You can try going thru the start up items on the computer. Also removing any unwanted or unused software on your computer. To disable start up items: go to start > run > type msconfig > go to the start up tab on top of screen > then within here is all the aplications that start when you turn on your pc. If your not fimiliar with any of them go to www.processlibrary.com and enter each one it will advise you if you should turn it off or not. Or if it ok to disable it. To remove software from computer: go to start > open control panel > within control panel open add/or remove programs > with in here you can remove any software that you may not be using or are unaware of what it may be. Desktop Support & Repair
Try to perform disk cleaning clear all temperory files, restart your PC again.
