Question about Wacom ET-45A STEEL Graphire2 (MAPET45ASTEEL)
'Lag' or Trailing Line
Hi there, i have got this Wacom from my Dad recently, it is an old tablet that he hasn't used in a long time. Now the tablet works fine, pressure sensitivity and clicking etc, but i have the issue where i can draw a line (in Photoshop CS3 and Sketchbook 2009) but there is lag where it looks like the tablet thinks the pen is still touching the tablet, and a very faint line will be drawn wherever i move the pen. Its like its trailing off very faintly at the end, even though the pen isn't touching the tablet! Any help would be great, i can also take some screen shots if you are not sure what i mean. Thanks
  • dmorita Jun 17, 2008
    Don't go out and buy a new tablet! It happens on Intuos 2 and 3 tablets as well. I thought it might be a thing with the older tablet and bought a new Intuos 3. It worked fine for a couple of months in Tiger on a Quad Core Mac, but when I went to Leopard on a new Dual Quad Core, it came back and won't go away no matter what settings I use. I wrote to Wacom but haven't heard back. Sorry this isn't a solution, but might save you from spending extra money.
  • Steven Gipson
    Steven Gipson Dec 16, 2008
    Same problem after one year of owning the Wacom Intuos 3. The lines trail, as if the tip is still touching the pad, even when it isn't. Does it in all applications.
I just did some more experimenting and it seems that if I replace the tip of the pen, it starts to react better, not great, but definitely better.
Again, I'm using an Intuos 3. On the Intuos 2 I was using, if I replaced the tip, it would improve, but I was going through tips every two months or so. That's why I bought the 3, thinking it would be better because I've never experienced this problem with my 3 at home (these problems are all happening at work). I'm not sure which tablet your have or if you have the spare tips that come with it, but that might be your solution.
Also, check your Wacom settings and make sure the "tip double click distance" is set to "Off". That should help a little.
Another forum post suggested not using the stylus stand or holder. It could...not sure that it actually does...damage the stylus tip so that it reacts as if pressure is being applied. My stylus at home is always in the stand and, since it does have this problem, makes me wonder if this is valid....but why chance it...different stands and different stylus.
Good luck and hope this helps!!!
Posted on Jun 17, 2008
  • dmorita Jun 24, 2008
    Finally got an email back from Wacom. Take the tip/nib out of your pen for 24 hours. If the problem persists, after letting it sit for that long, then the pen needs to be replaced.
I had the same problem ogf trailing lines. When the pen was off the tablet, it still drew a line as if it was in contact. Scrollbars were sticky too. It was the same across all applications. Than I remembered that when I first got the pen, there was a little play in the tip. I think the internals might have gummed up a bit over time as dust particles get in there. Using tweezers, I gently pulled the tip in and out a millimeter or so. Sort of loosened it up so it has a small amount of play. This seems to have fixed the problem. I will repost if the problem comes back.
i love my Wacom again!
Posted on Dec 16, 2008
Wacom Bamboo Fun Tablet-Mac. Yellow box pops up under pen cursor.
Your tablet is set under the handwriting setting. Go to system preferences and select ink under hardware. Then turn off handwriting recognition.
Jan 20, 2010 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
My wacom tablet pen is acting like a mouse...
go to the pen tablet program folder and start up pen tablet properties and there should be an option to use the pen as a pen or as a mouse. if this does not help then the pen may have some problems.
Nov 08, 2009 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Wacom tablet (Model ET-0405-U) Driver?
Wacom tablet drivers can be found at: Driver Update Software for XP Vista 7 8. Used it many times before. have a nice day
Oct 03, 2009 | Wacom Graphire Grape (ET0405UGRAPE)...
Odd Cursor Movement with Tablet Pen
hello there, take the batteries out of you maouse and see if the problem persists. also, it seems as if cells phone interfere with some models of mice.
Nov 20, 2008 | Wacom Bamboo Fun USB Tablet with Cordless...
Wacom tablet won't read pen
Hello there. Sorry to tell you but no. the graphire and intous pens are 2 different animals. one has 512 levels of sensitivity and the other has 1024 among other things. you have to get a new pen.
Nov 20, 2008 | Wacom intuos2 12x18 USB Tablet (507074)
Pen Tip Not Working
I had the same problem and called Wacom Customer Care at 360-896-9833... I was informed that the pen was defective/ broken and needs to be replaced. This can be caused by being dropped and such. I was told that i should keep the pen on the stand or a eyeglasses case when not in use.
If your tablet is under a year old, warranty will cover the cost of the pen with proof of purchase. Other than that, you will need to purchase a new pen (about $29.99 from Wacom & online).
Unfortunate, but great to know.
Jul 16, 2008 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Intuos3 tablet not functioning on entire screen area
why cant i use my wacom tablet as a regular mouse pad it allows me to go on line but not search?
Dec 26, 2007 | Wacom Intuos3 6X8 USB with Pen&Mouse [...
Serial to usb wacom tablet problem
I just got Vista and it killed my Intuos2 w/serial to usb also, but here's a half solution:
Download Wacom driver 4.78-6 http://www.wacom-europe.com/int/downloads/driver/driver.asp?lang=en. Make sure you remove any other Wacom drivers, tablet, and reboot. Install 4.78-6 driver and select serial port when the choice pops up. Plug in your tablet with the serial to usb adapter, wait a few seconds and click retry. Complete the install and reboot.
Your Wacom tracking should work now, but certain things might not work like pressure sensitivity and you'll get annoying error "reinstall driver" pop-ups.
I think you can aslo buy a PCI-serial card for your computer and skip the serial-usb adapter since Vista doesn't support the adapter for Wacom tablets.. but I'm not sure if there's a working Vista serial Wacom driver either.. or ever will be. The age of XP and Legacy support is at an end my friends.
Dec 03, 2007 | Wacom (PTZ930AC) Graphic Tablet
Wacom Graphire
Like you guys i have the same problem.
It's starting to bug me. One day its all great, the next the pressure sensitivity is gone and it just draws a hard line.
Sep 16, 2007 | Wacom Graphire4 4x5
Wacom ET-45A STEEL Graphire2 (MAPET45ASTEEL) Logo
682 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
