Question about RCA HDLP50W151 50" Rear Projection HDTV
Hplpw175x7 How do I find out which light assembly my tv uses?
  • RCA Master
  • 8,617 Answers
If you can post the full model number with all the suffix letters on the end I can locate the correct one from the suffix letters
Posted on Jun 11, 2008
My tv is on standby and will not turn on
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service
Jul 20, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
NEED TO KNW HOW TO REPLACE NO 2 FAN ON A SAMSUNG DLP TV HL-S50786W
Here is Fan part# BP31-00024A. Search google, find it at various places.
Light engine assembly has to be removed. This involves unplugging various connectors between processing/control chassis on the left side and engine assembly on the right side. Mounting screws on the top and bottom of engine assembly. Then remove light engine assembly completely from the TV. Fan#2 is the lamp cooling fan and is located beside the lamp assembly.
It is not too complicated if you draw a picture of where all the plugs are removed from. If one plug is not put back correctly, unit will not work. Usually a tight fight sliding out the engine. Plastic cable tie-down between the 2 assemblies can be cut and discarded, this makes re-installing light engine considerably easier.
Cheat the cabinet safety switch with tape or stretch connecting wire across it to hold it in "on" position for test after reassembly.
Service cost may be $150-$200 if you don't do it yourself. We do it in most Canada cities.
easyab
Apr 22, 2010 | Samsung HL-S5087W DLP TV
My samsung lcd tv is clicking and wont turn on
Sounds like a warped color wheel which is part of the light engine assembly. That is the assembly which has the bulb.
Jun 12, 2009 | Samsung DLP HL-P5663W 56" TV
Mitsubishi wd 62725
Color wheel - light engine assembly is bad, must be replaced. New assemblies not available, try ebay. You''ll need technical expertise or you'll need to hire a tv service shop. MOst shops will NOT sel you a used color wheel assembly, but they will install one if you buy it.
Jan 20, 2009 | Televison & Video
Hplpw175x7
youre welcome let me know if I can assist you further.
Jun 11, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Hplpw175x7
I need to know which type lamp assembly you use there are two types type A and Type B. Let me know and I will post a link where you can get a new ballast circuit.
Jun 10, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Hplpw175x7
If the color wheel was the only problem the power supply should be good
Jun 02, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Hplpw175x7
I would try the power supply first as the ATC336 has a history of the bad power supply boards.If the power supply doesnt fix it then I would think it may possibly be the ballast
May 30, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Hplpw175x7
Thats a good price as long as they guarantee that it works. How were you able to pull a capacitor off without un-soldering it?
Hplpw175x7
Try replacing these 4 capacitors on the power supply first, as thats only abou 5.00 at radio shcak and that may solve your problem as I have had alot of the RCA DLPs have these capacitors go bad. They are capacitors CP624, CP639, CP641 and CP644 try replacing them first as you may just end up not having to pay out alot of cash needlesly. Please let me know if you need further assistance or how changing the capacitors worked and we can go from there to get the set up and running again.
May 29, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
RCA HDLP50W151 50" Rear Projection HDTV Logo
32 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
