Question about HP LaserJet 3055 All-In-One Printer
Please help me to to install my printer
I could not install 3055 printer to my computer because it requires from me while installing uniser.dll file so, I am trying to write it but could not. If it is possible could you please send me good setup version of the HP Laserjet 3055 printer. Thanks alot to you for your help!
  • hassan 510 Jun 23, 2008
    i lost my software and my computer did not recognise it ;could you please send it to rectify that problem
    Scholar:
  • 107 Answers
Hi if u want Drivers for the Hp 3055 all in one
please use link below select the operating system & download it
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1140780&taskId=135&prodTypeId=18972&prodSeriesId=1161389&submit.y=10&submit.x=5&lang=en&cc=us
there is Drivers/software &firmware also available
if this information is useful for u please rete me ......
Posted on Jun 11, 2008
  • Techpoint
    Techpoint Jun 22, 2008
    friend u r not Rate me for this solution for long time .if u resolve problem please Rate me......
Hey can you help here please i've downloaded a video games and install it. But everytime i click for starting or opening a game...something pop up saying Missing required file ,for example " QtWebKit
Use torrents to download the game you will get a cracked one with all the files. . Search on Google. . Torrent for . . Download the torrent and open ir in a torrent client like uTorrent etc
Nov 07, 2013 | Video Game Consoles & Games
I have Hp Laser jet 3055 can install only the printer under windows 7, but unable to install the fax facility.Please help.
Then please navigate to www.hp.com, click on support and type the model details e.g HP Laserjet 3055 all in one printer and select your computer operating system type to download the full drive for all your printer facilities.
Thanks
May 18, 2011 | HP LaserJet 3055 All-In-One Printer
I am not able to install POP sands of time on my laptop (windows 7 premium) it shows some error related to some dll installation please help
Does the error say that the dll is missing? Then it's simply a case of installing the required dll onto your PC. For a good guide which shows you how to find the required dll then install it, go to http://www.makeuseof.com/tag/how-to-fix-missing-dll-file-errors/
Aug 17, 2010 | Ubi Soft Prince Of Persia: The Sands Of...
Error Code: 2753 " Fatal Error or error MSI.dot4msi"
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
solution 2>
complete uninstall printer software from computer.
run uninstall L1 L2 L3 L4(if not an hp computer).
run same uninstall l1l2l3l4 from 7z..folder or hp folder from temp if availalbe.
then clean from add remove programs/program and features.
then clean from cleanup utility all hp pritner related entries.
then clean temp folder. clean recycle bin.
delete c:\program files\hp and hewlett packard folders (if not an hp computer). on hp computer delete digital imaging bin folders.
delete following folders from following locations-
C:\windows\System32\Spool\Printers and deleted entries inside it
C:\windows\System32\Spool\drivers\w32x86\*.* deleted entries inside it
C:\windows\twain_32.
cleanup from regsitry--
plz make back up for registry first.
>> hklm/system/current control set/control/print/environment/windowsNT(x86/64)/drivers + processors delete all pritner entries from there.
>> hklm/system/current control set/enum/usb/vid_000,vid_003 delete.
>> hklm/system/current control set/enum/usbprint delete pritner entries.
>> hklm/system/current control set/control/print/monitors/hp standard tcp/ip ports/ports.
>> hklm/system/current control set/control/print/monitors/standard tcp/ip ports/ports.
>> delete same ports from printers and faxes/pritners pritner properties ports
>> hklm/system/current control set/control/print/monitors/hpz..
>> hklm/system/current control set/control/print/providers/lan man settings.
>> hklm/SYSTEM/CURRENTCONTROLSET/CONTROL/PRINt/PRINTERS
>> hkey_Current_User\Software\Hewlett-Packard
>> hKey_Local_Machine\Software\Hewlett-Packard
>> HKEY_USERS\.DEFAULT\Software\Hewlett-Packard
>> hkey_current_user\software\hewlett packard delete if not hp computer.
>> hkey_curent_configuration/system/current control set/control/print/pritners.
then go to msconfig
make it selective startup disable all microsoft services except hp services. hide all microsoft services. disable all startup tab apply restart.
after restart install cue version 12 officejet pro 8500 or 6500.
then run msiexec.exe /unregister then msiexec.exe /regserver cmd commands.
then install software from downloaded version of original pritner install only basic drivers first and imaging devices only and use solution center 12. cue 12.
issue resolved.
