Question about Dryers
ASCO T721 dryer, the heat temp is too low
HI, I have a ASCO T721 dryer. The heat temp is too low. Yesterday it took 2&1/2 hrs. to dry 3 pairs of small sweat socks and a few other(lighter) items. Sheeesh. this is suppose to conserve energy? If there is anyway I can adjust the heating element plz let me know. I am an electrician by trade, It is stacked on a washer in the closet. I just need to know where the temp. adj. is located.Thank you.
  • 2 more comments
  • Melimar Jun 11, 2008
    Hi, It is a condensing model, that is in a closet, with the washer under it.
    It is a condensing model, that is in a closet, with the washer on the bottom.
    A building vent to the outside. I have cleaned the filters. They weren't too dirty because I have only used it about 10 times this year. I even had the maintence guy check it out. He was shocked at how clean the filters were.
    Yes, it does. It is a multidwelling building. It has one common duct. There is a hose from my unit to that duct.
  • 770 Answers
Is your model a Condensing dryer or does it have a Vent to the outside?
Posted on Jun 11, 2008
  • 1 more comment
  • Gary Davd
    Gary Davd Jun 11, 2008
    First off clean the collector box out reall good also check the lint sceen on the door to make sure of no clogs sweep with a vaccum the lint screen area then run a load see what happens
  • Gary Davd
    Ok I am confussed ...............DOES YOUR UNIT VENT TO THE OUTSIDE?
  • Gary Davd
    Ok then please take the vent off the dryer let it blow into the closet for one load i am willing to bet it will dry fine. If so tell your maintence man the common vent needs de linted this is 95% of long dry time problems
Maytag DE810 Dryer takes too long to dry
Have you checked the Hose and the pipe that exits your wall? Sometimes birds will nest in them. Pull the dryer out and run it without the hose connected to test it.
May 18, 2015 | Dryers
Run a service test for kitchenaid dishwasher
Did you check behind the toe-kick panel for the tech data sheet? Assuming that you have checked and that it is missing, there here is the "secret keystrokes" that will make most Whirlpool/ KitchenAid/Kenmore/Maytag diswashers enter the diagnostic cycle:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Oct 18, 2014 | KitchenAid KUDS30IXSS Builtin Dishwasher
Reset kenmore dishwasher
The most common "reset" key sequences are:
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry).
Jun 15, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
The clean light keeps flashing clean and we can't start it. Plus it doesn't get any of the dishes clean and it's only 3 hrs old
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 14, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
My dryer won't heat up to dry the clothes. I empty the condensing unit (the long many paneled pull-out piece behind the two red levers behind the lower front panel) periodically and this is not the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 23, 2011 | Asko T721 Electric Dryer
No heat not drying
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 28, 2010 | Asko T721 Electric Dryer
I dont have manual for miele T5213 so cant tell - should heat button be pressed in for low temp. Doesn't seen to have time difference when drying towels
hi i have a miele t5213 dryer it was ok yesterday but today it is
not getting hot can you help also i dint have a manual for this
machine i lost it during moving house
regards jeff
Sep 19, 2010 | Miele Novotronic T1570C Electric Dryer
Wed5300VWO dryer only dries clothes occasionally. Some times takes 1 1/2 hrs for small load. waist bands on pants damp etc, All thermostats have been replaced by repairman
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 11, 2010 | Whirlpool Dryers
Front load MDE2400AZW takes forever to dry stuff. A regular load takes 1 1/2 hrs to dry,but the heat is on, and it seems to work.
Make sure the lint trap in the door is clean. It has a plastic cover that opens. Disconnect the venting at the rear and run a load, if it works you have a restriction in the hose after the dryer or in the wall past the hose.
Dec 01, 2009 | Maytag MDE2400AYW Neptune Electric Dryer
Dryer heats but doesn't dry
Sounds like it is only heating on "low". The problem is most likely a thermal limit switch/thermostat which is bad.
Apr 21, 2009 | Electrolux Dryers
Dryers Logo
201 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
