Question about Philips Office Equipment & Supplies
My philips hfc 171 wont pick up fax when sent it ring ring until goes to message please help how to set up
Hit it with a hammer
Posted on Jun 22, 2008
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Need to delay fax pick up time
Please follow the steps below to configure the Pick-up On setting on your Lexmark X6650 printer:
  1. From the printer operator panel, press the Setup button.
  2. Go to Fax Setup.
  3. Go to Ringing and Answering.
  4. Go to Pick up on.
  5. Select your preferred number of rings before your fax picks up the message. Press OK to save the setting.
I hope this helps.
Should you still need assistance. please leave a comment to my response and I'll get back to you. Thanks.
Oct 19, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
How do I lessen the number of rings when receiving a fax?
Check On your Manual for Ring setting or Press Menu Setup on your Fax Check for phone setting and set our ring setting
Sep 29, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Can't receive fax. MP530is set on DRPD. Phone
DR is for distinctive ring, do you actually have distinctive ring from your phone company? Have you set the matching pattern into the Canon? It will only answer when it is sent the proper ring, unless you turn off distinctive ring.
Apr 20, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Fax feature
You have to set the printer to pickup 2 rings higher than your answering machine. If the answering machine picks up on 4 the printer should pick up on 6.
I believe the menu should be Setup button - down arrow key until you see basic fax setup and press ok - down arrow key until you see rings to answer and press ok - change to 2 higher than answering machine.
Now you should receive faxes and calls!
Jan 05, 2009 | HP OfficeJet 7310 All-In-One InkJet...
The fax picks up every call
Most fax machines are set-up to pick up all calls. There isn't a way to know you are receiving a voice call until the fax picks up and doesn't hear the tracer signal that kills our human ears.
You could change the number of rings it takes the fax machine to pickup the call. If you set it to the max, you would have plenty of time to pick-up. this option is normally part of the settings on the machine itself.
The only other options are to unplug the fax when you aren't expecting to receive a message, or get a dedicated fax line. It depends on how much you use the fax.
Hope this helps! Please don't forget to rate the answer!
Jan 02, 2009 | Lexmark X7170 All-In-One InkJet Printer
Fax pick up
Greetings Nana,
I believe that you can specify how many rings should occur before your Kodak 5500 Ai Printer automatically answers an incoming call (default = 4).
If you have a dedicated fax line, set the Rings to Answer to 1 or 2.  If you have a shared line for voice/modem and fax, set the Rings to answer to 3, 4, or 5. This setting only applies if Answering Machine Mode is set to OFF.
When the Answering Machine mode is disabled, Rings to Answer applies and your AiO printer answers the call. When your AiO printer detects a fax tone, it receives the fax. When a voice call is received (no fax tone), the call is ignored.
1 Press Menu to display the main menu. 2 Press scroll down until Fax Settings is displayed. 3 Press OK to display the Adjust Fax Settings menu. 4 Press scroll down until Rings to Answer is selected. 5 Press right or left arrow to change the number of rings.
Give it a try, Nana, but let Kodak know if you need additional help. They will be there for you.
Ron Baird the friendly Kodak guy
Sep 28, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Sending Faxes
When the last page of your document has been sent successfully, the machine beeps and returns to Standby mode. When something goes wrong while sending your fax, an error message appears on the display. If you receive an error message, press Stop/Clear to clear the message and try to send the document again. You can set your machine to print a confirmation report automatically each time sending a fax is completed. If you get the error message write it down it should always supply an error message if the fax did not go through.
Jul 25, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Epson Aculaser CX11NF won't receive faxes
Change your incoming mode from "autoswitching" to "TAM" (TAM is short for telephone answering machine" Press the "Setup" button on the control panel Use down arrow twice to select "FAX SETTINGS" Press the right arrow once The FAX SETTINGS menu appears Press the down arrow twice to select RECEPTION SETTINGS Press the right arrow once Press the down arrow unit INCOMING MODE appears in display Press the right arrow once Press the down arrow until TAM appears in display Press the right arrow once. That should do it for you If I got lost somewhere, it is in your Operator's manual - look in the index for TAM Hope it helped Ed
May 22, 2007 | Epson ACULASER CX11NF All-In-One Printer
Cannot recieve faxes
I just spoke with customer service live chat.
-press the "Fax Mode" button
-press the menu button
-The Fax menu screen will be displayed
-press down arrow button 5 times until the screen displays "Ringing and Answering."
-press the select button
-the display will show the "Ringing and Answering menu
-press down arrow button 4 times untip "Pick-up On?" is highlighted
-press the right arrow button 2 times until the screen displays "1st ring"
-press the "select" button and now "1st ring" will be set as the default.
Apr 01, 2007 | Lexmark X8350 Print, Scan, Copy and Fax...
102 people viewed this question
Top Philips Office Equipment & Supplies Experts
matt martin
matt martin
Starnley Johnwells
Starnley Johnwells
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
