Question about Sony Ericsson K510i Cellular Phone
Key blocking hi! i noticed that my keys are not working. for instance, i can't type 1,2,3 and the answering button... obviously i can't enter the pin number, thus i can't get a master reset or so... i went to a gsm service, they've cleanded it up and with no help... the man there told me about a reset of the mobile, but i can't figure out a way to reset it since i can't access the menu. i would be grateful if you'd answer me (and explain a little about the reset and how can i do it). cheers!
    Problem Solver:
  • 10 Answers
I think, you need to buy new keys to work again...
Posted on Jun 11, 2008
I have forgotten my alarm code for my motorhome Sigma S30 The keypads still work but I need the code to reprogramme a more rememberable number
Here are some important informationabout Sigma S30. Programming a New PIN Code:
The standard PIN code can be changed following thesequence below:
i) Type in to the keypad **
ii) Type in to the keypad the "existing PIN code" then *
iii) Type in to the keypad 92 * "new PIN code" * "new PINcode" #
Programming Remote Keys to the System:
Remote keys can be added or removed to/from the systemfollowing the sequence below:
iii) Type in to the keypad 91 * " the number of keys to beused" #
iv) Press the first remote key button until bleep sounds,release and press next key. Continue until all
keys have been taught to the system. Note the maximumnumber of keys is 4 and all keys required
to operate the system must be taught during this operation- any key not included will no longer
operate the system.
Full Programming, Diagnostics and Features
This section contains all the information that the dealersuse for programming and diagnosis of
the Sigma M30 alarm system, using the MK1 keypadprogrammer.. Programming can also be carried
out using a dealers CP1 programmer.
MK1 Keypad Programming Introduction
It is important the keypad buttons are not pressed tooquickly-
Each time a button is pressed the LED on the keypad willflash once as confirmation. The next button should
not be pressed before this confirmation.
It is important the keypad buttons are not pressed tooslowly-
When in programming mode, if a button is not pressed for aperiod of 10 seconds or more, the alarm will
automatically exit programming mode. This will be confirmedby repeated flashes from LED on the keypad.
You must wait until the LED stops flashing and then startagain.
All programming functions are entered after typing * andthen the programming PIN code. The programming
PIN code is 17856.
To enter the programming PIN code, the alarm system mustfirst be armed and then disarmed using a valid
remote key. (Or keypad using the PIN code)
* 17856 * must then be entered within 30 seconds ofdisarming the system. This is then followed by a 2
digit function code, then another * and then sometimesoptional parameters as shown in the following tables.
It is important to remember the * key is used to separatethe various parts of the code like this:
* programming PIN code * function code * parameter #. The# key is pressed at the end of all
sequences and is used like the "enter" key on a computer keyboard.
Programming Features On or Off:
Programming
PIN
Function
Code
Switch Code
(where 0=off and 1=on)
Function Default
* 17856 * 00 * 0 or * 1 then # arm/disarm bleeps * 0 (off)
* 17856 * 01 * 0 or * 1 then # door open warning bleeps *0 (off)
* 17856 * 02 * 0 or * 1 then # auto-lock * 0 (off)
* 17856 * 03 * 0 or * 1 then # auto-arm * 0 (off)
* 17856 * 04 * 0 or * 1 then # auto-arm to include doorlocking * 0 (off)
* 17856 * 05 * 0 or * 1 then # auto-rearm * 0 (off)
* 17856 * 06 * 0 or * 1 then # engineer mode * 0 (off)
* 17856 * 07 * 0 or * 1 then # hold-down remote key button= -ve
output on wire 4
* 0 (off)
* 17856 * 08 * 0 or * 1 then #
hold-down remote key button =
extends lock pulse
* 0 (off)
* 17856 * 09 * 0 or * 1 then # after disarm -ve output onwire 4 * 0 (off)
Programming Timing Settings:
Programming
PIN
Function
Code
Variable(s) Function Default
* 17856 * 10 * 1 to * 30 then # stall to ignition on timein seconds 30 sec
* 17856 * 11 * 1 to * 99 then # unset to ignition on timein seconds 30 sec
* 17856 * 12 * 1 to * 99 then # panic time in seconds 05sec
* 17856 * 13 * 1 to * 51 then # lock time in seconds (51gives two
short pulses)
01 sec
* 17856 * 14 * 1 to * 51 then # unlock time in seconds (51gives
two short pulses)
01 sec
* 17856 * 15 * 1 to * 99 then # settle time in seconds 15sec
* 17856 * 16 * 1 to * 99 then # threshold setting time inseconds 15 sec
* 17856 * 17 * 1 to * 99 then # auto arm time in seconds60 sec
* 17856 * 18 * 1 to * 99 then # auto re-arm time and also-ve
output time after disarm , on wire 4
(green/red) in seconds
60 sec
Displaying System Diagnostics:
The dashboard LED displays the value of settings as anumber of flashes.
