Samsung SL201 Digital Camera Logo
Posted on Oct 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Card locked - Samsung SL201 Digital Camera
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Samsung Master 102,366 Answers
  • Posted on Oct 31, 2010
Samsung Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443379
Points
622693
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
My VPC-E760 keeps saying card is locked but the sd card is not locked
For the card locked, make sure that you are using a 2GB or smaller card. The E760 can not use 4GB or larger SDHC cards. 2GB cards can still be purchased on Amazon if your local store no longer carries them. If you are using 2GB, then here are some more tips for card locked.
For the "lens error", see this article for tips and steps that might help you repair it.
The memory was lock. but i want to unlock it
id1102_e3sdhc.gifSOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
NOTE: If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
15helpful
2answers
How do you unlock camera card it says card locked
Hi. Remove the card. On the side of the card is a small sliding lock. That's it. J.
Jul 12, 2010 • HP Cameras
5helpful
Cannon IXUS 40.Saying, Card Locked.How do you unlock it?
In case it uses the SD card, then there is a lock feature in the card. You will need to unlock the card so that it becomes read/write enabled. In lock position, it is read only, so you can read the files from it but cannot create any more files.
Most SD cards have a switch on the edge of one side of the card. Sliding it up or down will unlock or lock the card. When the card is locked, you will not be able to transfer any audio tracks. Nor will you be able to play any copy protected files. We recommend you always keep the card unlocked.
sd%20card%20lock%20slider.jpgNOTE: We have found that on some cards, if the slider is even halfway towards the lock position, the card will be locked. Make sure that the slider is all the way to the UN-locked position.
1helpful
Whenever take picture 'memory card locked' message on the display
18helpful
3answers
Memory card locked
I had the same problem - just put the lock button of the card to the lock position and than again to the unlock position
14helpful
2answers
Memory card locked
Take the card out. On the left side of the card is a tiny white switch. Reverse the position.
CARD LOCKED
try puting the lock thing onto Lock. it worked for me
Memory card locked
I noticed that this camera does not work well with cheaper memory cards. The only brand that works without fail is the SanDisk brand.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
