Question about Refrigerators
Side by side Sub Zero not cold enough.
Older side by side refrigerator. Freezer side still makes and keeps ice but ice cream is "soft". Frig side is only "ok"--milk is not very cold and tends to sour too soon. freezer at 10 degrees and frige at 58 not cold enough. have cleaned condessor coil works alittle better but still not cold enough.
  • 828 Answers
How old is "OLDER" ? If there is no frost buildup on the back wall of the freezer you could have one of two problems. On older units the compressor wears out with years of service and no longer pumps efficiently. Or it could possibly be low on refrigerant charge. ether one of these two problems is a sign that is time to update to new unit.
If you have frost buildup on the back wall of the freezer section you then would have a problem in the defrost circuit attributed to the timer, defrost heaters or defrost thermostat.
Posted on Jun 11, 2008
I have a 12 year old sub zero 590 side by side. The freezer is not working well.ice is fine but ice cream is very soft. Meats and others are not so hard either.
Jai,
If the ice is still frozen after any time the temp is below 32. But thats not cold enough as you know. Target temp in such a freezer is between +10 to 0 F inwhich ice cream is good and firm. BTW many restaurants and food pro's set and judge the freezer temp by the firmness of ice cream! A twelve year old Sub Z should not be having such problems and causes could be numerous. Lets talk about what you can do. This is a built in unit correct? Ok, get your step ladder and remove the cover above the doors and look for a dirty coil, a failed fan, or both. If the coil is dirty enough to restrict air flow or fan not blowing this IS a problem! One that will cause such problems and is my bet to whats going on.
Oct 13, 2013 | Refrigerators
I have an Amana side by side frig and the freezer is not keeping ice cream cold. The refrigerator side seems fine. The freezer side is set to 7 but it no longer clicks like it used to when you turn the...
If you do not have guages (freon) and have a licens to proforme this type of work you will need to have someone qualified in this area to varify.You can call sears home repair @ 800 469-4663
Aug 05, 2010 | Amana ARS2464B Side by Side Refrigerator
Hi, I got no Ice in the freezer, and the Ice Cream is not hard
the higher the # the colder the frig should be . / if ice cream is not hard the freezer is not cold ennogh . so clean the coiles and ck the two fans . also look in back of freezer side for ice build up there should not be any frost on back wall . if so you've found the problem . which is a defros problem .. mm
Jul 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice cream in freezer of our side by side refrigerator is soft
Try cleaning the condenser coil. It will be under or on the back of your frig. Use a vacuum cleaner attachment. Good luck
Sep 08, 2009 | GE GTS22KBP Top Freezer Refrigerator
I have a GE side by side refrigerator GSH22JST and frig is cold but freezer is not cold enough (soft ice cream)...heavy frost is building up on bottom half of evaporator. I can force defrost mode through...
Okay,
What is your Freezer temp rating?
Did you check the refrigerant PSI rating?
Is your condenser restricted?
Let try adjust refrigerator to less cold and adjust more cold for freezer. and see what your temp rating.
nguyen@ite.net
Jun 09, 2009 | Refrigerators
Freezer section not cold enough/fridge ok
sounds as if you might have a compressor related sealed system problem, youll have 5 year war on such an issue from the manufacture
Oct 29, 2008 | Maytag MSD2758GEW
Sub zero
Is ice on the back cover on the left side? if it is you have a leak in the evaporator... if its under 12 yrs old call an authorized sub zero service it will be covered
Jul 30, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Freezer not cold enough to freeze items solid
Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
Jan 28, 2008 | Frigidaire GLRS264ZA Side by Side...
Refrigerators Logo
289 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