Programming
PIN
Function Code Function
* 17856 * 30 then # time elapsed since last trigger (inminutes)
* 17856 * 31 then # as * 30 above - but each flash = 256minutes
* 17856 * 33 then # wire 7 (orange) ignition trigger count
* 17856 * 34 then # wire 1 (blue) -ve door trigger count
* 17856 * 35 then # wire 2 (blue/red) -ve boot triggercount
* 17856 * 36 then # -ve bonnet switch trigger count (blacksingle wire on siren
plug)
* 17856 * 37 then # ultrasonic's trigger count
* 17856 * 38 then # last trigger register (see tablebelow)
* 17856 * 39 then # reset all above trigger counts to 0(zero)
Setting Up Pre-set Programs:
Keying in the following sequences on the keypad sets up afixed set of features, which can be used as a
starting point for further tailoring:
* 17856 * 80 # everything off, lock and unlock pulses 1second.
* 17856 * 81 # as for * 80 above, with auto-rearm on.
* 17856 * 82 # as for * 80 above, with auto-arm on.
* 17856 * 83 # as for * 80 above, with auto-rearm andauto-arm on.
* 17856 * 80 # Default setting configures the values shownin the previous tables 1, 2 and 3. Hope this will help you. Good Luck.
Aug 22, 2011 | GPS
I need a parental control reset code
Hi there
Click the "Wii" button located on the bottom left corner of the screen on the Wii Main menu.
Click the "Wii Settings" button on the System Settings screen. Look for the button with the wrench icon.
Move to the second page of the Wii System Settings screen by clicking the blue arrow.
Click the "Parental Controls" button on the second System Settings screen.
Click "I Forgot" when asked asked to enter your four-digit PIN.
Answer the secret question displayed on the screen. You provided the question when you set up your Wii. Note that the answer to the question is case sensitive.
If you answer correctly, you'll have access to the Parental Control Settings. Reset your PIN on this screen by entering a new PIN number and a new answer to the secret question, then clicking OK.
Click "I Forget" if you can't remember the answer to the question. Nintendo displays a message screen with text telling you to contact Nintendo customer support. At the bottom of the screen is a confirmation number.
Write down the confirmation number so you don't forget it, and leave your Wii turned on with the confirmation number screen displayed.
Call Wii customer support at 800-255-3700. Tell Nintendo customer support your confirmation number. You'll receive a master key code to reset your parental control PIN. Write down the master key code.
Return to your Wii, and click the "Enter Master Key" button. On the Master Key screen, enter the five-digit master key you received from Nintendo customer support, then click "Confirm Master Key." The Wii displays a message stating that "Parental Controls are Now Disabled." Click "OK" for the Wii to return you to page two of the Wii Systems Setting screen.
Click the "Parental Controls" button on the Wii System Settings screen. The Parental Controls screen will now show that you have no parental control settings enabled. Enter a new four-digit PIN number and secret question to reset your PIN, then click "OK."
Sep 30, 2010 | Nintendo Wii Console
Sony ericsson w580i turn on it asks for lock code 4-8 characters. i have tried all the combinations 0000-00000000, 1111-11111111,1234-12345678, 0123-01234567,reverse
To activate the phone lock protection:
  1. Select Menu > Settings > General (tab).
  2. Select Security > Locks > Phone protection.
  3. Select Protection > On.
  4. Enter the default phone lock code "0000".
To change the phone lock code:
  3. Select Change code and follow the instructions.
However IF it is to do with your PUK code see below..
