Intel D845GVSR Motherboard Logo
Posted on Oct 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Total amount of ram allowed ??? - Intel D845GVSR Motherboard
Lebanon Raingam
Level 3:
  • Master 4,737 Answers
  • Posted on Oct 31, 2010
Lebanon Raingam
Master
Level 3:
Answers
4737
Questions
Helped
1385377
Points
16345
2GB maximum (Click Here), open the link and check the "System Memory Features"
Source: Intel > Maximum total system memory: 2 GB; minimum total system memory: 64 MB
Good luck.
Thanks for using FixYa.
Duncan Mutch
Level 3:
  • Master 418 Answers
Duncan Mutch
Master
Level 3:
Answers
418
Questions
0
Helped
78190
Points
1268
If I've got the right manual (which I'm sure it is but do double check) it says total allowed is 2GB.
http://downloadmirror.intel.com/15210/eng/D845GVSR_TechProdSpec.pdf
I have problems with the ram in my laptop what can i do? how can i find out if its a hardware problem or software
To check if you have a RAM problem, go into the BIOS and check the amount of RAM installed, does this match the total amount of RAM installed, if the RAM in the BIOS does not match the total amount of RAM in the RAM modules then you may a faulty RAM module or an incompatible RAM module.
If it is a software problem, a program may require more RAM than is installed on your computer. The software instructions will recommend the amount of RAM your computer should be installed with.
How many slots for dram chipsets? For AZ11/ AZ31 motherboard? Thanks!
FIC AZ11 (First International Computer {Inc}
3 Ram Memory slots.
Supports SDR Sdram at 100MegaHertz, or 133MHz. (PC100, and PC133 respectively)
Maximum Total Amount is 1.5GB
Maximum Amount for EACH ram memory slot is 512MB. (1/2GB.)
Uses the VIA KT133 motherboard chipset,
(Northbridge - VIA VT8363
Southbridge - VIA VT82C686A/B)
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
Socket A processor socket for AMD processors. (Also referred to as Socket 462)
http://www.xbitlabs.com/articles/mainboards/display/fic-az11.html#
FIC AZ31
3 Ram Memory slots
Same type of ram memory as above, same total amount, and amount for each ram memory slot.
Uses the VIA KT133A motherboard chipset.
(Northbridge - VT8363A
Southbridge - VT82C686B
Socket A processor socket.
http://en.wikipedia.org/wiki/Socket_A
http://www.baber.com/baber/411/fic_az31.htm
3helpful
2answers
If i change the ram stick will my pc reconise it
Yes.
Provided,
1) It is no more than the maximum amount, for that ram memory slot.
2) Adding it, will not go over the Maximum Total Amount for the motherboard.
If this pertains to an Acer Aspire T135 desktop computer,
A) The Maximum Total Amount is 2GB.
B) The Maximum Amount for Each ram memory slot is 1GB.
C) PC3200 is the best you can use.
DDR Sdram at 400MegaHertz. (400MHz)
[It can also use PC2100, and PC2700.
DDR Sdram at 266MHz, and DDR Sdram at 333MHz, respectively ]
Once you install the ram memory, BIOS should automatically find it.
If you are only going to use one ram memory module, be sure to put it in Slot 1.
The Processor reads ram memory in Slot 1 first.
[Slot 1 is closest to the Processor.
It may have DIMM 1 printed on the motherboard, next to Slot 1 ]
1helpful
2answers
I want to upgrade my memory on my Pavilion 513n,
FixYa is a product support website, and as such we do not delve into manufacturing. No we cannot supply ram memory.
I can supply you with the solution to your questions, however.
This is HP Support, and the main page for the Pavilion 513n Desktop PC,
http://h10025.www1.hp.com/ewfrf/wc/product?product=90384&lc=en&cc=us&dlc=en&submit.y=5&submit.x=6&lang=en&cc=us
If you click on > Product information > Product specifications > HP Pavilion 513n Desktop PC Product Specifications,
you can view,
A) What type of ram memory the computer uses,
B) How much is the Maximum Total Amount for the computer,
C) How much is the Maximum Amount for EACH ram slot,
D) How many ram slots
Look under the Memory heading.
Type - DDR
It's DDR Sdram
Speed - PC1600/PC2100
Tells you either PC1600 can be used, or PC2100.
PC1600 is DDR Sdram that operates at 200MHz.
PC2100 is DDR Sdram that operates at 266MHz.
{To expound:
Ram memory operates at a Frequency Rate. Slang for frequency rate is 'Speed'.
Mega = approximately 1 Million
Hertz stands for Cycles per Second
Example: PC2100 is DDR Sdram that operates at 266 Million Cycles per Second }
B) What is the Maximum Total Amount for the computer. (Motherboard)
According to HP it is 1GB.
{Maximum - 1GB (2 X 512) HP recommended maximum}
I believe this to be wrong. The Total Maximum Amount is 2GB.
1GB per ram slot.
I base this upon using the memory configurator's of several websites, that sell ram memory for the Pavilion 513n desktop computer, and looking at what the motherboard chipset for the Pavilion 513n will support.
