Question about Samsung Cameras
My Samsung CX1L DSLR camera is telling me that there is no battery power (the flashing battery sign on the top display) even when I've put new batteries in. I'm guessing there's a bit of a dodgy connection somewhere, but could I sort this myself, or would I have to get it repaired somewhere?
  • diablogem Jun 11, 2008
    Sorry! I meant GX1L!
  • diablogem Jun 13, 2008
    Many thanks for the response! I will try these today and let you know how I get on!
    Problem Solver:
  • 13 Answers
First, try cleaning the battery contacts with an ink pen type eraser, not a pencil eraser, but one that is made to erase ink. These are a little gritty and usually white, not red rubber.
If this does not work, and you are sure they are NEW batteries, not just not used batteries, try to reset the camera to all original defaults.
If this fails, the camera may have a faulty internal connection, and need to be repaired or replaced.
One last thing to try, IF the camera will accept an external power supply, do you still get the no battery power?
If so, this is a sure sign it has an internal failure and needs to be serviced or replaced.
Posted on Jun 13, 2008
Nikon D90. blinking "clock" sign in the top LCD panel. Any advise?
Sounds like you may have a circuit failure. Possibly the phase switch but that is not the usual symptom. In any case this should be sent to Nikon as they stopped selling parts a year ago, and also you need their proprietary software to initialize a new board if it is replaced.
Jun 13, 2014 | Nikon DSLR D90 Digital Camera
Flashing 0% battery and won't turn on
I had the exact problem with the blinking top menu. I found that my memory card had gone bad. one i put in a fresh card the camera operated normally.
Aug 27, 2012 | Canon EOS 60D Digital Camera
I have a Sunpak pf30x flash (ETTL II for Canon) and a 550d Canon but the flash will not work. the flash works on my Canon Eos 300 film. Help
Many flashguns deigned for film cameras - even really expensive ones - will not work with DSLRs.
I have a perfectly good pentax gun that cost me almost £300. It is fanstastic on my TOTR Pentax SLR but will only blat at maximum power on my Pentax DSLR. I had to spend another almost £300 to buy the new gun that will work with all the bells and whistles on my DSLR.
It looks as though Canon work theirs the same way.
May 22, 2011 | Sunpak PF30X for Canon Flash
Have a new D3000, full battery. Camera will not turn on. Purchased a replacement battery still no power, HELP....
I`ve experienced the same problem as yours before,
it was caused by the main IC power supply
If the item is still in warranty condition,
You can claim the warranty from the store where you bought it
They will changed a new DSLR
Dec 25, 2010 | Nikon D3000 Digital Camera
My canon SX110 IS camera has recently started displaying 'battery is low' and flashing the red low battery sign even a few minutes after putting in brand new batteries. I have tried with several new sets...
I had the same problem with new batteries reporting as "low" and instant shut-off. After I found that it would stay on when plugged into USB, I suspected a firmware bug in the camera (I am a computer engineer). So I thought "how can I fool it?" I then found that it would stay on if you power it up with the rotary dial BETWEEN the video and manual ("M") setting -- in the "illegal" position. The after it's on, every mode works!
--Dan S.
Ithaca, NY
Oct 22, 2010 | Canon PowerShot SX110 IS Digital Camera
Nikon D90 Memory Card Access Blinking
It's a deadly common problem of D90. Fixation:Simply go to the DSLR repair shop and ask them to change the power circuit board of the camera. Will take $60-70 if the board available. Reason of issue:The power control IC get short and feedback the battery power to the battery causing the draining out and other problem like the top LCD back lamp turned ON after turning on the camera. Careful:To avoid this issue in future, after full charge of the battery, do not put it in the camera right then. Wait for the battery to cool down for 5-10 min and then put it in. With the full charge, the battery hold high ampere for a short time. It could damage the power distributor IC suddenly if you put it in the camera right after a full charge. Best, Leo>>from personal experience<<
Jun 14, 2009 | Nikon D90 Digital Camera with 18-105mm...
Canon A710
I have found that the camera is sensitive to battery power in that a slight fall off in voltage causes the problem. I came across a site, which I have not been able to find again, where it was stated that the contacts on the lid do not sit with sufficient pressure on the batteries to get a good contact. If you put the batteries in and look across the top, in my case, the battery +ve terminal is sitting slightly lower than the –ve battery terminal. To solve it, put a small piece of very thin plastic under the +ve contact on the lid so that it sits more proud. This has certainly improved my problem to the extent that this week the plastic fell out and the problem returned. Also I always use high capacity re-chargeable batteries. Hope this helps.
Jun 30, 2008 | Canon PowerShot A710 IS Digital Camera
Lens stuck open
i have just had the same problem. mine was stuck open, i gave the lens a slight twist and heard a bit of a crack. i switched it on again, now it is ok.
Apr 09, 2008 | Samsung Digimax S600 Digital Camera
Low battery indication
You have either a faulty charger, a faulty battery or a fault in your camera. I purchased 2 batteries for my Sony 505v and from new one of them kept flashing an empty battery sign right in the middle of the display. Actually it was fully charged but Sony batteries have a little circuit inside them which tell you how long the batteries will last. In my case I could continue to use the battery but put up with that flashing icon. I returned it to where I purchased it and it was replaced Immediately. Please ,next time give us a little more information as to what battery type it is and which camera it goes in. Some cameras can develop a natural short circuit over time. BMW
Jul 02, 2006 | Sony Cyber-Shot DSC-U10 Digital Camera
Cameras Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
