No cold water
Maytag ,I thoink wire is off
  • 868 Answers
Check water to see if its turned off
Posted on Jun 11, 2008
Inlet Valve
Check the wires or problem with the board
Feb 05, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag neptune washer can not change the wash cycles
1) test the timer probably faulty,tight connection wires see the diagram how to test,and see the diagram in line black, how the contacts from timer control everthing in the washer.
2) problem of cold water, is the cold water turn on? consult your owner manual for to see if acting abnormally
3) check the selector is o.k
God bless you
Jul 18, 2012 | Maytag Neptune MAH6500A Front Load Washer
Maytag Model A511 Cold water will not fill for wash or rinse cycles. Water is on, hoses are straight, and filters are clean. Water valve checks out OK (110V across terminals on both solenoids, slight...
Hi and welcome to FixYa, I am Kelly. Your testing of the solenoid was good. My question is this... when the timer stops do you still get the magnetic attraction? If I interpet this correctly; the answer is no. So we are dealing with a power problem. Power comes from the timer straight to the COLD solenoid. (Blue wire)
http://www.appliancepartspros.com/sect/i/e/j/iejjijajjf.gif (wiring diagram)
Power comes in to the TIMER from the lid switch on the red wire of terminal 12. It is supposed to be then routed to Yellow wire terminal 3 and the internal contacts of the timer (buss 14) connect power to the BLUE wire 5B. If your not getting power at the timer 5B / Blue wire lid closed the problem is inside the timer. Just make sure the timer connections discussed above are correct ON the timer.
Maytag PN 2.5639 timer NEW price is around $147.00 for factoryoriginal Used Avg $35.00. Your choice if you need a timer.
2-5639 +Maytag (Net image search)
Thanks for choosing FixYa,
Kelly
Jul 19, 2011 | Maytag Washing Machines
My maytags cold water won't pump?? tanya
If you mean you have no cold water entering machine/most likely cause is plugged screen at water inlet valve. shut cold water valve of remove line at washer clean screen inside valve put back togeather test for leaks test for cold water good luck..................................
Mar 02, 2011 | Maytag Washing Machines
No cold water when trying to use it nothing
Your cold water solonoid is not working and needs to be replace. Very easy fix. Just follow the cold water supply tube and you will find it connected to a plastic mechanism with a couple of wires to it. Most of the time the hot and cold solonoid are together and you need to replace both at the same time. When installing make sure you test for any leaks. Good Luck
Jan 07, 2011 | Maytag Atlantis MAV6451 Top Load Washer
Maytag performa PAV2200 - cold water fill does not work, but hot does
Check the solenoids at the water inlet valve. They can be checked using a multimeter or ohm meter for continuity. If either solenoid has none, it is defective and the water inlet valve assy will need to be replaced. I am attaching a photo for reference. Hope this helped and best wishes.
Aug 04, 2009 | Maytag Performa PAV2200
Cold water trickles very slowly hot water has plenty of pressure it is a maytag pav2300 how can i fix this problem
1. Check cold water hose for obstructions
2. Check cold water spigot for proper water volume
3. Cold water electronic valve may be failing, easy to replace
Apr 15, 2009 | Maytag PAV2300 Top Load Washer
Cold button is pressed and warm water comes out
water valves might be wired wrong or water select control is bad or wired wrong
Apr 10, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Cold water fill
You need to open the back and follow the cold water hose to the solenoid. Tap the solenoid a few times wile you are trying to use cold wated. If not check for power at the 2 wires that go to this solenoid, if you gout power then you need to replace your cold water solenoid. I hope this helps. Don't forget to rate my answer, thanks.
Feb 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
