Question about MSI KM4M-L Motherboard
Graphic card problem
You told me maybe its with the power, yes there is a port like the one next to my IDE cable in my hard disk, but the fan on the graphic card is working but my monitor says NO SIGNAL. If i try to plug the cable on the graphic card and if its not good will be the card damaged?? ( The graphic card is an NVIDEA 6600 256MB 128 Bit)
  • BIOS21 Jun 15, 2008
    Thanks a lot!! It works!!!
  • Anonymous Jul 27, 2008
    my graphic card do n't display any image also the monitor no signal
    President:
  • 2,351 Answers
Hi BIOS21, I know this much. I know you're motherboard can not use a PCI-Express video card. You're board can not support SLI. I know from looking & reading the manual for the MSI KM4-L you're board supports an AGP video card. I also know some AGP video cards need extra power for them to function. This varies from card to card. You did find an open power port on you're AGP NVIDA 6600 256MG 128bit card. So plug in the power cord. Every AGP card receives power from the AGP port. Enough to run the fan. Depending on the card it may also need more power provided by the system to function. This is you're case. The power connector would not be on the card if it was not needed. Other AGP cards use the same power cord as a floppy drive. (Just so you know).
Mike
Posted on Jun 11, 2008
  • Mike Peluso
    Mike Peluso Jun 11, 2008
    You're video card did come with instruction. You should go over those instructions.
My motherboard cant detect hard disk ,disk driver and when i start my computer it dint show HDD LED light (red light) and it show "No Hard Disk detected, Please insert Hard Disk and Press Enter. i...
THere maybe a problem with the SATA/IDE connection.Check the connection first using another cable or try to another port. If it doesn't work, try the drive on another PC. Check for the power connection cable as well.
Let me know if this works,
levibit
Dec 17, 2010 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Ive built my first pc and all went well until the message no hard drive detected comes on all parts are new so any help would be great in fixing this thanks dave
Verify that the hard disk is connected on both data and power cables and is receiving power (it hums at startup); also that the proper EIDE or SATA slot on the motherboard is used, and properly jumpered (e.g. a SATA 2 disk on a SATA 1 configured port is likely to malfunction).
Check that the BIOS is configured to autodetect the hard disk type, and is using the appropriate adapter (EIDE or SATA port), without RAID options or such.
In a pinch, try also ignoring the motherboard labels (e.g., plug the hard disk on the fourth SATA port instead of the first -- the mobo numbering is not always the "logical" one, even if it usually should be.
Jul 02, 2010 | Computers & Internet
IDE Ports not working on ASUS P5LD2-VM Mobo
Good Day sir, hi, Have you tried to enable the IDE on BIOS setup. If the Bios setup did not solve the IDE problem, check the IDE port of the HARD drive, check if there are bent pins.
If still wont work, you can buy a PCI to IDE/SATA card, this is an expansion card in PCI format with IDE and SATA port.We use this card incase the IDE or SATA on the motherboard gets bad. Connect it on the available PCI slot. Then connect the IDE cable of the Hard disk to this card. Thats it.
Nov 10, 2009 | ASUS P5LD2-VM Motherboard
Primary IDE port does not work. My main hard disk drive and DVD writer drive are connected to the Secondary IDE port. If I move them to the the Primary IDE port, both the drives do not get detected at all....
Good day sir, there are several way to connect an extra IDE if the motherboard is full:
  1. Buy a PCI to IDE/SATA card. Check your local computer dealer if there is available.
  2. Buy an external USB to IDE Hard disk enclosure.
Of course, these are things to buy, but check first the CMOS setup if the Primary IDE is enabled on your PC.
Oct 12, 2009 | Intel D865GVHZ Motherboard
My fujitsu laptop recently had a new hard drive installed in it ,but i want to transfer the data i have on the old hard drive that was removed from laptop to my new hard drive. I bought the all in one...
The Coolmax adapter is an USB hard drive adapter that can connect various types hard drives to your computer. This is used for testing and and transferring data to and from hard drives connected to the computer via the computer's USB port.
This Coolmax USB hard disk adapter can connect a 2.5-, 3.5- and 5.25-inch IDE or SATA hard disk to a PC. The black adapter box connects the hard disk, while the secondary power plug/adapter powers the drive. In the case of smaller notebook or SATA disks, the power cable is plugged directly into the adapter (as opposed to straight into the IDE hard disk).
The red USB cable, meanwhile, can be used to power hard disks directly from the host PC's bus via another USB port.
Connect the hard drive to the adapter as detailed above, power up your computer and plug the Coolmax USB cable into the conputer's USB port. The computer will detect and see this as an external drive, most likely as a E drive (the next drive letter that is available). Click on this drive and open to open the folder/s where your data is stored then select the folder/s and/or data and copy them, then open the hard drive on the computer and paste the folder/s and/or files onto the new hard drive.
Sep 29, 2009 | Fujitsu Siemens Computers & Internet
Dead hard drive- does not power up, no lights or fan... What now?
yes, you can easily identify the motherboard cause this is the biggest part of a computer where the memory or ram, graphic card,processor, hard disk sond card sts cable and everything is connected to this board. that is why its called the "mother" board.
Jul 11, 2008 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Installing 2 hard drive
if ur hard drive is IDE port then
attach the 1st end of ide cable to the motherboard and second end of ide cable {IDE1}to the hard disk {make this hard disk MASTER by change the jumper settings }
attach the second hard disk to ide cable {IDE 2} make this hard disk SLAVE by remove the jumper from hdd
Mar 20, 2008 | Computers & Internet
MSI KM4M-L Motherboard Logo
85 people viewed this question
Top MSI Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
