Question about Panasonic GigaRange KX-TG2432 Cordless Phone
Display is not working properly
The phone is working OK except that there is absolutely no text on the display for the second handset. I am getting dial tone, I can receive and send calls, I can also hear keypad sounds but there is NO VISUAL on the display except for the background light.
    Novelist:
  • 201 Answers
There are 2+ possibilities.
If the LCD went out after a bad fall you may have cracked the display behind the scenes where you can't see it.
If the phone has EVER been exposed to water or high humidity.... (even 2 years ago) then corrosion in the connector for the LCD may have grown to the size to effect the operation of the LCD. If you feel comfortable taking the phone apart and removing the LCD you may see the corrosion... you can clean the LCD cable with isopropyl alcohol and possibly help the connector itself using a few drops of isopropyl and a tooth brush. If you do not visually see any corrosion then don't clean it... it would have to be visible to stop the LCD.
These LCDs can go bad on their own but it's rare.
Posted on Jun 12, 2008
Handset display says "Connecting" I can't deregister. How can I get the handset to display "not registered"?
The procedures to deregister are, of course, specific
to each make and model number of cordless phone.
All of them are a LOT more involved than simply
removing the battery.
For some AT&T, VTech, Uniden, & GE model numbers
you might try the following:
For many AT&T models it is simple:
1. When the handset says "Connecting..."
enter *331734 [menu]
it will soon (chirp) and display "Not registered"
For many VTech models it is a bit more involved:
1. Start by taking off the battery compartment cover.
2. press [menu]
3. scroll up/down to "Settings"
4. enter * 7 8 9 0 #
5. if display reads "Test Base",
scroll to "Test Handset", press [select]
scroll to "next page", press [select]
6. scroll to "Register Clear?", press [select]
7. display asks "Confirm?" or "Register Clear??",
press [select]
8. display reads "Ok" (chirps), press [ off ]
9. UNPLUG THE HANDSET BATTERY
(this is why the cover is off)
10. Wait ~30 seconds, re-connect the battery &
replace the cover
11. display reads "Not Registered"
For many Uniden models:
1. Press and hold the [END] and [ # ] keys at the
same time, after a few seconds the display reads
2. "System Reset, Deregister Handset"
3. scroll to "... Base Unavailable"
press [SELECT]
4. Handset (chirps)
press [END]
5. display reads "Not Registered, Place in base..." =====================================
For some GE models:
1. press "program[mute]"
2. scroll to "Handset Setup" press "program[mute]"
3. scroll to "Deregistration" press "program[mute]"
4. scroll to "Yes" press "program[mute]"
5. display reads "Not Registered"
Once you have the handset displaying "Not Registered"
you can follow the User's Manual instructions to register
the handset.
The model number for your cordless phone is shown on
a small sticker underneath the battery in the handset --
enter this number at www.manualslib.com to get a free
copy of the User's Manual if you need it.
Mar 14, 2016 | Lands Phones
HandsetS #2 and #3 work properly. Handset #1 has a display screen with correct datet and time -- but no dial tone, How can I fix this?
This sounds like Handset #1 has lost its "registration" with
the base. De-registering & re-registering is often easy.
First, be sure the handset battery is well charged as a
weak battery will interfere with the registration process.
Then try this ( 'works for the D1680, D1481, & similar):
To deregister the handset:
1. Press and hold the [END] and [ # ] keys at the same time,
after a few seconds the display will say
press [SELECT]
scroll to "Base Unavailable"
press [SELECT] (chirps) press [END]
display reads "Place in base..."
Next, to re-register the handset:
2. Set the handset into the base cradle and wait,
within ~30 seconds the handset should display
a "Handset #" and be good to go.
Nov 26, 2015 | Uniden DECT 6.0 Cordless Telephone...
I have a vetch mod# CS6114 I checked the base unit and it gets power to charge phone but I can't get a dial tone. I even hooked up to another line and still won't work.
This sounds like a registration problem, the
handset must be de-registered from wherever
it thinks it is and then registered to your base.
( I ). First, to de-register a cs6114 handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll from "Test Base" to "Test Handset", press [select]
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( III.) To register the cs6114 handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
NOTE 2: Some cs6114 bases do not have the "In Use"
lamp indicator. To register the handset simply park it
displaying "Not Registered" in the base cradle and wait
for the registration to occur. Pressing # as above may
be required, maybe not.
Good luck !!
Feb 12, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
No display panasonic cordless phone
The display on that particular phone may have to be replaced.
Dec 28, 2013 | Lands Phones
Handset display not working
Display can be damaged change ur display install new display
Jul 11, 2009 | Vtech V-tech Speakerphone
Display on phone just started showing all info backwards
This issue is more like hardware issue. LCD cable cold solder, mabye need to open the handset ,the check if the LCD cable connection is ok or not.
Jan 21, 2009 | Uniden Cordless Phone
Display backlit but does not display text
check you rbattery or cell .
reset your phone settings
Oct 09, 2008 | Panasonic KX-TGA560B 5.8 GHz Cordless...
NOT SUB on head set
I had the same problem to fix it you press the menu button then scrool up untill you see REGISTER.
Press OK the display shows "BS 1 2 3 4" Enter the number of the base unit you wish to register the handset to.
The display shows "PIN code" (original code 0000) press OK the display shows "Search X (where 'X' is the number of the base you are registering to)
Press and hold the "page button" on the Base unit untill it beeps twice then after a few seconds the phone should work again.
Mar 14, 2008 | Cable_and_wireless CWD4901 Cordless...
Disfunctional Handset
has the secondary handset ever worked. Reason I ask is that it happened to me with a new addtl handset and the problem was that I did not remove the small piece of paper between the handset and the battery which caused only distorted figures to display on the LCD of the handset.
Nov 22, 2007 | Vtech VT 2461 Cordless Phone
Handset voice very low and LCD display is blank
My 1740 handset volume was also low. As a shot in the dark I changed the speaker and it fixed the problem. I got a new speaker from www.panasonic.com .
Feb 11, 2007 | Panasonic KX TC1740 Cordless Phone
Panasonic GigaRange KX-TG2432 Cordless Phone Logo
280 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
