Question about Maytag Performa PAV2200
How to take off water valve
Help me
  • M Linden Jun 11, 2008
    Tanx alot
  • 868 Answers
On the back un do both hot&cold hoses.remove the screw that is on plate where the 2 oses were.Pull out the water valve&rep.lace it
Posted on Jun 11, 2008
Hi, the drawer on my tumble dryer is not filling with water and the water light is on, the water must be somewhere....help
1st remove the hoses and check the filters in the hose and in the water valve.
if water valves r open and machine is in fill mode then the water valve is defective.
Timer may not be activating valve but if u can't monitor the voltage on the valve replacing the valve is cheaper than the timer.
Dec 09, 2014 | Dryers
Mine DU1055XTSS3 is not taking on water after initial rinse.
test this steps and fix it. GOd bless you
Water Inlet Valve
The dishwasher has an electrical water valve called a water inlet valve. If the dishwasher won't fill with water, the water inlet valve might be defective. These valves are not repairable and will have to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Float
The float assembly is normally inside the dishwasher near the door on the floor of the dishwasher. If something gets stuck underneath it and holds the float assembly up, the dishwasher won't fill with water. If the float assembly moves freely up and down, the float switch might be defective.
Float Switch
The float switch is actuated by the float assembly. It is a protection device designed to prevent the dishwasher from overfilling. If the dishwasher won't fill with water, it may be because this float switch is defective or stuck.
Water Supply Problem
The dishwasher is connected to the hot water supply from the house. Check to be sure the household water supply valve is turned on. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. The water supply line may need to be removed from the water inlet valve of the dishwasher, then run some water into a bucket to see if there is enough pressure. Be certain to turn off the water before working on the water line.
Jul 30, 2013 | Dishwashers
Does not fill with water.
follow this steps and fix it. God bless you
Water Inlet Valve
Float
Float Switch
Jul 08, 2013 | Thermador 24 in. DWHD64CS Stainless Steel...
Vacuum valve leaking water
Question is unclear.
What is a vacuum valve?
You posted under electric water heater.
Water heaters are associated with TP or 'safety overflow' valve, water shut-off valve, tank drain valve, pressure-regulating valve, mixing valve and possibly a few other plumbing valves.
Vacuum valve implies that a compressor is creating pressure on one line while creating vacuum on another line. I don't know of a water heater that uses air compressor.
Open following link to help troubleshoot leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
Jul 23, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Dishwasher was starting up but no water enetering and would beep as if cycle was completed within a few minutes. we took the water hose off and water is flowing fine. now when we switch it on it just beeps...
you would check the water inlet valve first to assure that you have power to the valve and secondly to the solenoid on top of the valve if you have water going to the inlet valve but it wont go past the valve then replace the valve if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Apr 16, 2011 | Dishwashers
There is a hot water valve & a cold water valve on the Dexter T300 machines but it is a 2 coil valve. does the hot water valve supply only hot water or does one side provide water to perhaps the...
supplies hot water when needed, cold water when needed. and then warm water when needed. so the second coil is for warm water. it basically mixes the hot and cold water.
Mar 17, 2011 | Washing Machines
Washer machine filled up with water all night with door open? I have a mess of water in my basement and no water pressure.
If water comes into washer with no power to it and water valves are turned on then you have a bad water inlet valve in washer. Try unplugging washer and turn on water valves see if water comes in note may be small amount (but it does add up if it runs all night) if it does your water valve is bad..Replace.Sometimes the vales can stick open a little it is caused by buildup inside valves from minerals and other items in water....Note make sure if you replace valve that you have sediment screens in your water inlet lines on washer that will prevent items in water getting stuck in valves and keeping them open..If you need more help please ask if I helped you please vote Thanks and good luck
Feb 05, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Where is the bypass valve on the water heater?Just bought the trailer and unable to fill water heater?? Any help
Look at back of water heater, valve(s) should be back there. You want valve open to bottom (cold in) and also valve open to allow hot water out at top. Any valves in between, closed.
May 30, 2010 | RTO Atwood Water Heater - 6 Gal LP
My Maytag side by side has a water dispenser however the water trickles out what is wrong?
The problem more than likely is with the water valve.Side/sides have a double water valve with one inlet and two supply outs .The water dispenser valve is probably clogged with debris.Turn off water to valve, remove and clean. If this does not help then valve is probably faulty. Hope this helps
Jul 31, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Figidaire model frs26r4cbb side by side dispenses water and makes ice if i poor water into the tray but will not fill on its own
There is a valve that allows water to go into the trays and generally it is behind your fridge where the water line connects into the fridge. This valve is generally the problem but not always. Here is a link to a site that gives you drawing on your fridge and also the parts to repair it if need be. I hope this helps.
http://www.appliancepartspros.com/partsearch/
Jul 28, 2009 | Refrigerators
Washing Machines Logo
20 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
