Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Posted on Oct 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an airflow issue and it says the tv will shut down
Anonymous
Level 3:
Genius:
  • Master 1,030 Answers
  • Posted on Oct 31, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1030
Questions
Helped
227561
Points
2244
Check to see if the vent might be blocked or if you can feel the fans blowing... there is a sensor that takes the temperature of this set. mitisubishi has had problems with this sensor. as a technician i have replace this sensor fairly inexpensively. .. most time under warrenty.
My tv monitor says "TV
YOU NEED TO REPLACE THE THERMOSTAT ON YOUR SET TO CORRECT THIS ISSUE .
2answers
Have a Mitsubishi 52725 52" DLP The TV shuts off frequently. It tells you "the TV with shut off in 30 seconds". It seems warm but I have a fan in the rear to cool it down but sometimes it still...
does it give you the "airflow" message?
if so it needs a new thermal sensor by the lamp, known issue defective sensor..
if not, suspect bad capacitors
there are many bad caps across 3 board , all part of the chassis.
a repair center will ship the chassis into mits for rebuild, about 400 or 500 total bill
1helpful
The projector is starting up but after warming up it shuts itself off. It is not the a problem with the filter, lamp seating or an overheating issue.
Does the lamp actually light up and project? If not, it's probably a dead bulb. Are there any flashing lights that might be displaying an error code? How dow you know it's not overheating? Remove the filter and give it a good cleaning. Some projectors measure airflow and, even though the heat hasn't built up, the projector shuts down because it predicts overheating will occur due to insufficient airflow.
3helpful
TV turns off because of air flow
It is probably a bad temp sensor inside the TV. My 73" started shutting down before it was a year old. I moved it way out from the wall and it got a little better. A tech was just out to change the bulb under an extended warranty and he said there is a service bulletin about the temp sensor. If your TV is out of warranty you might call Mits and see if they will cover the sensor replacement. Tech said it takes about a 1/2 hour in the home to change it...
Error message
Good Day, drdeath57;
Make sure your air vents are clean but more than likely you should suspect the TV's Lamp Thermal Sensor
2answers
Shut Down Message
The repair is to have the DLP engine replaced!!
FYI: The engine also can cause the set to shut down without any display or might even tell you the lamp door is open when it is not.
Turns off every so often
Well guys I found that if one just reads the manual you may find the solution...Mine seemed pretty simple - the room temperature was too warm! I adjusted the heat in the house, the yellow Status light went off and...it works again!
Thanks
ndre
Mitsubishi wd 52525 dlp shuts down
mitsubish has issued a service bullietin about the problem. which means ussally they will pay for its repair. the reson it says airflow bock is that there is a temperture sensor that is at fault... it needs replaced.
1helpful
3answers
Mitsubishi dlp tv model number wd57732 purchased 2-20-2007
i had the same problem on 10/24/07 and i called a Mitsubishi warranty company near me and they came out and replaced the Sensor part # 1299P313010A. No problem since
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
