Got a Megane Scenic 1.6 mpi manual, engine cranks but won't fire. No noid signal at injectors, no sparks, got ok resistance at rpm sensor & continuity to ecu from sensor and from injectors. Immobiliser light goes out. MODIS code reader shows no fault codes but says i've only got 8 volts and no fuel pump running. Car hasn't ran for some time & has had front end repairs. Found fuses missing from box at n/s/f wing and there is only one (brown) relay in there but space and terminals for another. Earths on o/s of engine seem ok & tight. Any suggestions??
Sounds like your taking too long to put the key in the Ignition and turning.If this happens, just press the button on ignition key to lock the door then press again to unlock then put key into ignition and turn to start! If this doesn't work then it might be something more serious than that!
Hi
Well, no noid signal and no spark says to me that the crank sensor is at fault.
Does the check engine light come on when you turn on the igntion? If not then the ECU is not waking up.
Regards
Geordie
Renault Scenic 2001 randomly won't start, engine turns over does not fire, rest for several minits it fires. Occasionally cuts out on tick over or slow running, but does restart straight away, no difference noticed on panel lights etc help
I have a 2003 1.6 Scenic Megane that has recently been losing power while I'm driving. Have to pull over and turn motor off then start sometimes have to so this many times. The electrical fault light was coming on but when I took it to mechanic he put diagnostic tool on but no fault code showed up. This happened on and off for months now there is no electrical fault light coming on but there is sometimes no power when driving and it has just started to not turn over every time I start the car it takes several tries before the engine starts up. Can anyone help?
