof take the access panel off to the electrical components. Most carrier circ boards have a flashing light display on the board itself. On the back of the panel you just took off should be a kiosk that tells you what the flashing means. If the light is dead, no color but you are sure there is power to the unit, the board is bad or there could be a fuse blown on the board. Most circ board fuses are a small 3 or 5 amp blade fuse mounted right on the circ board. I have seen many a carrier board burn out because of lightning. I hope this is not the case for you, as carrier boards are just a little expensive. Hope this helps you get some air back. Mark
Aug 01, 2011 | Heating & Cooling
Unable to switch on. Have checked safety switch and fuse on home circuit board - OK Power on outside unit on and OK Remote control has new batteries and display OK Cleaned remote sensor panels on both...
as per the problem which you mentioned it clearly indicates that problem is with the switch in the wall unit.but you mentioned that you checked the switch and it is OK.
this means that the problem is with the main circuit control board of the wall unit.on that board the component is got blow-ned out or any of the component is got loose.you will have to check out with meter .if it looks looks then component needs re soldering but if its faulty or blow-ned out then that component needs replacement.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 31, 2009 | Heating & Cooling
HAD Carrier Digital unit, did not like, purchased Hunter, which I could not get to work Now I have extra colored wires hanging from the wall that came off the carrier that I did not tag.
Put the carrier unit back on the wall and connect the colored wires to the designated terminals.
R-Red, G-green(fan), Y- yellow and so on until they are all reconnected.
Manufacturers controls are designed to operate their units and sometime have more control options that require the extra wire you experienced with the off brand unit you purchased. Take it back and get the instruction manual out for the Carrier unit and learn to like it. If you have aZone System it is the only cotrol that will work with your system.
Oct 23, 2009 | Heating & Cooling
Wall ac will not turn off
Yes it sounds to me like you have found the problem and I do recommend www.appliance411.com. They may not have the part you're looking for on the site but they might be able to link you to the most inexpensive parts available with the exception of used parts. Hope this helps, good luck!
Sep 02, 2009 | Carrier XCB121E Air Conditioner
I have a Carrier 38tra048340 ac 4 ton unit outside, heater in attic. Thermostat is Totaline P374-1100. Power went out than back on after a few hours due to vehicle crashing into power pole. AC was running...
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Jun 23, 2008 | Carrier Heating & Cooling
Unit shuts down
The E4 error in display its mean the wire sensor connector to thermostat is loose pls fix , or have a problem in PCB Board on thermostat, pls go to the nearest repairman to repair that.
Thank you,have a nice day
Edgz
Jan 22, 2008 | ACE -Air 18,000BTU Heat Pump A/C Free DVD...
Heating & Cooling Logo
862 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
