Question about George Foreman G5 Indoor Grill
Grill buzzing hi my G/F grill gr30vttsil model no 10099, has been working fine until today when switched on and the lid lowered it is making a loud buzzing noise. This stops when the lid is raised, the plates still heat up. Is this a sign it unsafe to use & needs either new parts or to be replaced. regards
  • flass harry Aug 11, 2008
    thank you for the information will investigate
  • 105 Answers
No, a buzzing noise merely means that something is vibrating from the magnetic field that is created when power flows through the heating elements. As long as nothing is obviously loose, the grill is safe to use.
Posted on Aug 11, 2008
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
I am searching for a george foreman grill manual GR30VTTSIL
Unfortunately that model's manual is not available, but this is a very similar model and the instructions are virtually the same..
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
http://dl.owneriq.net/1/154cb6ac-2cad-4f32-92d7-bb79a414db76.pdf
Oct 15, 2010 | Microwave Ovens
Series 90 with loud buzzing/grinding noise, won't spin
It could have gone out of balance. See if the drum looks off center and center it if necessary. Turn it off and back on to reset the switch. If that doesn't work, try pressing on the lid either 2/3 of the way back on the right or all the way back on the left (depends on the model -- try both) and see if it starts. If it does, I would suspect the lid switch.
Jul 21, 2010 | Kenmore Washing Machines
Loud buzzing sound. warm fridge and freezer
Could not find info for the model listed could it be PFS22SBASS...any way the most common reason for your issue is the main motherboard part #WR55X10942
prices vary $180 - $200. The circuit that operates the compressor is most likely at fault. Most boards are located at rear of unit lower right, it controls all refer functions. Not hard to instal,l but due to the cost most electrical parts bought are not returnable.
Ric
Mar 09, 2010 | GE PFS22SBSSS Stainless Steel French Door...
Whirlpool cabrio-buzzing noise when water runs
i think the problem that you have is one of the electric coils from the entrance valve from water. Check if there the vibration comes from there.
Oct 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Dacor DMT2420s when started makes a loud buzzing sound
The fan could have an obstuction. I have heard of tech sheets getting into the fan and causing a vibration and vibrating sound.
May 12, 2009 | Dacor DMT2420SS Microwave Oven
Whirlpool LSR model Washing machine
The lid switch on your model is located by the left lid hinge under the cabinet. It is activated by a rod on the left lid hinge. If you open and close the lid, you should hear a clicking sound as the switch is activated. If you can't hear the switch, sometimes bending the rod on the lid hinge will correct most contact problems. I haven't seen many of these type lid switches go bad. Its almost always been a simple adjustment to correct a contact issue.
Now, if you are sure you switch is good, the loud hum sounds like you have a drive motor seized up. Try removing the motor to see if it will free spin. The following link explains how:
http://www.fixya.com/support/r599953-replacing_drive_motor_kenmore_or
The motor comes out fairly easily if you follow the steps in the link provided. This will make the motor more accessible to you. If the motor will free spin, check the motor windings by taking resistance checks to be sure. There should be a wiring diagram located inside the operator console.
Your motor also has a motor start switch. If the motor and windings check good, you may have a defective start switch. I apologize for not having definite solutions here, but I'm trying to be as thorough as possible. Its often hard to determine a cause based on some symptoms, as there could be several possiblities.
If you go to searspartsdirect.com and type in your model number, there's an excellent exploded view diagram of the drive components under the "Brake/Clutch/Gearcase/Motor and Pump" heading. The drive motor and switch are listed as items 19 and 20. The lid switch is located under the "Top and Cabinet Parts" heading as item number 11.
I hope some of this information is helpful to you. Let me know if I can be of further assistance to you.
Sep 30, 2008 | Whirlpool LSR5132PQ Top Load Washer
Ge microwave - making noise
I have a GE counter top microwave oven. When the oven starts cooking (the magnetron turns on) the oven makes a harsh buzzing noise. What is wrong and what should be done?
Mar 07, 2008 | Microwave Ovens
George Foreman G5 Indoor Grill Logo
322 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
