Question about Continental Manufacturing Company 2RFSSHD Stainless Steel Commercial Refrigerator
Continental refrigerator where is the thermostat to turn the temperature down?
  • carli reid Dec 21, 2011
    inside next to the freezer
  • 828 Answers
Some units have the thermostat located on the evaporator cover (cooling coil). There will be a dimple or some other mark at the set point. These temperature controls cause a cycle defrost. Cooling coil temperature must warm up to above freezing before the next cooling cycle starts.
Posted on Jun 11, 2008
I have Mod. # RT21LMXKQ. There is only one thermostat control. How do I regulate the temperature in the refridgerator and freezer?
Walter,
Usually the thermostat control knob is in the refrigerator compartment, and the knob in the freezer controls how much cold air is moved past the damper down into the refrigerator area. All of you cooling is generated in the freezer section and the fan forces is downward. Your thermostat usually has a bulb that senses the temperature that turns the compressor on and off. The factory settings are in the middle of the dial on both areas. Hope this helps!
Aug 05, 2015 | Roper Refrigerators
Temperature control in fridge is turned all the way down but still too cold-25*, freezer=10*. What can i do? Amana SZD27ME side by side
Turning down the dial is not recommended as it does not turn the temperature down. Please return it the factory setting. If your temperature is too cold in the fridge, it may be the timer or thermostat. If it its in the freezer, it's the thermostat. If it both, you have a bigger problem, such as the compressor may be malfunctioning.
Jan 13, 2015 | Amana Refrigerators
How do test the thermostat on
Hi Walter, The fact that the unit is freezing when turned fully down suggests to me that you need a new thermostat as this is the switch that controls the temperature.
Oct 29, 2014 | Refrigerators
My Lincoln continental starts cold fine but when it gets hot or normal running temp it starts to loose power and feels like the tranny is slipping. When I turn it of and start it back up I have to give it...
SOUND LIKE YOU HAVE A TEMPERATURE PROBLEM, HOOK UP SCANNER AND CHE THE TEMPERATURE ON THE ENGINE, DOES IT GET HOT QUICK, LIKE A CLOSE THERMOSTAT, IS IT LOW ON FLUID, DOES THE TEMPERATURE SENSOR READ OVER 200 WHEN WORM, DO YOU SEE THE TEMPERATURE GO BACK DOWN TO 15 OR LESS, ES TEMPERATURE GOES UP, LESS AND LESS GAS GOES INTO THE ENGINE IS INJECTOR SENS LESS AND LESS FUEL, THE TEMP SHOULD BE 180 TO 210 OVER THIS MEANS THE THERMOSTAT IS CLOSED OR THE WATER PUMP IS NOT CIRCULATING ANY COOLANT, BELOW 180 MEANS THE THERMOSTAT IS ALWAYS OPEN.
Jul 28, 2014 | Cars & Trucks
I have a Kenmore 17 cu. ft. refrigerator. Model 67741 series.I keep it in the garage mainly for liquids Most everything in the refrigerator freezes. I have turned the dials down to no avail. What do you...
If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly. This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35 and 42 degrees. Here are some things to try: If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf. If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper.
Aug 21, 2011 | Kenmore Top Freezer Refrigerator
Having trouble with my 1997 lincoln continental i changed the radiator thermostat and the water pump and it still over heating please help
Have you burped the system? If air gets trapped it can prevent the thermostat from opening and make your engine overheat. To get the air out, start with a cold engine, turn the heat on vent or floor only and run full blast, run the engine with the radiator cap off until it gets to operating temperature. Keep an eye on the coolant level and add as needed until it doesn't drop in level for five minutes. Some cars may require removal of the thermostat so you can drill a small hole in it to allow air to escape from the engine side of the thermostat. Keep any eye on the temperature gauge to make sure you don't over heat it while trying to burp it.
Nov 17, 2010 | 1997 Lincoln Continental
Runs constantly seems like it never shuts down our power bill is soaring
Hello there:
The refrigerator never cycles off The thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired. If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system, in which case you should contact a qualified appliance repair technician.
Jul 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My Haier compact refrigerator won't turn on
A new thermostat is required. When you turned it down you probably broke the contact and will not re-connect. Be careful installing the new one the fine tube contains gas which is temperature sensitive. do kink or break it.
Apr 17, 2010 | Dometic WA3210 Compact Refrigerator
Freezer Freezes Refrigerator Barely gets cold
Hello there:
Here is a few things to check to make sure the referigerator is working properly.
The first thing to check is the overall internal refrigerator temperature (see the Appliance Accessories section for a refrigerator/freezer thermometer). The proper temperature should be between 35 and 42 degrees. Here are some things to try: If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly. If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf. If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. The refrigerator never cycles off The thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired. If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system,
Apr 14, 2010 | KitchenAid Architect 24.5 Cu. Ft....
Refridgerator is freezing everything
This is likely a thermostat failure. The thermostat is no longer shutting down the compressor or sensing the temperature wrong. The thermostat is a module inside most modern refrigerators and is a fairly easy fix except for the cramped quarters. You can order the thermostat from an appliance repair store. I suggest getting the service manual while you are at it if you have no experience taking a fridge apart.
Do not damage or bend the sensing tube sharply at any time. Be gentle!
Mar 22, 2010 | Amana Refrigerators
Continental Manufacturing Company 2RFSSHD Stainless Steel Commercial Refrigerator Logo
116 people viewed this question
Top Continental Manufacturing Company Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Continental Manufacturing Company Refrigerator Expert? Answer questions, earn points and help others
