Question about LG Goldstar GWHD5000 wall/window Air Conditioner
LG Goldstar GWHD5000 Starts only with Remote and Display buttons dont work
I have an LG Goldstar GWHD5000 that Starts only with the Remote and Display buttons dont work. when i push the display buttons for cool, time, on and off, etc, they dont work. I can only turn it on with the remote and have to shut it off by unplugging it.
    New Friend:
  • 102 Answers
Sounds like a bad switch or bad connections.  Recommend having a professional look at it.  Hope that helped.
Posted on Mar 11, 2009
Cooling part ig gone
No water is needed for this model, you can refer to user manual.
http://www.helpowl.com/manuals/lg-gwhd5000-owners-manual-6758147.pdf
Aug 21, 2013 | LG Goldstar GWHD5000 wall/window Air...
Do you have to add water to the air conditioner?
NO
if its an air conditioner not humidifier etc, then no!
it will create condensation which can mislead people into thinking it has a leak, this is normal. it is only moisture taken from the air we are cooling
cheers
Jul 05, 2010 | LG Goldstar GWHD5000 wall/window Air...
Air conditoner model gwhd5000 goldstar does not cool
Hi, first you will need to know, what type refrigerant,(freon) your a/c used, if you need to add freon, there's a leak in your a/c. you will have to find and repair leak, before you can charge/ add refrigerant(freon) . automobile a/c can be easily recharge (add) to system, but your window a/c unit, has the same principles but different approach, if you don't have experience, you will have to call mechanic, make sure you have a freon leak, before calling mechanic, plug a/c on let it work, put hands close to a/c, feel or check temperature of air blowing out from a/c, make sure compressor is working/running, fans could be working/ but compressor not, also put a/c thermostat to max, your model no. GWHD5000. means your unit is 5000 b.t.u, (british thermal unit) measurement of heat transfer, am wondering if a/c is to small for your space/room. making you think it needs freon, 5000. b.t.u. is for a small space,like a room 10' by 10' like a storage area or small bedroom, keep bedroom door/windows shut. measure you room/space/area , the bigger space/area needed to be cooled, has a chart, maybe you can find it on internet, any way a 10.000 or 12.000 b.t.u a/c is better buy, for normal room/space etc. so check compressor especially to make sure working, a/c could be to small for space/room, check it at night to see if it's colder. don't try to put gas/ freon yourself, could be very dangerous. but before calling mechanic, check those thing, mention before, could be your a/c are to small, for space/room etc. remember before attempting any repairs, disconnect power. good luck.
Aug 20, 2009 | LG Goldstar GWHD5000 wall/window Air...
GoldStar model GWHD5000
Make sure that the unit is properly mounted in the opening (I take it it's in a window) and that it is level or at least not tipping inward as in the outside being higher than the inside. If unsure about how to mount it properly, consult your owners manual. Your installation should be reasonably close to the illustrations.
Jul 13, 2009 | LG Goldstar GWHD5000 wall/window Air...
Condensation question
Yes there is a hole in the rear underneath.  Make sure that it is not plugged.  The ac needs to be cleaned every year for good workmanship.  Make sure that the ac is tilted back allittle so the water or condensation will drain.  Sometimes I've seen one where it was tilted towards the inside of the house and the fan would pickup some of the water and put a mist in the house which is not good.  If We can be anymore help let us know and thankyou1
Mar 11, 2009 | LG Goldstar GWHD5000 wall/window Air...
Goldstar room ac GWHD6500R
I read that its just simply cool with low fan on energy saver...on another site.
Aug 22, 2008 | LG Goldstar GWHD5000 wall/window Air...
YES. make sure the air grills on the sides of the unit can breath and not covered if the grills are covered u will have problems with the unit.
Jun 29, 2008 | LG Goldstar GWHD5000 wall/window Air...
Not getting cold anymore
Unit has probably lost its charge of refrigerant.
Check for warranty, or buy another one.
Usually they are not worth repairing, sorry
Jun 06, 2008 | LG Goldstar GWHD5000 wall/window Air...
LG Goldstar GWHD5000 wall/window Air Conditioner Logo
163 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
