Question about Kitchen Appliances - Others
Problem with toaster
I bought this toaster in February - worked fine so I threw away the box & recpt - now it won't stay down when we put bread in it to toast - we have tried everything - very dissappointing!! It is a T80BC or TB0R, can't find the model # on the appliance.
Linda Hollingsworth
  • mdoirish Mar 08, 2009
    I have the same problem as the previous reviewer. When new the toaster would only stay down and in the toasting mode when it was plugged in. After less than one year, the toasting baskets will not stay down whether plugged in or not. Cleaning of crumbs did not make any difference. It seems to me that it may be electronic as a cancel button on the side will pop up the baskets when working properly. Model no. etc are located on the bottom of the unit.
    Michael O'Connor III
I have the same toaster. From time to time crumbs get into the contact for the relay that engages the toaster and keeps the handle down. You have to remove the cover, using a soft paintbrush, gently brush away all the crumbs for the contact and electronics. I even use a little rubbing alcohol to clean the contact. This has happen to me a few times. They should have put a cover over it.
Posted on Jun 06, 2013
  • 4 Answers
Did you try cleaning it? Crumbs in the works can work miracles - against you!
Posted on Jun 30, 2008
Russell Hobbs 18140 Toaster The bread carrier will not stay down during toasting. Insert two slices of bread into bread carrier and push down to lock. The right hand side carrier does not stay down. The...
Constant use can lead to crumbs clogging the path of the lever. Try opening up the bottom panel, by pulling on the metal tab to release the plate (and crumbs!) over a trash can. Also try flipping the toaster upside down and, very gently, shaking the crumbs out. if that doesn't work, you can try checking the toaster's browning dial. This might be too low to activate the heating coil. Try dialing it up, and pushing the lever down again. I hope this helps. You can check our post on Best ways to use a Toaster oven. Best ways to use toaster oven 2017 ultimate guide Kitchenutilitypro
Sep 28, 2017 | Kitchen Appliances - Others
Right side lights on all buttons won't stop flashing and bread 'holder' stays closed
Hi! Try to unplug it from the electrical grid and to clean it inside the place where the bread goes, maybe there's a piece of bread stuck in there. I hope this will work! Have a nice day!
Sep 02, 2011 | Breville BTA840XL 4-Slice Toaster
Russell hobbs toaster 9379 bread carriage handles won't stay down to toast
bought a new toaster I would like any account you have created for me to be deleted. thank you
Dec 22, 2009 | Russell Hobbs 9379 Classic 4-Slice Toaster
I have a pink two slicer kitchen aide Toaster. The button to pull down the bread to toast will not stay on. Where can I order/buy a new pink one? thanks kathie
Before tossing out the toaster, check on the inside of the toaster, you may have a wire bread closure in there that is blocking the lever.
I took my son's toaster apart when they replaced it, and found a bread closure inside it, blocking the lever. Anything small enough to fall inside could do this too. (The toaster works fine now, and I use it myself!)
Make sure you unplug the toaster first, you don't want to have a "shocking" experience.
Turn the toaster upside down and shake it a few times, over the kitchen sink, and then open and clean the "crumb" compartment.
Sorry to tell you this, but, your toaster is no longer available on the market, you might want to check a few thrift shops in your area...or you can check this link for another model that is pink and a KitchenAid.
Oct 13, 2009 | KitchenAid KTT261 Ultra Power Plus 2-Slice...
Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Aug 04, 2009 | Kitchen Appliances - Others
Bread will not stay down
Be sure the temp/time dial is not on zero.
Mar 11, 2009 | Russell Hobbs 9376 Classic 2-Slice Toaster
Digital Display no longer showing, lever won't stay down
jsullivan22 is right about the diode. I have this problem with my 24502, which is a dual version of this. There are 2 circuit boards in your unit one with the LED display on it and another one. The diode needing replacing is on the other board. it is in the center of the board, right next to a large (1/2W or 1W) 2K ohm resistor. The diode is probably part number 3ez24d5. Test it with the diode test on your DMM, if it is bad you will get 0V both directions (I think). Also if you measure it with the Ohm function it will probably measure less than an Ohm (check the zero on your DMM as many are not accurate down this low) You can probably replace it with a <a id="ctl00_ContentMain_CartGrid_grid_ctl02_ctl00_lnkManufacturerPartNumber" href="" style="font-weight: bold;">1N5934BG</a> or a <a id="ctl00_ContentMain_CartGrid_grid_ctl03_ctl00_lnkManufacturerPartNumber" href="" style="font-weight: bold;">1N5359BG</a> Mouser stocks both of these&nbsp; (currently). I haven\'t gotten my parts so I can\'t guarantee these will work, but I\'m pretty sure. I will try the latter first as I\'m hoping it\'s higher power rating will keep it from burning out again, although I will be buying several spares. <br><br>This is clearly a design issue with these toasters and one that could be easily corrected. Both circuit boards in my toaster are very toasty in the area of these diodes, although I\'m sure the fact that these boards are mounted very close to the heating elements doesn\'t help their longevity.<br><br>Hope this helps everyone.
Sep 27, 2008 | Hamilton Beach 22502 Digital 2-Slice...
Bread toaster doesnt work
It could be the slide button connections or loose wires. You would have to take it apart to try and figure it out. It should be under warranty, though. I don't know if the box is required. You'll have to ask Back to Basics about that.
Aug 29, 2008 | Back to Basics TEM-500 Egg & Muffin...
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
if u need instructions on how to use a goes:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
245 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