PUKs, or personal unblocking keys, are used to unblock a mobile phone which becomes blocked. Mobile phones may become blocked when a PIN (personal identification number) is entered incorrectly on three consecutive occasions. In some instances, the phone may become blocked, which requires a PUK to unblock it, and in other instances, the SIM (Subscriber Identity Module) card itself becomes blocked and again will require a PUK to unblock it. Mobile phones are also blocked when they are reported stolen and if there is an outstanding payment on the account. It is important to differentiate between unblocking phones (using a PUK) and unlocking mobile phones (using another type of code). NOTE: It is a criminal offence for anyone to attempt to unblock a mobile phone, other than the network provider who put the block on the phone. If your phone has become blocked by mistake, for example you have entered the PIN incorrectly on three consecutive occasions, then you need to contact the mobile phone network operator with your details. To explain a little more, specific to your mobile phone network, You need to go to your Service providers, web site & navigate your way to the specific PUK details for your mobile phone network operator. Usually you have to Register your phone to get a PUK code.
Aug 19, 2010 | Sony W595a Cell Phone
Give me unlock key for imei 35664005162345
There are two type of phone lock:-
1. Sim Lock
2. Phone lock
Sim unlock: To unlock sim ask pin or puk no from your mobile service provider and then enter the no to unlock, if you get the msg as sim rejected then you have to go for a new sim card to activate your number
Phone Unlock: To unlock phone with IMEI no is not easy you must know the phone unlock number and it may differ with user( Nokia common Unlock code is 12345 or 0000), you better go to Nokia service center and update the software to unlock the phone easily and it cost only Rs:400.
Thank you.
May 08, 2010 | Nokia 6600
PUK code
PUKs, or personal unblocking keys, are used to unblock a mobile phone which becomes blocked. Mobile phones may become blocked when a PIN (personal identification number) is entered incorrectly on three consecutive occasions. In some instances, the phone may become blocked, which requires a PUK to unblock it, and in other instances, the SIM (Subscriber Identity Module) card itself becomes blocked and again will require a PUK to unblock it.Mobile phones are also blocked when they are reported stolen and if there is an outstanding payment on the account.It is important to differentiate between unblocking phones (using a PUK) and unlocking mobile phones (using another type of code). NOTE: It is a criminal offence for anyone to attempt to unblock a mobile phone, other than the network provider who put the block on the phone.If your phone has become blocked by mistake, for example you have entered the PIN incorrectly on three consecutive occasions, then you need to contact the mobile phone network operator with your details. To explain a little more, specific to your mobile phone network, You need to go to your Service providers, web site & navigate your way to the specific PUK details for your mobile phone network operator. Usually you have to Register your phone to get a PUK code.
Apr 09, 2010 | Alcatel OT-C701 Cellular Phone
Plese give me the licencse key my IMEI 010339001508423
Apr 06, 2010 | Nokia N-Gage QD Console
My IMEI 353360001113415....i want know my license key
Apr 03, 2010 | Nokia N-Gage QD Console
Ask for PUK code of sim card even upon entering the right sim PIN
PUKs, or personal unblocking keys, are used to unblock a mobile phone which becomes blocked. Mobile phones may become blocked when a PIN (personal identification number) is entered incorrectly on three consecutive occasions. In some instances, the phone may become blocked, which requires a PUK to unblock it, and in other instances, the SIM (Subscriber Identity Module) card itself becomes blocked and again will require a PUK to unblock it. Mobile phones are also blocked when they are reported stolen and if there is an outstanding payment on the account. It is important to differentiate between unblocking phones (using a PUK) and unlocking mobile phones (using another type of code). More information on unlocking phones will be available here in the very near future. NOTE: It is a criminal offence for anyone to attempt to unblock a mobile phone, other than the network provider who put the block on the phone. If your phone has become blocked by mistake, for example you have entered the PIN incorrectly on three consecutive occasions, then you need to contact the mobile phone network operator with your details. To explain a little more, specific to your mobile phone network, use the links above to navigate your way to the specific PUK details for your mobile phone network operator.
Feb 05, 2010 | Cell Phones
Change tax rate oncalculator
Press the [ac] button, then press and hold the [tax+] button for a second or two. Then enter the tax rate you want as a percentage. You would enter 8.25% sales tax as 8.25 for instance. Then press the [%] key to set the rate. Notice that printed above the [tax+] button is "tax rate" and above the [%] key is "rate set" as a reminder of which key to press.
Apr 02, 2009 | Casio Office Equipment & Supplies
Forgotten pin number
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Sep 03, 2007 | Kenwood KDC-519 CD Player
Sony Ericsson K510i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
