Question about Toshiba 42H81 42" Rear Projection Television
40WH08B hI, I have a problem with the above set in which the colours are mixing and the screen appears ghost. Any ideas Thanks Alan
  • Alan Robinson Jun 11, 2008
    The colours are all wrong and the the numbers are showing twicw as in like a ghost effect.
Is that a screen saver??
Posted on Jun 11, 2008
Holden statesman sle 1979 colour mulberry can you tell me the paint identification number Thanks Alan
Hi Alan Check all id Plates normally have paint code
(1) near front strut mounts (2) front panel top, in front of radiator (3) Firewall Panel across rear of engine (4) B pillers inside of front doors.these are the normal areas for id Plates. If no luck try car panel shop normally have colour cards to match paint with paint code. Good luck
May 25, 2017 | Holden Cars & Trucks
Olympus u820 image distortions colour and form
One answer time for a new camera the cost to repair is about the same as new.
Mar 15, 2017 | Olympus Stylus Stylus 820 ยต Digital 820...
Colour printing
Hi Alan,
Please ensure that the printer driver is set correctly.
Go to your Printer & Faxes menu, right click the C250, click printing preferences, click the Quality tab and make sure Colour is selected. Apply the changes and bingo!
The above assumes you are using Windows and a PCL driver.
Hope it helps
Regards
Taminol
Mar 05, 2010 | Konica Minolta bizhub C250 All-In-One...
Retaining image on screen
Ur Tuner Signal board is dying,must replaced this board to solved this problems.
Jan 16, 2010 | Panasonic TH-42PX60U Television
My LG rear projection TV RE40NZ60RB colour is ghosting with three colours separating. Colour converging does not rectify
There is a problem with the convergence circuit. It can be as simple as poor solder connections at the pins of the convergence IC or a defective IC. If you can solder, you can fix this yourself. Please confirm the model number of hte set and I'll provide the part numbers etc. required to resolve this.
Thanks,
Dan
Aug 20, 2009 | Televison & Video
Oki C3100 - v poor print quality
Hi Errol
The way to identifiy your problem is to send a full colour print to your printer and open the top just as the paper starts to come out . if you then remove your toner / drums for all the colours you can see the transfer belt if the quality of the image that you can see on the transfer belt is good and clear your problem is with the transfer form the tranferbelt to the paper and not any toner /drum issue and the most likley cause is the transfer belt itself "but before you relpace it remove it and clean around the electrical contact points and generally make sure the internals of the printer is free of loose toner .
Regards Alan (Alstech)
May 13, 2009 | OKI C3100 Led Printer
Celestial HD Digital Television Receiver DVB8800HD
It appears that the default output is set to component video by the manufacturer.
connect it to a suitable TV and change the output to composite and you'll be able to use it.
Jul 25, 2008 | Televison & Video
Various colours mixing on monitor
hi im wesley. please make sure that you keep speakers and things like that away from your screen and switch your screen off and plug it out for a few hours if it duznt come right its not magnet that caused it it might be settings of your vga card.
Jul 21, 2008 | Compaq Presario 5000 PC Desktop
Toshiba 42H81 42" Rear Projection Television Logo
46 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
