Question about HTC TyTN II Smartphone
TyTN 2 hi iv recently rented a TyTN 2 phone from college iv recently dropped it nd a screen has come up with all different colours and the serial number it also wont turn on or off and is continually on the screen do you know how i could fix it?
  • 1 more comment
  • hollyanng Jan 31, 2009
    I have the same problem. Did you get an answer?
  • GeoffPotts Mar 02, 2009
    Won't hard reset, didn't drop mine, but screen is all different colours showing serial number. It did it once before but went away when I switched it off and on. This time it won't do anything at all
  • watermouse May 11, 2010
    Did you really drop it? That's something caused by the operating system being overwritten improperly, or corrupted in some way.
Make an hard reset !
http://www.pdamobile.cz/pict/news/htc_tytn_2-hard_reset.jpg
Posted on Oct 23, 2008
I forgot my security code..nd for this czs i dn't
Instructions
    • 1
      Turn on the cell phone. If it's locked, use the current PIN number to unlock it.
    • 2
      Navigate to the "Settings" screen, or to a screen of the same significance. Different phones will have different names for screens, but the security features are always available on the screen that allows users to change the settings.
    • Sponsored Links
    • 3
      Open the "Security" menu. On this menu, you will probably be able to view your passwords and information about your phone, such as the email address you were given by your service provider and your phone number.
    • 4
      Enter the menu that allows you to view and change your password.
    • 5
      To change your password, you'll first have to enter your current password. You'll then need to enter your new password and confirm it. Make sure the new password is something you can easily remember. If you lock your phone and forget your password, you'll have to enter your phone's PIN Unblocking Key (PUK) or call your cellular service provider to get an unlock code, either of which can be a hassle.
God bless you
May 23, 2013 | Cell Phones
My tytn 2 suddenly stop detecting the SIM. i tried putting a different SIM but the phone still say insert SIM on the screen.. pls hlp
Try putting a little piece of folded paper between the battery and the SIM. Maybe it`s a loose contact.
Mar 13, 2011 | HTC TyTN II Smartphone
Iam was using HTC TYTN 2,it was working fine till yesterday,today moring i dropped my tytn2 in road by accidently,i took it back and my phone was working good i can receive the call and i can make the...
it seems when you dropped the phone some stuff shifted in the mobile if you can pull the phone and just screw it back up it should be ok, if not i recommend contact a technician for his assistance
Sep 18, 2010 | HTC TyTN II Smartphone
My samsung phone has stopped receiving texts what wrong with my phone
hi iv ad dis fone 4 nearly 2 months nd dat happened bt all u av 2 do is send ur self a msg 2 or 3 times nd den all d msgs dat were sent to u *** in..!! hope it helps...
Aug 27, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Htc herm200 can't charge
Hold down the two soft-keys (the ones below the screen) and while you have them held down you poke the reset button with your stylus. You'll then see a message on the screen saying 'press R to reset, X to exit'. Pressing the R key on the keyboard will hard-reset the device. It'll now take a few minutes to reboot and load all of the operator customisation etc.
This procedure will hard reset the HTC TyTN, Vodofone v1605 and all other HTC Hermes variants.
Dec 17, 2009 | HTC TYTN GSM Phone
I can not be able to access the internet on my htc tytn phone.
You need to call your Mobile Operator for the Internet settings as they are specific to the Mobile Operators.
Apr 07, 2009 | HTC TyTN Smartphone
EDGE/GPRS not working in HTC TyTN II with Windows Mobile 6.1
There is an auto configuration guide that you must use after the update. Look for it in your system tabe under settings
Oct 22, 2008 | HTC TyTN Smartphone
TyTN II - Keep the phone screen alice during a call
Received the following reponse very promptly from HTC Support
---Quote---
This is actually a function of the phone and not a fault. It was designed so that when you were on a call and had the phone against your ear that you didn't accidently tap on the screen and open functions or end the call etc. If you wish to access the touchscreen while on the phone you can press the power button on the side of the phone to turn the screen back on. I have attached a 3rd Party Application that allows the screen to stay on while you are on a call. Follow the below steps to install the program. Attached is a patch for the TyTN II screen blackout issue.
This is not an official fix.
  1. Copy the KaiserTweak.zip folder to your pc's desktop.
  2. Connect you device to the pc via ActiveSync.
  3. Use the Explore function in Active Sync to copy the KaiserTweak.zip folder to the windows directory on your TYTN II.
  4. Disconnect your TYTN II from the pc.
  5. Open up file explorer on your TYTN II and go to the windows directory
  6. Unzip the folder to the windows directory on the TYTN II
  7. Run the Kaiser Tweak.exe to install the patch.
  8. Adopt the recommended configs, not the default.
  9. Soft reset the TYTN II by pressing the stylus into the little circle hole on the bottom of the handset.
If it doesn't work first time hard reset and try again. ---End Quote --- Thanks to the FixYa guys for thier intererst in this topic and problem Cheers Corpcc
May 12, 2008 | HTC TyTN Smartphone
HTC TyTN II Smartphone Logo
527 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
