Fills up too much
Maytag keeps filling ?
  • M Linden Jun 24, 2008
    replace the water valve
Inside the top of the machine, check for a pressure sensitive switch connected to a tube which runs down to the drum. If the tube is intact, the pressure switch may be faulty.
Posted on Jun 11, 2008
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
The tub starts to fill then it shuts off wont complete wash cycle
Depending on the model, it could be a few things:
Fill level sensor
door switch
timer
control board
The model really matters, as Maytag has been making washers for 70 years. uploadserror please enter an image url (gif, jpg, png).
Dec 09, 2014 | Maytag Washing Machines
My washer fills with water and keeps filling doesn't stop on the selected water level for the load. It doesn't wash because the water keeps filling. What's wrong with my washer? Help please (Maytag...
The problem is simple and easy to fix. Your washer has a tubing which runs from the base of the tub to the water pressure switch. It might have vibrated loose from the switch, or their can be some sediment in the tub. Blow out the tubing and reattach it securely to the switch and pump out the water in the tub. Then try it again. I wrote an article about this:
Help my washer is overflowing !!!
Jan 07, 2011 | Maytag PAV2300 Top Load Washer
WATER KEEPS FILLING, doesn't recognize various level setting and keeps filling until it overflows
If it is filling with just water then your problem is probably in the solenoid valve body that is located right where the hoses hookup.There probably is dirt underneath the valve and it won't close properly. Or it just plain went bad and will not close.
Try replacing it.
Mar 28, 2010 | Maytag Atlantis MAV8551 Top Load Washer
I have a stackable Maytag. The water will not
I had a similar problem I just fixed. There is a fuse inside that keeps the water from filling if it's blown. Might try changing that first.
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag legacy series tub wont fill
Your drain hose is too low or there is no air gap where the hose enters the drain line.
This causes the water to siphon out as it fills.
Mar 08, 2009 | Maytag Legacy Series Top Load Washer
My washer starts by turning the water on, but it won't stop filling with water
if you unplug the machine does it still fill? If it does then the fill valve is bad.
happens alot when machines are on well water.
Oct 31, 2008 | Maytag Neptune MAH5500B Front Load Washer
Overfill
The vacuum line in side of the controls may have came off that is what happen to me it plug behind the switch
Aug 10, 2008 | Maytag PAV2300 Top Load Washer
My washer will fill up, but will not spin or rinse. The belt also keeps slipping off
it sounds like the bearing on the back of the drum have worn out and warped the belt wheel,does it make a loud noise in spin?let me know what you find-mike
Jul 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Leaky float valve
Teresa, the water fill is usually a timed fill and the float assy. is a safety device to cut power to the fill valve in the event the dishwasher keeps filling. ( In most models). Sounds like your initial fill is just above the float lever actuator and dripping. Check the level of the dishwasher to make sure that the water is not higher toward the front. Catriver..post back.
Feb 10, 2007 | Maytag 24 in. DWU7402 Built-in Dishwasher
Washing Machines Logo
Top Washing Machines Experts