The motherboard chipset is the Intel 845GL.
This chart found on Wikipedia, states what the Intel 845GL chipset will support,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
As you can see reading across from the 845GL subheading, and looking under > Max.memory, 2GB is listed.
Sources for online memory configurators,
1) Crucial.com
2) Tigerdirect.com
3) Newegg.com
4) Memory4less.net
In this case,
C) Maximum Amount for EACH ram slot is 1GB.
D) There are Two ram slots. {Proper speak for ram Slot is ram Bank}
Kingston is a good brand for economical ram memory.
So is Ultra.
An easy way to find out what type of ram memory you need, and how much is the Maximum Total Amount, as well as the Maximum Amount for Each ram slot, is to use an automatic scanner from a website that sells ram memory.
The above four websites listed, are but a small handful of the total websites online that offer an automatic scan.
Let's use Crucial.com for an example.
On the main page,
http://www.crucial.com/
,you will see - Scan My System, in blue.
Simply click on it to run an automatic scan of your computers hardware.
Doesn't look at your personal effects, just the hardware of your computer.
After the scan is done, you will be presented with the ram memory info you need.
Several options of ram memory are presented for you to choose from.
1helpful
2answers
Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
1helpful
3answers
Change ram from 512 to 1 gig bios cannot read added ram
The original 2 sticks of 256 Mb of RAM gives you a total of 512
Mb of RAM. Two 512 Mb of RAM gives you a total of 1 Gb of RAM.
With two sticks of 512 Mb of RAM are you sure you got a total of 192 Mb of RAM, this is a lot less than the original RAM total of 512 Mb?
Should this be 1920 Mb of RAM?
If this 192 Mb is correct then the RAM modules are either not compatible with the laptop or if the RAM modules are not from the same manufacturer then they may not work together.
Most laptops have video cards that use part of the main RAM for video RAM, that is why the available RAM is less than the installed RAM modules. The amount of RAM the video card grabs depends upon the type of video card and in some cases the amount of video RAM can controlled in the BIOS setting.
After I upgraded RAM from 512 MB to 2 G, my computer can not resume from stand by mode.
1.Do you know what the Maximum TOTAL Amount is for your ram?
2.Do you know what the Maximum Amount is for EACH ram slot?
3.What is the computer manufacturers name, model name, and model number?
(Example: Compaq Presario SR1110NX.
Compaq: Computer manufacturers name
Presario: Model Name
SR1110NX: Model Number
(Not trying to insult your intelligence with Number 3 above)
Reason for asking Number 3?
Let's take an example. Let's say your computer has a Maximum Total Amount for ram memory, that is 2GB.
EACH ram slot's Maximum Amount is 1GB, and you have two ram slots.
If you install a single stick of 2GB ram in Slot 1, chances are it isn't going to work.
If I know what computer you're referring to here, then I can give more of an exacting solution.
Upgrade memory ram for ibm thinkpad 600e
IT DOEST MATTER YOUR VISTA OR XP SOFTWARE HAS TO BE ABLE TO SUPPORT THE AMOUNT OF RAM, ALSO DO YOU SHARE VEDIOMEMORY WITH THE RAM AS ONE , IF SO THAN JUST LET 1 GIG FOR VEDIO AND YOUR SYSTEM MAY ALLOW YOU TO GO TO 2-3BG, CALL THE VENDER ASK THEM THE MAXIMUIN AMOUNT OF RAM THAT THE SOFTWARE WILL SUPPORT THAN ADD THE TOTAL AMOUNT OF RAM YOUR VEDIO RAM ALLOW AND YOU WILL KNOW HOW MUCH RAM YOUR SYSTEM CAN HANDLE, 32BIT OR 64 BIT XP OR VISTA WILL RUN MIN 2-4GB, WANT TO BE SAFE THAN SPLIT IT 3GB
IT WILL COST YOU AT FRY .COM, WITH SHIPPING AND INSURANCE LIFE TIME WARRRENTY ON THE MEMORY ABOUT 50-70 DOLLARS.
ROD
BEEN THERE AND DONE IT
Sdram capacity
its that 512 mb total capacity for your computer memory?? if so read this:
To find the total amount of RAM that can be added , subtract the amount of RAM currently in the computer from the maximum amount of memory the computer can hold. For example, a computer has 256 MB of RAM. If the maximum amount of memory the computer can hold is 512 MB, then 256 MB is the amount of RAM that can be added. this info from the HP website , to find out more , go to http://www.hp.com/support , enter the model number , and look for more information about your computer specs, hope this helps , please rate & thanks AJ
Getting access to bios in Dell Inspiron 1300
No, The amount of RAM the integrated video uses is dynamically adjusted depending on the loading of the video and the total amount of RAM installed.
If less than 512 MB RAM, the video is limited to 64MB, 512 to 2 GB max video RAM is 128 MB.
If you want to upgrade RAM to improve performance, check the link below:
http://www.crucial.com/store/listparts.aspx?model=Inspiron%201300
2 GB for $50 + tax, not bad
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
