FixYa.com
Gateway FPD 1730  17 in. Flat Panel LCD Monitor
Gateway flatscreen monitor
posted by Hoonhor1 on Jun 11, 2008
screen flickers a bit, then will go black, although the power is still on.  Switching it off and then on again brings the picture back temporarily.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 11, 2008
Thanks for Trying (70)
Regzo
Rank:Wiz Wiz
Rating: 75%, 14 votes
There is a problem with the power supply cable to this monitor. You need to have a new one put on. An easy way to test this is to get it to a shop so they can test the cable.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Monitors problems?
Gateway FPD 1730 (Platinum) 17 in. Flat Panel...
Thin Green line from top to...
Appx 3 inches from the left of... Answer This...
Monitor Lines
Everytime I start-up my... Answer This...
screen going black, green LED...
I have the same problem e.g.... Answer This...
Inverter and power supply
i could use the inverter but if... Answer This...
Need inverter
If you are trashing your... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
