Question about Panasonic GigaRange KX-TG5480S Cordless Phone (KXTG5480S)
Panasonic KX-TG5471 2-line 5.8 GHz w/remote handset-Can I purchase expansion handset?
Hi, I work from home and use the base unit with remote handset but would like to have a separate handset in another part of the house. Does Panasonic make a compatible expansion hand set or can I buy a third party compatible unit?
5 Suggested Answers
Noggin
  • 944 Answers
SOURCE: Hard reset of KX-TCD580 Base
Go to this link; http://panasonic.co.uk/customer-Support/download-centre.asp and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
Posted on Apr 01, 2007
mrfixit64857
  • 9 Answers
SOURCE: sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Posted on Jan 01, 2009
  • 512 Answers
SOURCE: Kx-tg1100 registration to anoter base
sorry, it seems that they have to come from the same model base. however, the procedure to reset handset numbers for the 1100 may work for you. there is a 15 digit number on the base unit. try to type that into the 1100 and see if that will register the 1100 to your old base.
Posted on Jan 09, 2009
  • 569 Answers
SOURCE: how to program handset to the base? Panasinic KX-T7730
I have uploaded the user manual for you.
Go here and download. This manual covers the 7730.
http://www.easy-share.com/1909338845/Panasonic KXT7700-User-Guide.pdf
Posted on Feb 19, 2010
  • 3 Answers
SOURCE: KX-TG4321 & KX-TG430B - Purchased separately, can't register handset to base
(Got this from a Panasonic Support Tech...Thanks Panasonic!) The following steps should help.... Resetting Handsets
Posted on Sep 23, 2010
Where can I get an instruction manual?
Panasonic kx-tga600b handset manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tga600b cordless extension handset manual. Panasonic kx ...Panasonic kx tga520 5.8 ghz fhss cordless expansion handset manual. Panasonic kx ... Panasonic kx tg6071 operating instructions manual pdf download. Panasonic... Need manual for kx tga600b so i can turn off voice mail dont need. Panasonic ...
Kx-tg6500 manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tg6500 operating instructions manual pdf download. Panasonic ...Panasonic kx tga650b cordless extension handset installation. Troubleshooting ...Panasonic kxtga651b dect 6.0 plus expansion handset black kx. Panasonic kx ...Can i register a kxtg6500 handset with a kxtg4500 base. Panasonic kx tg6502 ...
Panasonic KX-TGA650B ' Installation Manual - Page 3
Feb 09, 2016 | Panasonic KX-TGA650B (037988474806)...
Hi,How do I change the answer machine message?
The KX-TGA711 handset can be added to the KX-TGA7160 or KX-TGA7180 system. First, make sure that the answer system is ON. (Use the button on the base or the first few steps below.) For those base units, press the Menu/OK button on the handset. Use the Up/Down arrows to navigate to Answer System. Press the right arrow to enter the sub-menu. If the system is off, turn it on. (Answer On/Answer Off will be displayed on one line. Press the right arrow to access the item.) To record a new greeting, navigate to the line 'Record Greeting' and press the right arrow. Hold the handset about 20 cm away and speak clearly into the microphone. Press Menu/OK to stop recording. Press the Hangup/End to exit and save. A faster access route would be to press 7 and then 6 after accessing the answer system menu. The directions are on page 25 of the manual, which is available from Panasonic and here: http://www.home-phones.co.uk/assets/uploaded/documents/473_7160.pdf . You can do this as a remote operation if you have enabled the feature. Press 7 to record and 9 to stop recording.
I hope this helps.
Dec 14, 2015 | Panasonic KX TGA711 1Line Cordless...
How can i register my hanset. it says error.
Please use the below link to assist you with handset registration.
http://service.us.panasonic.com/OPERMANPDF/KXTG5621S.PDF#page=35
May 06, 2014 | Panasonic KX-TGA560 Cordless Expansion...
How do i sync my panasonic phones cordless kx-tga810
335 is the magic code when you want to remove a previous handset or base station registration!
Handset:
1 " (middle soft key) i L i #
2 Enter "335".
3 "Cancel Handset" i #
LThe numbers of all handsets
registered to the base unit are
displayed.
4 Select the handset(s) you want to
cancel, by pressing the desired handset
number. i #
5 "Yes" i # i {ih}
Base Station:
A handset can be registered to a maximum
of 4 base units. A handset can cancel a base
unit that it is registered to. This allows the
handset to "forget" the base unit.
1 " (middle soft key) i N i #
2 "Registration" i #
3 Enter "335".
4 "Cancel Base" i #
5 Select the base unit(s) you want to
cancel, by pressing the desired base unit
number. i #
6 "Yes" i # i {ih}
Dec 23, 2013 | Panasonic KX TGA810 1Line Cordless...
The base unit will not charge hand sets . I have cleaned the contacts on base unit as recommended. Please note the remote unit charges both handsets.
The problem is in the remote charger or batteries in each phone is the issue. If you are handy with a meter, "set it to DC volts" press down on the charging tabs, you should have at least 3.6V to 12V if it reads 0 the remote charger is defective.
May 26, 2011 | Panasonic KX-TGA560 Cordless Expansion...
It said base no power
Remove then replace the batteries from the hand set. You should now get dial tojo.
Oct 25, 2010 | Panasonic KX-TGA101S Cordless Handset
Dead handsets
i had the same problem with my KX-TGA650 and called repair out and they said it wasn't seating on the home base to charge, we'll see. i'm looking for a manual for this phone lost mine and cost prohibitive to order from panasonic. and download pdf is just too large.
go to website and it tells you that only a same model is able to be used with the base unit. hope this helps.
martha
angelml@sbcglobal.net
Jan 05, 2009 | Panasonic KX-TGA650 Cordless Expansion...
Sync a new handset to kx-tg5632 phone
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
indicator flashes.
minute.
3 Handset:
sounds.
4 {OFF}
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
Panasonic GigaRange KX-TG5480S Cordless Phone (KXTG5480S) Logo
61 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