Jun 19, 2009 | HP LaserJet 3055 All-In-One Printer
Error 2753 HP3055
My Scenario:
OS: MS Windows XP SP3 [Version 5.1.2600]
Printer: HP LaserJet 3390 (AiO) (Firmware datecode: 20070331)
Printer Connection: Connected via Ethernet with a static IP address
HP Driver Version: v4.0 (hp_LJ3050-3052-3055-3390-3392_Full_Solution_AMWE.exe)
Ran into same error that everyone else is experiencing. (see below)
Now Launching=X:\hpzmsi01.exe -m dot4msi -l XXX -f X:\DIVins??.DAT
Error message received: The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2753.
X:\HPZBDI32.msi failed with return code 1603
MSIInstall() failed with 1603
Exit code=1603
After debugging HP's installation scripts for 2 days, here is the cause & solution I identified to this specific install error. Once I got passed this error, everything installed without error and all functionality was working properly (including scanning!).
BACKGROUND:
Microsoft Installer (MSI) error 1603 is simply a generic "A fatal error occurred during installation" -- see http://msdn.microsoft.com/en-us/library/aa368542(VS.85).aspx. This is basically MSI telling you that something very bad has happened during the installation. In order to get more details, you can turn on MSI debug logging by following this MS Knowledge Base article (http://support.microsoft.com/kb/223300).
The MSI error code 2753 is the code for "The File '<file name>' is not marked for installation.". This error can be triggered by many scenarios, but usually, it has to do with the actual installation script not properly checking for the existence/non-existence of an installation file and then not marking it for either installation/removal. I know this sounds confusing, and it is. If your curious about all the possible causes, just Google for "msi 2753 not marked for installation" and you'll see lots of results which you can peruse for your own enjoyment.
In order to identify what was causing these 2 errors, I enabled debugging for MSI via the aforementioned MS KB article
CAUSE:
SOLUTION:
Steps:
If all goes well, the install should now run without any issues.
Hope this helps since many people (including myself) have spent a lot of time (and HP Support chats) trying to find a workaround for this issue.
If you find this solution helped you out, please feel free to make a small donation to my PayPal ;)
Jun 26, 2008 | HP LaserJet 3055 All-In-One Printer
Printer driver
SOLUTION FOR HP 3055 SOFTWARE INSTALL ERROR!
THE METHOD:
Search for file "DPINST.LOG" on your computer. This will show you specifically what ERRORS are taking place. After three seperate trial and errors I found out that three different files are missing from the software package downloaded from the HP driver support site. http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1140780&prodTypeId=18972&prodSeriesId=1161389&swLang=8&taskId=135&swEnvOID=228
"HP LaserJet 3050/3052/3055/3390/3392 PostScript Print Driver Package" ~364mb
MISSING FILES:
UNIDRV.HLP
UNIDRVUI.DLL
UNIRES.DLL
FIND HERE:
http://www.filewatcher.com/m/UNIDRV.HLP.15343.0.0.html
http://www.dlldump.com/download-dll-files_new.php/dllfiles/U/UNIDRVUI.DLL/5.2.3790.120/download.html
http://www.dlldump.com/download-dll-files_new.php/dllfiles/U/UNIRES.DLL/5.2.3790.120/download.html
STEPS:
Download missing files then copy to the unzipped software folder. Which is most likely
"C:\hp_LJ3050-3052-3055-3390-3392_Full_Solution\"
Jun 24, 2008 | HP LaserJet 3055 All-In-One Printer
Error
First I had to find out where the error message came from (scan in my case, see the description of my problem). Apparently Win XP, Me and 2000 have a security function that doesn't let you overwrite existing twain and/or twunk files.
So you have to install these files manually:
Search on the installation CD or in the unzipped downloaded full solution the folder setup\scan, there you'll find the file data1.cab.
Doubleclick it and extract the following files to a temporary folder:
F1922_TWUNK_16.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892
F1923_TWUNK_32.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892
F1928_TWAIN.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892. F1939_TWAIN_32.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892.
Rename these files to twunk_16.exe, twunk_32.exe, twain.dll and twain_32.dll respectively
Copy (and overwrite if necessary) them to the Windows directory (c:\winnt in my case)
Now you can re-install the complete HP software again, in my case it worked and I'm now able to fully use my CM1015 multi-function printer!
Dec 12, 2007 | HP LaserJet 3055 All-In-One Printer
Fatal error installing HP 3055 all in one
OK, here is my debugged/tested solution.
I know your error refers to a different installer MSI file (CIOUM32.msi) but the installation component in your log file (ipm12.A4B24390_80AD_4BAF_B8FD_C670FE0DB586) is identical to the one that was giving me trouble as well (i.e. points to the same service/file). So it is definitely worth a shot to try this solution out as it will only take a few minutes.
My Scenario:
Exit code=1603
BACKGROUND:
CAUSE:
SOLUTION:
Steps:
Dec 08, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
141 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
