Question about Toshiba Satellite A135-S4527 Notebook
URGENT CALL: Critical Error that keeps restarting System?
We switch the laptop on to access AOL, but once in desktop a little pop up box appears that states " Windows has enctountered a critical error and will restart your system in one minute - please save all work now".
It then restarts, lets you access AOL but then promptly cuts out, retarts again the cycle begins again and again and again??
Ive rang AOL techies, and they "sorry nothing to do with us, you have a laptop issue"... so can anyone please please help - this is an emergency as this laptop is used for work. We use windows Vista Basic on this machine.
the machine is less than 6 months old.
We actually have a Toshiba Satellite A135-S7404 Intel Celeron M.
    Scholar:
  • 107 Answers
Hi ,
this is problem with your windows , you used winxp it is need to protect with antivirus .
when u get revers counting on screen just go to "Run"& type shutdown -a
  • once u need to remove virus from u r laptop
  • if problems get same u need to reinstall win xp
Posted on Jun 11, 2008
  • Techpoint
    Techpoint Jun 22, 2008
    friend u r not Rate me for this solution for long time .if u resolve problem please Rate me......
Computer restarts randomly
If you are using Windows (XP, Vista or 7) then open the Computer properties by clicking on the Computer icon (on desktop or start menu) then go to the Advanced page tab and check if you have the option to automatically restart the system set on in the Startup and Recovery Settings section. If this is on, then Windows will restart the system any time that a critical error is encountered.
The other place to check is in the Windows Event logs (system log) provided this option is enabled.
You should be able to access the event logs by right clicking on the Computer icon and then selecting the Manage option followed by opening the Event viewer where you should look for any critical, error or warning entries that may occur at the times when the computer restarts itself (or posted immediately when it restarts).
Jan 12, 2012 | Toshiba Computers & Internet
Laptop keeps restarting
  1. See if you can start in Safe Mode (hit F8 before Windows loads - best way is to keep tapping F8 after you power it on. You should get a menu with "start in Safe Mode" as an option.
  2. Once booted in safe mode go to Control Panel, System, Advanced, ;Startup and recovery'.
  3. Click the Settings button and remove the tick from the "Automatically Restart" box.
  4. Click all the OK's to get back to Control Panel.
  5. Reboot as normal and the system should display an error code. Post that error code here and we can have a look at it.
Sep 07, 2009 | Compaq Presario 5000 PC Desktop
Lenvo blue screen error message when computer starts up
Please try to unplug the laptop from power and remove the battery for over 10 seconds. Then start it up again. There are other things we can try if this does not work.
Mar 19, 2009 | Lenovo 3000 N200 Notebook
Hi My daughters laptop Acer aspire 5920 is giving her problems. After windows start up a blue screen appears stating " fatal error C000021a". She has ran windows repairs as that pops up but a...
pleas run this command from command prompt
go to run and type cmd then enter
type this chkdsk/r/f/v
press y when prompt for scan will on windows restart your
After restart leave the system idle to complete the scan
I hope this will solve your problem
Dec 04, 2008 | Acer Computers & Internet
Reconnect
This is an AOL Problem. Call your AOL representative and they will help you fix their/your problem.
good Luck *s*
Oct 26, 2008 | Computers & Internet
Used laptop
Hi
It could be some of your system application cause your internet explorer not to open. I suggest to try the steps below.
1. Click start
2, go to Run, then type this command in the box.
msconfig
a pop window will show up on the screen.
3. Look for Services as one of the tab of the window.
4. Under services, look for a smal box at the bottom portion of the screen that say "hide all microsoft services" then click on disable all.
5. Look for Startup tab on the same window screen. Then click on Disable all. Click on apply then "Ok/ Close"
6. Restart your computer. After restarting your computer. You will see the system configuration utility window. just put a check on a small box that say "Do no show the message" then click Ok.
7. Try to open your internet explorer icon.
Keep me posted.
Thanks.
Oct 17, 2008 | Dell Latitude D600 Notebook
Start up problem
It appears that Service Pack 2 did not completely install. Try to boot into safe mode (F8 at startup). If you can, go to control panel, then add/remove programs. Scroll all the way down, select Windows XP Service Pack 2 and click "remove".
After it's removed, you will need to reboot, but the system should come up normally after that.
Hope this helps - please remember to rate :)
Sep 25, 2008 | Compaq Presario R3000 Notebook
URGENT CALL:- Critical Error that keeps restarting system?
Definately not a "major issue"... it is a Software issue rather than a Hardware issue...
And most likely a conflict with your ActiveX controls...
Try This....
Go to Start...Programs......Windows Update..enable if disabled.. and it will search for updates and hopefully install the SP1 update...
This update download apparently has patches for the exact error you have and that is a typical Vista "hiccup" error....
try that, if it doesnt help still, we can go from there..
Jun 11, 2008 | Toshiba Satellite A135-S4527 Notebook
URGENT CALL: Critical Error that keeps cutting out AOL
GO Here and download the Hotfix at the top of the page.. (click on the Hotfix Icon, and follow directions..
http://support.microsoft.com/kb/937063#
it is for vista home basic as well......
then lemme know again
Toshiba Satellite A135-S4527 Notebook Logo
205 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
