Recording from Sky+
HI,
I have a Techwood AEDVDRS7 dvd recorder.
I have tried to record a film from the Sky+ planner but I keep getting the following message " Paused for no stable video! Please check the connection".
I have checked scart connection on both the sky box and dvd recorder and, have disconnected and reconnected the dvd recorder.
Any ideas please?
  • Tobius Jun 13, 2008
    Thanks to GSAN and Guest for your comments.
    I appreciate there may be anti copying in place but, I have copied from the planner successfully before. I can't figure out why I have only just started to get this particular message. If it was copyrighted would it not just state that?
GSAN is correct anti copying measures are in place to stop illict recording or copying
Posted on Jun 13, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 106 Answers
Could be possible that Sky TV is right protected therefore making it hard or impossible to record.
Posted on Jun 12, 2008
  • Gerson War
    Gerson War Jun 13, 2008
    It could be that Sky is starting to add the copy protection or just certain movies/shows from certain produers. To make sure it is not your cables or recorder causing the problem, record from your airwaves (rabbit ears, local TV from the antena) to see if the recorder records as it should. Ifit does, then contact the Sky service to see if they have any info...it could be that a technician needs to maintain their antena or re-align their hardware to get a stronger signal.
Does anybody have advice for recording issues with a Techwood AEDVDRS7?
The dvd disks you're playing.... are they homemade or factory made recordings?
May 13, 2014 | Televison & Video
Copying from Sky Plus to DVD with Panasonic DMR-EX773
Go to planner...highlight the program that you want to copy.
Press right on the navigation keys then the green button then select.
When you are ready press select to start followed by record on your recorder...
Feb 21, 2012 | Panasonic Televison & Video
Recording from sky planner to dvd
Yep all you will need is a DVD recorder Philips do a good low cost version DVDR 3380 and a Philips DVD+RW ( this is the type that you don't need to finalize before you can use it in your PC)
All you have to do is make a connectiion to the video out of the Sky box using the suitable connection normally a SCART lead in to the EXT1 or EXT2 of your DVD recorder.
Play the Sky program in your planner and hit record don't forget to select the time you require 1 (HQ) 2,4 or 6 (SLP) hours. It will take as long as the program take to run to record it.
The best way to get the DVD-Video into your PC is to use the excellent TMPGEnc v4.0 Xpress from Pegasys use the Souce Video Wizard.
Then select the DVD-VR button this will read in the DVD content and then allow you to edit it and re-encode to almost any format.
If you select over 4 hours or recording most DVD standalone recorders will revert to Half D1 this equates to 360x576 instead of the Full D1 resolution of 720x576 (standard PAL for DVD-Video) you will need to use this filter to convert the half to full download it here Half D1 to Full D1
LOL
Sep 28, 2009 | Compaq Presario 5000 PC Desktop
DVD-VR320 combo DVD player
I think its the dvd players internal settings that need to be adjusted. If there is a menu set the sky box to the connection it is plugged into. Although this might sound strange some units when you connect them up will play fine through that input but unless the settings of the player is adjusted iut will record a blank screen because its default setting for recording might not be either the connection method you are using or the input you are using. I hope this makes sense.
Aug 26, 2008 | Samsung DVD-VR320 DVD Recorder/VCR
Pace Sky plus box
You have 2 choices, software reset or hardware reset. It's up to you what you try, but please read the advice in full before starting - if you break your box, please don't blame me!
SOFTWARE RESET
The following is copied from http://www.ecademy.com/node.php?id=73309
This is useful if your disk usage percentage doesn't go down even after clearing programmesfilms off.
The following is offered on an ADVICE only basis, take care when making changes:
WARNING following this advice is totally at your discretion and anything which happens to your digibox as a result is your responsibility, not mine. You will lose all recorded programmes from your Sky+ Planner.
Sky tech support can talk you through performing a system restore over the phone. To do this yourself, press 'services' on your Sky plus remote, then select option 4. Next press 0, 1, select - you should now see the engineer's menu. Choose option 8, 'Full System Reset'. The box will now take a few minutes to reset itself
Try pausing or recording again, and if the problem persists disconnect the digibox from the mains power. Press and hold the 'left' and 'right' navigation buttons on the front of the digibox whilst you reconnect the mains power. Continue holding the buttons in for about 20 seconds, and when the ring of light on the front comes on, press the 'select' button on the front of the digibox (between the left and right buttons you were holding). The Sky+ recording logo lights will spin backwards and, according to the Sky engineer, this will "clear the hard drive".
Once this is done, disconnect the digibox from the mains power again and this time press and hold the 'back up' button whilst you reconnect the mains power. Continue holding it for about 15 seconds until 3 lights on the front of the box come on and you get a full-screen message saying "Updating system software. Do not disconnect mains supply or satellite dish."
Leave the digibox doing its thing for about 10 minutes and it should be fixed! Try pausing and recording things again... hopefully you've just saved yourself £65
If you've not been so lucky, you'll have to get Sky to fix it for you. Some people report that if you ask to cancel your subscription Sky sometimes offer a free callout to fix the problem - you're more valuable to them as a paying customer than the cost of an engineer callout
Sky customer service's (seemingly unpublished) freephone number. You need to dial 0800 731 6965, then option 2, option 4 March 9, Sky have closed this Freephone number
HARDWARE RESET
Copied from http://www.digitalspy.co.uk/forums/showthread.php?t=484098
Full System Reset via front panel:
  1. Remove power at mains.
  2. Hold LEFT+RIGHT.
  3. Apply power, wait for ring to light.
  4. Release LEFT+RIGHT, press SELECT.
  5. Ring cycles backwards while disk is quick formatted.
  6. If format sucessful PLAY lights up, if not RECORD lights up.
  7. Box goes into standby - wait 30 seconds are wake it up.
Warning: Full System Reset deletes all your recordings and planner entries.
Aug 07, 2008 | Pace Type 30-0060 1121-0369 D1 .060 D2...
Watching another channel while recording
Hi there! Sorry but you can't unless you have My Sky/HD recorder. The sky decoder is simply a one channel watch decoder. You can only record a sky channel and watch the channels normally provided via your VHF and UHF aerials connected to the decoder or vice versa.
My Sky fixes that although you cannot record to a dvd disc on this thing and the privilege comes at a price of course!
Aug 03, 2008 | Panasonic DMR-EH57 HDD Recorder Player
Not recording a full film
1. Insert disc.
2. Press "DVD" button on remote.
3. Press "REC MODE/REC SPEED" button.
4. Keep pressing until desired recording speed.
I believe your problem is that the movie exceeds the 120 minute limit on the target disc at the default recording speed (SP). Try LP instead.
Nov 18, 2007 | Sharp DV-RW340U DVD Recorder/VCR
Televison & Video Logo
251 people viewed this question
Top Televison & Video Experts
Electro Med Services...
