Question about Miele W865 Front Load Washer
Maximum load what is the maximum dry load (in Kgs) that this washer will take please? does anyone know?
I solved my problem by choosing a different washing machine to buy
Posted on Jun 12, 2008
What is the tow bar down load of a Jayco Penguin please? Buying a new car and need to know please.
it is not the down weight of the van that is critical but the ball weight capacity for the vehicle
the down weight can be lessened by the use of load levelers or sway bars
most ball weights are 150 kgs to 350 kgs depending on the vehicle being used
before you buy the car ask the salesman or read it in the owners manual for the car
Feb 17, 2017 | Cars & Trucks
OK I do have Towing capabilities for my Captiva 7 LTZ Diesel. The caravan is rated at 1750 kgs loaded. Question- What is the towing capacity of a Captiva 7 Diesel
carpoint.com.au suggests a tow limit of 1700 kgs with a max ball weight of 170 kg
if it is a 2.2 L diesel it is less than a 3.2 L petrol which is 2000 kgs
in your configuration you will need anti-sway bars or load levelers to get the ball weight down to the 170 kgs
then if you load the van for touring it will be well over the specs for the vehicle
the towing capacity should be on the plate inside a front door pillar along with tyre sizes and pressures
Jan 19, 2017 | Cars & Trucks
What is the tongue weight on a 2001 mazda tribute towing package
most tongue weights are maximum 250 kgs (500 lbs )
use load lever bars to easy the tongue weight to that setting
If the weight exceeds the max then you should have load levers attach to add stability to the towed vehicle
Nov 02, 2015 | 2001 Mazda Tribute
Is Daewoo DWCLD-1213 a washer and dryer? Does it dry clothes well?
Yes. But be aware it washes up to 9 kgs (20 lbs) but only dries up to 7 kgs (15.5 lbs)
Aug 26, 2015 | Daewoo Washing Machines
What is the max load for an indesit 1234T washing machine please x
  • From the manual
    Maximum dry laundry
    load
    heavy fabrics
    maximum 5 kg
    delicate fabrics
    maximum 2 kg
    pure new wool
    maximum 1 kg
    mixed loads
    maximum 2,5 kg
    How heavy is your
    laundry?
    1 sheet 400-500 g
    1 pillow case 150-200 g
    1 table cloth 400-500 g
    1 bathrobe 900-1200 g
    1 bathroom towel150-250 g
Sep 14, 2014 | Indesit W 123 Front Load Washer
When there is a large load of clothes in the washer my washer does not spin fast enough to get the water out of my clothes, what is wrong with my washer?
You don't have to fill too much the washer, leave 1/4 of the cylinder free (if it's a front load washer) or check the maximum level for the top-load washer.
Be careful not to compress the clothes.
The weight that the washer can manage is the weight of the WET clothes.
More technically: the washer need to balance the drum before to spin-dry and for this it needs some free room in the drum. There is a sensor that check that there isn't too much vibrations during the spin-dry, otherwise it stops!
Sep 12, 2013 | Washing Machines
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Not drying clothes still getting warm and turning but despite leaving it for hours the clothes never become dry just warm and damp
sounds like your clothes are not spun dry enough try spinning on maximum speed alternatively check your water pump is not partially blocked maybe you need to clean filter let me know how you went
Nov 12, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Machine runs, but clothing won't dry
It sounds like your heating element is shot. The elements on this machine are very sensitive and if you use too much cleaning fluid the part will wear down after a while. You will need to get the part replaced (yuck) and start to use a little less washer fluid. Please let me know about your experience with the company (danfrogel@yahoo.com)
Sep 16, 2006 | Malber WD1000 Front Load Washer/Dryer
Miele W865 Front Load Washer Logo
78 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
