Question about Zebra LP 2844 Thermal Printer
Printer Clicking When zebra printer is printing a horizontal line across a label it makes a very noisy clicking sound and heats up very hot after much use. I have replaced this printer 3 times and the same problem comes back is this a common fault with an LP2844 or any suggestions you have what could cause this It is installed on a Windows 2000 environment using Parralel connectivity and installed using Generic, Generic text only windows drivers
    Novelist:
  • 148 Answers
What kind of printing job are you trying to do?
Posted on Jun 28, 2008
Zebra gk420d not printing shipping labels properly on ebay
You have to go to printer drivers on your Operative system, then open printer properties, general tab, you will be able to check the horizontal/vertical setting of the label there.
Mar 02, 2014 | Zebra Gk420d Direct Thermal Printer -...
Zebra printing out blank labels.
Thermal printers need to get hot to heat the special paper, which when heated prints an image.
Click here for a more detail explanation.
Usually the thermal head dies, it can be repaired, claim warranty support.
Check if your thermal printer is getting hot, if not then confirms above.
Take care!
damnor01
Jun 02, 2011 | Zebra 140XiIII Plus Thermal Label Printer
My Zebra Z4M Plus printer is printing, but some part of the label is missing. The printing is good, and starting from a certain point, nothing is printed. There is a straight line (approximately 2cm from...
if is line across all the label, need printhead replacement, but first clian the printhead and the rollar, then check if the length and the with is the correct from the driver, last solution, resect the printer to factory defult.
Nov 04, 2010 | Zebra Z4Mplus Label Printer
The printer will print one label correctly, then feed out a blank one. when the next label is printed, the printer reverse feeds the blank label into the printer to print the next one, but not far enough...
This sounds like a size issue, meaning that your label has too many lines and that kicks to the "next page".
Look for too many line items on first label.
Oct 06, 2010 | Zebra Z4M Printer
MY ZEBRA LP 2844-Z IS PRINTING BLANK, WHAT COULD BE THE PROBLEM?
Since the LP2844 is a direct thermal printer, the first thing to check is to make sure you have direct thermal labels - regular label stock won't work. Just quickly scrape your thumbnail across the label, the friction will cause a black line if the label is direct thermal.
Aug 11, 2010 | Zebra LP 2844-Z Thermal Label Printer
Zebra LP2844 print is wrapping horizontally
Update the printer firmware, download latest printer driver from zebra website.
Oct 01, 2009 | Zebra LP 2844 Thermal Printer
Printing solid black across the label.
Sounds like a defective printhead.
Reinstall the old one to see if the problem remains or not.
Steve
Jun 25, 2008 | Zebra 105Se Thermal Printer
Printing but not able to read bar code with scanner
make the pause test (press pause and turn on) press Pause , 5 sec. if print qualiti is ok and you dont see some lines across the print, the problem is not the printer.
if you see some withe lines across the print, you need to replace the print head.
Apr 15, 2008 | Zebra Z4Mplus Label Printer
Poor Quality (black line)
Check the temperature settings. If all of the text and barcode is clear and not fuzzy, check the platten roller for low areas, cuts, or other deformity.
Dec 12, 2007 | Zebra 170XiIIIPlus Thermal Label Printer
Zebra LP 2844 Thermal Printer Logo
293 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
