Carrier 38TXA030 not working
We have a Carrier 38TXA030 two zone central system. A few days ago after a power outage one of the zones failed to restart. Power to the thermostat is out but all breakers are on, both on the main panel and on the outside power switch. The other zone is working fine. Any ideas?
Thanks.
  • stumas Jun 12, 2008
    Already tried to reset by turning off main panel breakers and outdoor switch but alas, to no avail. Don't know if or where there are any micro fuses in our system. The thermostat power comes from the system itself, with no fuses visible.
    Scholar:
  • 54 Answers
That sounds like a very efficient system Gratz. You can try a reset by throwing the breakers off and back on and check all your micro fuses on boards and zone controllers. GL!
Posted on Jun 11, 2008
  • Wes Rackley Jun 12, 2008
    http://www.residential.carrier.com/produ...
    Heres carriers site you should be able to run down the info you need there :) you'll need your model numbers and you should be able to find all your manuals here for settings and fuse size and locations GL!
How do I set time zone? S/N: 502 16764PH.
Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there's nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet clock radio as follows: ZONE 1 - Atlantic Time ZONE 2 - Eastern Time (Default Setting) ZONE 3 - Central Time ZONE 4 - Mountain Time ZONE 5 - Pacific Time ZONE 6 - Yukon Time ZONE 7 To c h a n g e t h e d e f a u l t t i m e z o n e d i s p l a y, depress the TIME ZONE button. The number "2" will appear on the display indicating that the default zone is ZONE 2, Eastern Time. Hold theTIMEZONE button and then press either the or buttons your own time zone appears on the display, then release the buttons. The clock display will change to the correct time in the time zone you selected . The clock will always return to the correct time in the zone you selected after every power interruption. http://www.emersonradio.com/resources/owner_manuals/manual_1396274206.pdf
Apr 08, 2016 | Emerson Smart Set Alarm AM/FM Clock Radio...
Tip
Procedure For Setting Time Zones For Emerson Clock Radios
IMPORTANT: The first time you connect your new SmartSet® clock radio to
zone. If you live in the Eastern Time zone, there’s nothing else to do. Your
display to your own zone. You only do this one time and the SmartSet® will remember
interruption.
There are 7 time zones programmed into your SmartSet® clock radio as follows:
ZONE 1 — Atlantic Time
ZONE 2 — Eastern Time (Default Setting)
ZONE 3 — Central Time
ZONE 4 — Mountain Time
ZONE 5 — Pacific Time
ZONE 6 — Yukon Time
ZONE 7 — Hawaiian Time
To change the default time zone display, depress the Time Zone button.
The number “02” will appear on the display
Eastern Time
on Jun 12, 2009 | Emerson Smartset Clock Radio
Just moved in to new house with central air. Despite turning all 3 zone thermostats to off (ie no cool, no heat), there is still air being blown through vents throughout the house. (fan switches are also...
You should not have the blower fan running if all thermostats are set as you say. You either have a relay problem in the air handler or the zone system wiring or controller is defective.
Sep 01, 2011 | Honeywell Heating & Cooling
AVR-2803/983: Had recent 24hr Power Outage. When power restored, I receive no video/sound from TV thru COMCAST HD box, no video from CD but do get sound, lost partial use of Zone 2. Zone 2 works if I...
Extended power loss might lose memorized settings. Pretend the unit is brand new and verify all of them. No video from CD??? Really? Good luck with that.
Jul 16, 2011 | Denon AVR-2803 Receiver
Carrier Comfort zone 2 is flashing e1 after a storm/power outage
HEY THERE, DID YOU TRY POER CYCLING THE UNIT? TURN IT OFF AT THE BREAKER THEN BACK ON
SETH
Jun 27, 2009 | Carrier 38CKC060 Air Conditioner
Zoned system one zone not working
I hit the reset button on the main unit and that reset all the sensors. It was so easy but when I called Carrier's customer service line they told me there was nothing they could recommend. Not very good customer service. Avoid Carrier brand if possible.
Jan 22, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Changing Time Zone on Wind & Weather Atomic Clock
1. Press MODE to select the time with the day of week
display mode.
2. Select the time zone by pressing and holding the “ + ”
button for 3 seconds.
3. Keep holding until the desired time zone (Pacifi c,
Mountain, Central, or Eastern) is selected on the
display map
Jan 20, 2009 | SkyScan 86742 Digital Atomic Wall Clock
Time Zone Setting
Sorry it took so long to give you a answer to your problem. I hope this information help you with the problem. Thank you for using FixYa and have a nice day! Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time
Nov 04, 2008 | Emerson Smartset Clock Radio
Why won't it automatically set time?
Sorry it took so long to give you a answer for the problem.I hope this information help you with your problem.Thank you for using FixYa and have a nice day! Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time
Oct 21, 2008 | Emerson Smartset Clock Radio
Failure in comfort zone one
There is a capacitor connected to the motor on the compressor. If it fails, the motor won't start and the safety thermal cutoff will stop voltage at the motor terminals. There are fuses inside the power interrupt box on the side of the outside unit. One of them may have blown
May 09, 2017 | Amana Comfort Zone 18M33PCEH Air...
Heating & Cooling Logo
296 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
